Re: TTI headers where to buy?
[Re: Skeptic]
#1868469
07/11/15 10:39 PM
07/11/15 10:39 PM
Posts: 4,087 The Wet Coast, Canada
megajoltman
I just bought a set a couple of weeks ago. They fit a B engine A body perfectly- I wasted my $$ trying to make B engine headers work. The nickle chrome ones look nice and save about $200. I'm not worried about blueing- two reasons, 1- it's been dyno'd so the tune should be pretty close and 2- I like the bluing look. As far as the cost, they are well built and if there was that much margin someone else would be knocking them off. I've learned my lesson no more cheap headers. What tube size ones did you buy?
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: MidPenMopar]
#1868509
07/11/15 11:35 PM
07/11/15 11:35 PM
Posts: 10,951 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
ROAD TRIP!!! Go visit the magic kingdom and go a bit further south to Corona. It's not a bad drive once you get out of Anaheim.
I’m listening.
[Re: Big Bad Bee]
#1868525
07/11/15 11:53 PM
07/11/15 11:53 PM
Posts: 6,516 Santa Cruz, California
Lefty
I've used both Dougs and TTI and documented the difference. These are 440 with 2" pipes - TTI Dougs TTI Dougs TTI dings the tube for plug clearance, Dougs does not, but it's a tight fit without the ding
[Re: MidPenMopar]
#1868726
07/12/15 12:23 PM
07/12/15 12:23 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
My old CPPAs were one of the first sets they made.They are crusty now but still solid.My 6 cyl is a royal pain to change in my 65 440 B body.4 isnt real easy either.I run 2 inch tubes think smaller would be easier.Rocky
Chrysler Firepower
[Re: megajoltman]
#1869109
07/13/15 12:02 AM
07/13/15 12:02 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I just bought a set a couple of weeks ago. They fit a B engine A body perfectly- I wasted my $$ trying to make B engine headers work. The nickle chrome ones look nice and save about $200. I'm not worried about blueing- two reasons, 1- it's been dyno'd so the tune should be pretty close and 2- I like the bluing look. As far as the cost, they are well built and if there was that much margin someone else would be knocking them off. I've learned my lesson no more cheap headers. What tube size ones did you buy? The full length 1-3/4". They are a little small, but I have a stock stroke 400 and it's a street car with a full exhaust (Pypes 2-1/2" X pipe). I looked online and found calculators that recommended anything from 1-5/8" to 2-3/8" for the primary tubes. If I have a 500" motor I'd want bigger but since Andy F made 550 Hp with a 470 and cast manifolds, I don't think I'm giving up much.
[Re: MidPenMopar]
#1869135
07/13/15 12:41 AM
07/13/15 12:41 AM
Posts: 749 NY
Beep Beep
NY
I would recommend the TTI's, I bought them from Rob's Rod Shop. I got 10% off for the Carlisle Chrysler Show. They shipped directly from TTI. I went with the 1 7/8 in my 69 RR. They fit great but I wasn't to happy with the polish ceramic coating. That burned off on some tubes after a couple hours. I don't think the coating is that great. I also used studs on them.
