Re: 66 Satellite barn find/ build project.
[Re: cirrusaero]
#186779
12/11/09 11:07 PM
12/11/09 11:07 PM
Nice car.
[Re: 69B3GT]
#186781
12/13/09 04:47 PM
12/13/09 04:47 PM
Posts: 622 ct
jkgtx
ct
reminds me of my car when I started on it 30 years ago yours was in better shape:)
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: 69B3GT]
#186782
12/26/09 09:24 PM
12/26/09 09:24 PM
Posts: 90 Chandler, AZ
cirrusaero
Chandler, AZ
That has got to be the coolest oldschool looking car ive seen. Very Nice Any track time yet?
Yep, just took it to the track 2 weeks ago. Keep in mind that I don't have much drag racing under my belt but I managed to make it down the track without hurting myself or anyone else. I made a total of 6 passes just to make sure the car was A-okay. ( it did break a little )
First pass got a decent burn out but since it was the first run I just wanted to take it easy. R/T .156, 1/8th 7.63, 1/4 14.47, 89mph.
2nd run: R/T .152 1/8th 7.45, 1/4 13.53, 87.67mph (Still short shifting into 3rd and cruising to the line) 3rd got a bad burnout tires spinning all through 1st gear: R/T .243, 1/8th 7.78, 1/4 12.28, 108mph 4th run: good burnout R/T .124 1/8th 6.97,1/4 11.96 114 mph (still short shifting into 3rd gear) 5th run: good burnout R/T .198 1/8th 6.73, 1/4 11.61, 107 mph.
The last 2 runs the MSD box seemed to be cutting out over 4k RPM. The battery was draining and I didn't bring enough tools to check it out or fix it. Figured I'd pack it up and crawl home. I drove the car there and my headlights were dimming to almost nothing so I just drove with the parking lights on.
So I have a little bit of work cut out for me. Tech inspector asked me to put the battery in a legal box since it's in the trunk, need metal valve stems on the wheels, and few other misc. things. Overall it was a blast and can't wait to take it back next month.
68 Charger 605 Hemi, Keisler 5spd, Pro-touring 66 Coronet 2dr post 66 Satellite
[Re: cirrusaero]
#186783
12/27/09 02:01 AM
12/27/09 02:01 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
After you get your electrical system under conrol (I'd start with the ballest resistor, alternator, then the voltage regulator with a charging problem) check your fuel pump and fuel filter, it could have been from lack of spark with a weak battery but that sounds like it could also be starving of fuel at higher rpms under load.
[Re: sparkswillfly]
#186787
01/20/10 11:26 PM
01/20/10 11:26 PM
cirrusaero
Chandler, AZ
rear rims are a 15 x10. backspacing is 5.75. There is not much room on either side of the stock wheel wells but it does NOT rub. The outer lip was tweaked in a little and the inner/trunk area was sledge hammered in But like I said that was they way they did it back in the day.
FYI This car will be driven up to Mopars at the Strip.
[Re: cirrusaero]
#186791
01/27/10 08:28 PM
01/27/10 08:28 PM
Posts: 550 ne
broncobra
ne
[Re: broncobra]
#186792
12/18/12 05:33 PM
12/18/12 05:33 PM
cirrusaero
Chandler, AZ
Question: What is a good rust preventative for the bare metal behind the door panels, under dash inside trunk area ETC? I recently moved from Phoenix to South Florida and I don't want to see this original bare metal get any surface rust. The car is not in Florida yet and I'd like to prevent this before it gets out here.
Someone suggested Pledge since it is silicon based wax but it'll be a [Edited by Moparts - Family Friendly Site - Keep it clean] to get off should I ever want to paint the car.
[Re: NI4NI]
#186794
01/29/15 02:03 PM
01/29/15 02:03 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
The car is currently here in NJ with Kevin's brother. Very cool car.....
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: cirrusaero]
#186796
01/31/15 02:27 AM
01/31/15 02:27 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
There are lots of choices in that area, most are topicals like Pledge, WD-40, Wax, or my choice, RPM (from ECS) etc. If you paint it down the road these areas could left bare metal just as they are now, or you should be able to prep them properly with a light sand/scuff and a good wax & grease remover, no big deal.
[Re: Joesixpack]
#1985773
01/07/16 07:21 PM
01/07/16 07:21 PM
cirrusaero
Chandler, AZ
Well the car never made it out to Florida. I moved to a peninsula off the coast of Stuart Florida and we barely made it two years there before moving back to the Phoenix, AZ area. Car is back here enjoying the dry desert air. But sadly I think the time has come to sell it. When I first bought the car I had 3 kids that I was a Foster Parent to but I know have 5 kids, all adopted and part of the family for good and I just don't have the time to drive it. I hope someone can really appreciate this car for what it is.
See if i can figure out how to add a youtube video of it driving.
