Re: Replacing Timing Chain
[Re: MoparforLife]
#187078
01/08/09 08:43 PM
01/08/09 08:43 PM
Posts: 10,354 Someplace you aren't
SomeCarGuy
This is getting funny. Some of you guys act like degreeing a cam is some sort of high science.
I couldn't care less what you did 40 years ago. Giving a rookie advise like skipping simple check work is crap. It takes a very few minutes to due. Not doing it is just plain LAZY.
Try for more than 40 years. Experience works. Parts are probably closer to specs now than they were then and it worked then as it does now. You sound like one that thinks that every engine out there off the line has been degreed. Yep I am getting lazier by the year. You will to.
It is just poor advise to tell a newbie that it isn't needed. What if he gets off a tooth? Not hard to do when you don't have 40 years experience. I just hate to see something so simple get pushed aside. If he has a problem later, guess what, the installed centerline will be asked and he will have to pull it apart again to check. MUCH easier to do now.
Ever have a "factory freak" or a "dog"? Details do matter.
[Re: HemiStan]
#187080
01/08/09 10:10 PM
01/08/09 10:10 PM
Posts: 390 pacific northwest
wings471
pacific northwest
wtucker, I live up in Newport News. Shoot me a PM with your number and I can talk you through putting that timing chain in.
Stan
You can't beat a generous offer like that. The opportunity to learn how to do something like this just makes your mechanical knowledge greater and will aid in understanding other related technical questions/problems ...do it.
[Re: dartgame]
#187081
01/08/09 10:14 PM
01/08/09 10:14 PM
Posts: 6,620 Abilene, Texas
fastmark
Abilene, Texas
If you want to save some money and do not want to check the center line - at least compare your old timing sets gears and marks to the new ones on the replacement set. At least you'll then have some idea if the marks are out of whack.
Once upon at time I had a name brand timing set that was mismarked. I installed it and low and behold the motor ran like crap. I pulled it apart and found one of the marks was a tooth off. Ever since then I check the centerline on every build I do. Better to know, than not know.
Amen from the cheap seats. You guys can brag all you want to about building a thousand or a million motors. I started about 30 year ago and have built maybe a hundred or so. I have found TWO motors that the timing marks were off from the factory. They were both 340 factory sets or may have been replacement sets. One was off 8 and the other off 16 degrees. The friend with the 16 degree off motor always wondered why it ran like crap. I have found a few aftermarket sets needing as much as 4 degrees to correct.I would say the chances are less than 2-3% it would be off more than a few degrees, but it can happen. Degreeing a cam is not rocket science and is just the first step in learning how to blueprint motors. Buying mics and tools will make it enjoyable to build motors. Get busy and learn.
[Re: 70dart360]
#187083
01/08/09 11:13 PM
01/08/09 11:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If its stock dude whats the use? Its gonna be a pig anyway ya look at it. And as far as valve to piston clearance in a stocker Mopar? Whatever, the dang piston is 1/4 inch in the hole. Say what ya want, but I been a master mechanic for 25 years and unless its a performance engine why waste the time and try to confuse they guy? Never seen someone degreee a cam in a stock engine doing a basic timing chain job. You must be one of those shop owners that suck every red cent out of their customers for worthless extras!
Line your dots up man and run with it.
[Re: SomeCarGuy]
#187085
01/08/09 11:47 PM
01/08/09 11:47 PM
This is absolute nonsense. FIRST degreeing a cam won't do much good if you don't know what you started with. That is, it might run better on the factory marks, anyhow.
SECOND just because you didn't degree the damn thing does not mean you'll "get it off a tooth."
Please don't make fun of 40 years experience. Engines pretty much work the same way now as they did 40 years ago, WAIT!!! WAIT!!! WE ARE talking about a 40 year old engine!!!!
I'll guarantee you that the thousands of 340's 440's 383's and probably street hemi's that went down the production line NEVER SAW A DEGREE WHEEL. The factory assembly line folks slapped the sprocket "on the marks" and down the line it went.
AND ONE LAST TIME. If you get the cam "on the marks" degreeing will NOT do you any good until you have a baseline. Depending on whether this is a "torque monster" street engine or an RPM screamer, you won't know which way to push the wheel until you find the baseline.
From the sounds of the original poster, I doubt that he has access to a chassis dyno, and neither do most of the rest of us.
#187086
01/09/09 12:09 AM
01/09/09 12:09 AM
fastmark
Abilene, Texas
This is my point exactly.If you lined it up "on the marks" as you call it, the timing marks could be off and you would never know.The only way to check the marks is to degree it. You say that you have done thousands of engines and never degreed a stock motor, then how do you know they were all correct? One of the motors that I found to be off 8 degrees was one that I had built before I started checking the cam degree. I always wondered why is had less low end torque than I expected. I agree that the chances are slim, but I have had two in my "short" 30 years of engine building.
[Re: fastmark]
#187088
01/09/09 12:38 AM
01/09/09 12:38 AM
Just for clarity, I never said that.
The point I'm trying to make, though, is that DEGREEING a cam to whatever the grinder specked does not guarantee that is what you are going to want. So without trying it, establishing a baseline, and then deciding to advance/ retard it from there is simply shooting in the dark
#187091
01/09/09 10:33 AM
01/09/09 10:33 AM
Posts: 21,927 Kirkland, Washington
Pacnorthcuda
I don't build engines, but I install cams from time to time, and I want to KNOW the installed centerline so I have that baseline info. If I install a cam straight up without degreeing it I don't really know what the ICL is. Then, if some issue comes up, like a soft bottom end, or a top end that lays down early, I am left guessing if its the cam ICL or not. My last install on a Voodoo ended up 106.75 on a recommended 106 install. (yes I installed straight up) If I did not degree it, I would not know.
[Re: 70dart360]
#187092
01/10/09 12:24 AM
01/10/09 12:24 AM
SomeCarGuy
This is a performance website so...
A stock engine will need all the help it can get and if it is off it will for sure be a pig. Why leave it to chance on the sole reason that you feel like being lazy?
[Re: 70dart360]
#187093
01/10/09 12:25 AM
01/10/09 12:25 AM
SomeCarGuy
Take all the mechanics that dont, and break it down into odds like in Vegas. Bout a million to one that it'll make a drastic difference.
Why roll the dice?
#187094
01/10/09 12:26 AM
01/10/09 12:26 AM
SomeCarGuy
Yes, you need a baseline but without doing the job you will be pondering about what to do without a clue.
