Re: Is it safe to take on long ride?
[Re: glenngomango]
#1866464
07/08/15 11:32 AM
07/08/15 11:32 AM
RapidRobert
I wouldn't be afraid to do it but is there a possibility that you could pickle fork it apart & change it out real quick (easy to do/no realignment needed) & what kind of shape is the rest of the system in?
[Re: Hooligan]
#1867198
07/09/15 02:06 PM
07/09/15 02:06 PM
dogdays
All this legalism is just bandwagon BS, and the truth is, it's not like this is a tie rod end. Also it's not highly stressed. If it fails, you are still going to have some control over the car, although you may suddenly lurch in one direction or the other...
There are two real reasons why you should have changed this out before your weekend trip, which I believe was last weekend so this whole thing is moot anyway, but here goes...
1. It is THE RIGHT THING TO DO. Contrary to popular thinking, there IS Right and Wrong. It's not how you feel at the time. Driving with a known bad suspension or steering piece is Wrong. So you take care of it because it's the right thing to do. Sounds simple? It really is.
2. It is an easy fix. If one truly believes point #1, then this point is invalid. But the decision is made easier by the fact that this is an easy swap and doesn't cost too much. It won't require a realignment (no suspension shop that I know would do an alignment with such a worn piece, therefore, the current alignment must have been done much earlier and replacing the idler arm will bring it back to where it was originally). Also it'll help with tire wear.
End of story.
R.
