Page 2 of 3 1 2 3
Re: is there a better shifter ? [Re: modelmakerinc] #1873009
07/18/15 05:42 PM
07/18/15 05:42 PM
E
eh100
eh100
E
My T/A shifter must be close to 25 years old. Love it!
You can swing the cable to a rear entry by pulling a couple of bolts out and swing the assembly around.
I like that you can get a morse cable anywhere (usually a boat shop) in different lengths, if you need a replacement.
Re: is there a better shifter ? [Re: ProSport] #1873072
07/18/15 06:36 PM
07/18/15 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Love my B&M Pro Ratchet... wish I would have bought another
over the B&M Quicksilver... I wouldnt ever put a PPP in my car..
they look like crap... I could build that in my shop.... what
does it use to go from the shifter to the trans.... a cable
wave
Re: is there a better shifter ? [Re: tex013] #1873089
07/18/15 06:54 PM
07/18/15 06:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Of course they use a cable..........but so do most of the factory shifters and you wouldn't use that in a race car. A GOOD shifter is about the quality of the cable and how precise and repeatable the detents are in the mechanisms. Like the looks of the PPP or not, they are one of the most precisely machined shifters on the market. Couple that with a quality cable and correct adjustment and they are pretty much foolproof. Most shifters come with a very cheap cable that is prone to stretch.
Too many other shifters don't have positive detents and the shifter can be "in between". The detents on the PPP shifter is like a road map and has a positive stop at every location, it just doesn't slide in a gate and hit a stop. Very positive. Most ratchets can be caught "in between" as well when they get a little wear on the mechanism or if you don't pull it hard enough.
I tend to be a little more about function and weight, than "pretty", but have to admit I think the PPP is one of the best looking shifters out there as well as very light and well made.
Re: is there a better shifter ? [Re: Monte_Smith] #1873097
07/18/15 07:08 PM
07/18/15 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have NEVER.... repeat... NEVER missed a shift with the pro
ratchet... and like most other shifters it also uses a cable..
you can buy the skinny one or the heavy duty one... and I dont
even call the pro ratchet the prettiest either.. but it doesnt
fail... a slight touch of a finger or two and its done.. I'm
not a fan of a gate shifter.... but to each his own
wave
Re: is there a better shifter ? [Re: tex013] #1873127
07/18/15 08:06 PM
07/18/15 08:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a Winters/JVX in my Dart, the cable exits the shifter in the front and enters from the back of the trans. I have a reverse valve body but use a forward gate. I have to push the shifter over and back for the 2-3 shift, less chance of a 1-3 shift. Not the beast by any means but works for me.
Re: is there a better shifter ? [Re: tex013] #1873139
07/18/15 08:42 PM
07/18/15 08:42 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks for all input . I am fitting a proratchet this week for a customer , t400 , will try that Mrpeabody .
I will also try a mates 1/4 stick . I think a couple of guys i race against have ppp shifters will check them out
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: is there a better shifter ? [Re: MR_P_BODY] #1873260
07/19/15 12:14 AM
07/19/15 12:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
no....... you can't.
Re: is there a better shifter ? [Re: MR_P_BODY] #1874329
07/20/15 02:38 PM
07/20/15 02:38 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
I run the B&M Pro rachet as well however twice I had it go from first to third. After the second time it cost me a round of racing I tig welded positve stop on it in the pull direction "trans brake RMVB" and it's been trouble free since, even after installing CO2 shifter. Just can't see the $$ for the PPP JMO.
Re: is there a better shifter ? [Re: tex013] #1874372
07/20/15 03:34 PM
07/20/15 03:34 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's the first I've ever heard of a ProRatchet missing a gear, I didn't think it was even possible unless something in their is broken. I run a cheetah rmvb.
Re: is there a better shifter ? [Re: tex013] #1874906
07/21/15 07:08 AM
07/21/15 07:08 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
PPP
Accept no substitutes
Cable exit can be front or rear
1974 Roadrunner
1967 Charger
Re: is there a better shifter ? [Re: Saskabusa] #1874910
07/21/15 08:08 AM
07/21/15 08:08 AM
pa
572charger Offline
572charger  Offline
pa
hust quarter stick here put it in the car in 1984 still works perfect probably have 20000 + shifts on it !!! LOL
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: is there a better shifter ? [Re: vc360] #1874996
07/21/15 11:57 AM
07/21/15 11:57 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
T/A Cheetah here for close to thirty years still have the original cable, 0 problems
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: is there a better shifter ? [Re: tex013] #1875022
07/21/15 12:50 PM
07/21/15 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm sure a lot of people will laugh at this, but I use my factory ( I don't use no stinking cable ) solid linkage shifter. I fortunately have the room to do this in my car. whistling. I upgraded the pivot bushings so it is very positive and repeatable every shift. Only drawback to it is you can go from 1 to 3 if you are over zealous ( I have done it a few times ). Even incorporated the gear selector panel ( lit for night racing ) in my aluminum box cover.
Fastest 300
Re: is there a better shifter ? [Re: tex013] #1875038
07/21/15 01:15 PM
07/21/15 01:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never been a fan of gated shifters myself and love the simplicity and design of the Hurst Pro-Matic-2 shifter and have been runnin mine since the early 90`s and have replaced one cable and detent spring...... thumbs
Re: is there a better shifter ? [Re: tex013] #1875090
07/21/15 02:54 PM
07/21/15 02:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That's funny Thump. I had the same cheap azz shifter in the Mirada and it also worked great.... So good we bought another for the Duster and that thing was a miserable pos that we could never get properly adjusted.
Re: is there a better shifter ? [Re: Thumperdart] #1875096
07/21/15 02:59 PM
07/21/15 02:59 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I always liked the Cheetah but I always run the Forward VB style gate whether I'm running a FVB or RVB; When you use a reverse VB you can slap back on the 1-2 as hard as you want and then for the 2-3 it's just slightly toward you and back again. With a 3 speed the 1-2 is always the harder and more critical shift to execute, the 2-3 has never been an issue to hit quick. Never worried about missing a shift but I could see that the RVB gate could have that tendency if you get a little over-anxious so I like the hard stop (no-miss) detent pulling back on the 1-2 and never minded easing it over for the 2-3 for the peace of mind. and on a FVB the cheetah kicks it over for you for the 2-3. The only thing that ever vexes me is initially which car I'm in (I have a FVB and a RVB car...both with Cheetahs)
I guess I never liked in-line or ratchets because it just doesn't feel natural to me....I went straight from years and years of 4 speeds to a Cheetah, so it's all what you're used to I guess.
WIZE
In Car:
Re: is there a better shifter ? [Re: J_BODY] #1875114
07/21/15 03:39 PM
07/21/15 03:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
First I`ve heard of that but maybe they too use over-seas crap parts these dayz......... shruggy
Re: is there a better shifter ? [Re: Thumperdart] #1875117
07/21/15 03:45 PM
07/21/15 03:45 PM
Northampton Pa
65 NSS 500 Offline
65 NSS 500  Offline
Northampton Pa
My Vote goes to PPP. I put one in my car and love it..
http://precisionperformance.com/kwik1.htm
Made in US and good stuff. A coulpe of the street outlaw guys even have them.lol drive
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: is there a better shifter ? [Re: Thumperdart] #1875262
07/21/15 07:55 PM
07/21/15 07:55 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thumper ,
I run the Pro Matic II shifter,since 2007/8, and that is my biggest bugbear , inability to get good/correct adjustment and whenever I pull the pan the adjustment goes out shruggy
I do like the PPP but after mocking up off VC360's dimensions that will not fit with the bench seat . [censored]
Fitted a Hurst 1/4 stick in a friends Roadrunner , with buckets , about 15 years ago been fine never even melted a cable .
A mate has a 1/4 stick in his 65 Belvedere , mounted on a raised bracket , has bench seat , seems ok I have replaced 1 cable but with better shielding seems fine .
Just fitted a ProRatchet yesterday in a Holden ute with T400 - wow that is a sweet feeling shift .After I race this weekend , Mopar Sunday , I may have to look at 1 and just make a raised bracket to clear the bench seat .
I would like to keep my Hurst T handle with line lock button , so a ratchet seems the go.
thanks
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: Streetwize] #1875268
07/21/15 08:04 PM
07/21/15 08:04 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Wize ,
thanks for the insight that makes a lot of sense .uess like many others I want to avoid that missed shift that the reverse gate may promote
Tex
New best MPH 130.32
Page 2 of 3 1 2 3
