Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1861705
07/02/15 12:22 AM
07/02/15 12:22 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
What car are we talking about..GM? or others?
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: Plum440] #1861767
07/02/15 01:31 AM
07/02/15 01:31 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Originally Posted By Mopar_Beach
whistling
got one of these too......:)........
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: AARCONV] #1861769
07/02/15 01:32 AM
07/02/15 01:32 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
69 B-body.....non-locking steering column, etc...
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1861933
07/02/15 12:34 PM
07/02/15 12:34 PM
Alberta
rustbuckett68 Offline
Alberta
The lighter idea works. I have plugged in a wire from the tach lead (or coil) to the lighter hot, when the button is pushed in, it grounds the element. As for fuel, check into fuel tank selectors for a truck with dual tanks. Wire it so it is open when 'hot', and cap off the other inlet. Haven't tried a switch inline the the power going to the control unit, but it should work. BTW, who notices an extra dimmer switch on the floor, maybe a little higher up the floor? Also used to have a flashing light under the dash that lit the floor up a bit, it was noticeable when beside the vehicle, but not too obvious.
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1862176
07/02/15 05:43 PM
07/02/15 05:43 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
whistling
And I do too, but the concern is when nobody is around..
Believe you and me a DEAD thief is the best kind..
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1862637
07/03/15 03:57 AM
07/03/15 03:57 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
well, dang, if you leave the S&W 500 in the car, it will get stolen for the gun smile
Cheap burner phone on a cheap year long plan or tied to yours, hidden and powered inside the car with a gps tracking app, even with the battery disconnected you will get a day or five to find it
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1863178
07/04/15 12:15 AM
07/04/15 12:15 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I've a couple occasion where I have either misplaced my iPad/iPhone and used "Find my iPhone app to locate it". As long is it is turned on and the battery has charge, you will promptly find it. If it had been shutdown or the battery has run down, it will report where it was prior to either of these events.
One day I could not find my iPhone. The app said it was at my home. I tried calling it, but I had my ring in silence. I then sent out a signal from the app on my iPad to cause my iPhone to beep. Could not hear it. I then opened the doors on each of my cars and in one of them I could hear a muffled beep but still could not locate if. Finally found it between passenger seat and console where it had fallen.
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1863185
07/04/15 12:23 AM
07/04/15 12:23 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Mastrack, 19.00 per month, if its stolen you will have a GPs location to within 40'
http://www.mobileassetsolutions.com/
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Alarm Systems/Anti Theft Deterrent For Older Iron....?? [Re: E-Ticket] #1863219
07/04/15 12:54 AM
07/04/15 12:54 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
I am liking the GPS idea in addition to a lot of suggestions posted so far. Hidden home/driveway camera's are also an idea I've been thinking about....
