Eddie sm block victor news
#1857973
06/27/15 03:23 AM
06/27/15 03:23 AM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
The head is reality. Buddy and I talked to the product engineer yesterday afternoon. The head was recast, and is available with a full CNC port, and can be bought that way with roller springs if desired. They added meat in the recast( really went back almost to the drawing board) Heads have actually now been produced, and will be available next month for purchase. He expected to have real world " not happy" numbers in the next 7-10 days. Expects the full CNC version to flow 350 ish peak. Vendors will have pricing very shortly. As I said, they have now got some of these heads in inventory, but won't sell them direct. They are revamped, a reality, and mighty quick will be in customers hands. SWEET.......
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
Re: Eddie sm block victor news
[Re: J_BODY]
#1857980
06/27/15 03:39 AM
06/27/15 03:39 AM
B3422W5
Portage,michigan
first time I read a post like this was in 2012 when I unloaded all my W5 crap in anticipation..... No more maybe's They are on the shelf and have been made. He told us they were not happy with how the head initially worked, and much time was spent re inventing the thing. Initially it wasn't to be offered fully ported. Part of the rework was casting more meat. We didn't discuss all available options, but I do know two options are a ready to run flat tapper or roller Full CNC port head, fully assembled.
[Re: B3422W5]
#1858232
06/27/15 04:20 PM
06/27/15 04:20 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If 350 CFM=700 HP I would just use a 5.9 magnum block, they can take it. Most guys will never make the max out of them anyhow. If you are really really going to push the true maximum out of them then yes it would be nice to find a better block.
How come the AMC guys can have an AL block but not the SB mopar? Someone send a siamese R3 block to china and have one made in aluminum pleeeeeese!
[Re: B3422W5]
#1858239
06/27/15 04:30 PM
06/27/15 04:30 PM
HotRodDave
Kalispell Mt.
Awe shucks! Valve angle is 2 degrees different! I wonder if I can use my pistons as is, change the valve pocket a touch or do I need new pistons? If they are gonna move it you would think they would move it enough to make a big difference, or maybe 2 degrees does?
If this is true the timing may be good for me...
[Re: B3422W5]
#1858278
06/27/15 05:45 PM
06/27/15 05:45 PM
B3422W5
Portage,michigan
IF that head can go 350, I would bet 750 would be easily attainable. That is a bigger head than a W5 by a good bit, and I know those can support 700, based upon on track results/ mph/ weight.
[Re: B3422W5]
#1858560
06/27/15 11:38 PM
06/27/15 11:38 PM
Posts: 20,207 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well if the cnc ported ones come in at an honest non-inflated 350 cfm a good hand finishing is usually good for an extra 15-20 cfm so even though my 360-1's are coming around I may have to get a set to play with
[Re: pittsburghracer]
#1858636
06/28/15 12:28 AM
06/28/15 12:28 AM
B3422W5
Portage,michigan
Well if the cnc ported ones come in at an honest non-inflated 350 cfm a good hand finishing is usually good for an extra 15-20 cfm so even though my 360-1's are coming around I may have to get a set to play with I think it will probably take hand finishing to get them to 350. Just a guess on my part. I was excited they redid them so they could run a cnc program on them and offer them fully ported. Initially they were only going to be offered basically " pocket ported" It speaks well of Edelbrock they decided to not put these out until they were right
[Re: Stroker Scamp]
#1858638
06/28/15 12:30 AM
06/28/15 12:30 AM
B3422W5
Portage,michigan
any idea of a price tag?? We bugged him about that. But no dice. He said vendors will have pricing shortly. I am hoping a set can be had fully ported and setup up to run a roller for 2500 or so. I hope I am not optimistic. Even if in that neighborhood, you will still need an intake( super victor) and rocker gear( which we forgot to get into with him about) I am pretty sure w5 headers will bolt up.
[Re: B3422W5]
#1859728
06/29/15 04:16 PM
06/29/15 04:16 PM
HotRodDave
Kalispell Mt.
Looks like you could get pontiac or AMC around $4300 ready to assemble? or roughly the same as an R3+correcting issues.
[Re: B3422W5]
#1859761
06/29/15 04:43 PM
06/29/15 04:43 PM
Posts: 1,566 New Smyrna Beach FL
scottb
New Smyrna Beach FL
[u][/u]You can always buy the Ritter block for 8k by time your finished with it
[Re: B3422W5]
#1859810
06/29/15 06:00 PM
06/29/15 06:00 PM
BradH
It speaks well of Edelbrock they decided to not put these out until they were right Too bad they didn't take the same approach w/ their BBM Victor heads...
