Re: 440 advice needed [Re: PlumCrazy73Dodge] #1867212
07/09/15 02:38 PM
07/09/15 02:38 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Originally Posted By PlumCrazy73Dodge
You Will be amazed what proper carb tuning will do. It will crisp that motor up a lot. Its not too big as mentioned but there are a lot better street carbs out there out of the box if your not a carb guru.
We will give that 850 another chance. Will be interesting to tune it together with the A/F meter.
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: 440 advice needed [Re: BSB67] #1867214
07/09/15 02:40 PM
07/09/15 02:40 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Originally Posted By BSB67
Personally, if the piston is only 0.020" down, I would zero deck the block.
If you do this now, you will have several nice future options for aluminum cylinder heads with quench and a decent compression ratio.
We would probably have done that, but my buddy wants to get it ready and the machine shop have no time to deck it the next two weeks.
71 Duster 340
Re: 440 advice needed [Re: HP2] #1867225
07/09/15 03:02 PM
07/09/15 03:02 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Will have the block back for the weekend, cleaned, with new bearings everywhere, checked bores and rings and ready to assemble. Both crank and cam has been polished. Hopefully a new cam gear with possibilities to get 6 degrees advance will land here too before weekend. A new high volume oil pump is already here.
Will cc the heads, and another machine shop will stand ready to mill them on Monday. Hopefully I can find a valve spring tester too.
Came to think of one thing today. My buddy mounted a hood insulation, and with the RPM intake the Twin Air top gets choked by the insulation, and the height of the filter is only 2". Do you think this might have affected the breathing..?
How much cylinder pressure can we expect this combo (with 9.5:1) have?
Well how much torque and hp would it give?
71 Duster 340
Re: 440 advice needed [Re: HP2] #1867236
07/09/15 03:23 PM
07/09/15 03:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Pay attention to timing chain selection , you need to spend money to get a good one that is more adjustable and is able to use offset bushings if needed , the low cost ones will have a SLOT instead of a hole for the dowel pin , good luck drilling a hole for the bushing.
Re: 440 advice needed [Re: JohnRR] #1872764
07/18/15 08:26 AM
07/18/15 08:26 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Update:
Same Comp cam went back in. My buddy is a little cheap so he bought MrGasket offset bushings and I drilled the cam gear so much I could and put in a 6 degree bushing and got 102.5 degrees centerline, 3.5 degrees advanced from 106 (this means that the cam was installed 2.5 degrees retarded and that explains a little). Had wished for 5-6 degrees advance but I couldn't get more with this cheap crap.
Shaved the heads .020 and got 10.17:1
Still no adjustable rockers so preload is hard to measure. All I can say is that is is very little preload. Hope he can spend a little on used steel rockers some day.
Painted engine bay yesterday and will paint the engine today and, hopefully, will get it in so I can install the exhaust and get it running by Wednesday.
71 Duster 340
Re: 440 advice needed [Re: HP2] #1872906
07/18/15 02:50 PM
07/18/15 02:50 PM
dogdays Offline
dogdays  Offline
Should be no lash with a hydraulic cam. So what are you meaning to say?
R.
Re: 440 advice needed [Re: dogdays] #1873348
07/19/15 06:46 AM
07/19/15 06:46 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
R.
Did I say lash? It should be preload, sorry!
71 Duster 340
