Re: How many grams change before rebalance??
[Re: DemonDust]
#1868443
07/11/15 09:54 PM
07/11/15 09:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The amount that is going to be removed is probably only going to be a few grams.
But the high rpms is what I'm worried about. 9400+ You better rebalance.. and get it close... some of these guys that dont balance dont give a damn or just have junk... I balance every engine... yes Chrysler was the worst when it came to balancing and in a lot of cases it showed.. unless it was just stock junk... I normally turned 8200 but I did turn 9600 on a few runs.. smooth as silk... see what happens at 9500+ with a crap balance... you sure wont like it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: DemonDust]
#1868480
07/11/15 10:56 PM
07/11/15 10:56 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I went with a piston that is 14 grams lighter when I converted to pump gas. No re-balance and ran just fine on the dyno. No issues on the street either. I don't turn 9400 RPM ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) On the dyno we went to 7200.
[Re: MR_P_BODY]
#1868697
07/12/15 11:11 AM
07/12/15 11:11 AM
Quicktree
But the high rpms is what I'm worried about. 9400+ You better rebalance.. and get it close... some of these guys that dont balance dont give a damn or just have junk... I balance every engine... yes Chrysler was the worst when it came to balancing and in a lot of cases it showed.. unless it was just stock junk... I normally turned 8200 but I did turn 9600 on a few runs.. smooth as silk... see what happens at 9500+ with a crap balance... you sure wont like it ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) stock application no problem. high rpm race motor balance it, shouldn't even be a conversation about it.
[Re: DemonDust]
#1868714
07/12/15 11:58 AM
07/12/15 11:58 AM
Posts: 7,506 Az
Crizila
Az
In that case, there really shouldn't even be a question about it - at any rpm.
Fastest 300
[Re: DemonDust]
#1868727
07/12/15 12:24 PM
07/12/15 12:24 PM
Posts: 4,213 New York
polyspheric
New York
Vizard's latest BBC book strongly suggests that closely matching all reciprocating weight (1 gram) is far more important than making a specific percentage number.
Boffin Emeritus
[Re: DemonDust]
#1868743
07/12/15 12:52 PM
07/12/15 12:52 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I just want everyone to know we're talking maybe 3-4 grams the amount of oil on the rotating assembly could vary more than that, i think you'll be fine.
72 Plymouth Roadrunner 11.08@123.25
[Re: Crizila]
#1868758
07/12/15 01:18 PM
07/12/15 01:18 PM
Quicktree
In that case, there really shouldn't even be a question about it - at any rpm. how many 9600 rpm motors have you tested that theory on?
[Re: Quicktree]
#1868804
07/12/15 02:51 PM
07/12/15 02:51 PM
Posts: 7,506 Az
Crizila
Az
In that case, there really shouldn't even be a question about it - at any rpm. how many 9600 rpm motors have you tested that theory on? None of course. Don't think there are too many out there spinning that #. Mine has lived 16 -19 grams piston heavy @ 7K for some time now - which is the extent of my experience. I pretty much relied on my engine machinist for the decision not to rebalance. Could blow up tomorrow ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) . ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Fastest 300
[Re: Crizila]
#1868883
07/12/15 05:18 PM
07/12/15 05:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
The engine is probably overbalance already. Small changes in pistons are tolerable even pins. You change rods that a different weight on big end, rattle bad.
[Re: dogdays]
#1868892
07/12/15 05:32 PM
07/12/15 05:32 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Now for a real life example. A board member reports that he changed 591 gram 318 pistons with 507 gram KB pistons with no noticeable change in how the engine ran. There was no attempt to rebalance the engine.
Some people won't notice a subtle vibration, others will.
