Re: Six pack idle mixture screw broken -fix? [Re: 70440SIXPK] #1864116
07/05/15 03:05 AM
07/05/15 03:05 AM
Jasper, Indiana
fastnos Offline
fastnos  Offline
Jasper, Indiana
This is from Bud Weaver - Six Pack Solutions...
I do take out the screws. There is a couple of things you can try before you send them off. Get hold of some PB Blaster. Spray the things thoroughly and let it pool inside the screw bosses with the TB facing up overnight. Blow out the screw bosses with compressed air the following day and try to gingerly to unscrew them. If that is to no avail then they will have to be drilled out. You can usually do it with a 1/8" LEFT HAND spiral drill bit. The screws are 8-32 which is a #29 (.136") tap drill pilot and the 1/8" will not interfere with the minor diameter of the threads. This takes a bit of finesse because I usually have to "flatten" the boogered up screw slot with an end mill before I can center-spot the screw for drilling.
If you are not comfortable doing that then hit me up and i will do it for you. It usually runs $50.00 to get them out. that is my flat shop rate charge for that service. I have custom jig fixturing here and a dedicated mill that I use for this purpose.
A True Hybrid: Burns Gas AND Rubber!
Re: Six pack idle mixture screw broken -fix? [Re: 70440SIXPK] #1949058
11/10/15 10:33 PM
11/10/15 10:33 PM
So. Cal. For Now But Texas Bou...
69sixpackbee Offline
Just got done zooming some posts.
It's been while since I have been on the board. Posts like these really warms this old warrior's heart!
Thanx again for all of the kind words and again, this would not have been possible without you fellas jumping on board with me.
Thanx to ALL of you that have helped make this all worth while.
Still making 'em and still hear the singing of praises!
Regards,
Bud Weaver
Six-Pack Solutions!
Re: Six pack idle mixture screw broken -fix? [Re: 70440SIXPK] #1949138
11/11/15 12:32 AM
11/11/15 12:32 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I can buy and can supply Bud's screws (and tool) when requested by customers (great product!), so if anyone wants them added to their restoration just ask!
