Looks great Herb! Now you can safely redline the thing in 4th with room to spare. I believe the speed rating on those tires is 186 mph.
I need some fresh front tires on my E-body, and I may go the same route. Radial T/A's are only rated to 110 mph or something.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
