Size a budget built turbo small block.
#1854596
06/22/15 07:27 PM
06/22/15 07:27 PM
Posts: 363 kentucky
roadrunner7020
kentucky
So I am actually starting to put together a turbo setup for my small block, beofre i get in to deep can someone help me size a proper turbo for a 360 ill make sure to have a good dished forged piston a mild efi/turbo specd cam and good rods. The car will be a 73 duster with a 904 and a 8.75 with 3.23 gears. depending on what the registration comes to (as the car was junked at one point) I plan to build it into a competitive street strip car but may be race only. The classes in my area have a restriction of a 76 mm turbo and the racers in that class are running in the 5.50 range 1/8th mile so im assuming i wont be competitive here may be a fun bracket/grudge car. I currently have a log setup that has a t4 flange and is setup for a 38mm wastegate which im hoping i can use but im afraid of boost creep. Any advice would be appreciated. I would love to go MS3 and coil near plug like my street big block car but such electronics aren't allowed in the OSCA class to my knowledge, so likely it will be a blowthru 750. Thanks in advance.
Re: Size a budget built turbo small block.
[Re: roadrunner7020]
#1854758
06/22/15 10:16 PM
06/22/15 10:16 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
I've got just over 3k in my setup, and that includes a $1000 csu blow through carb who i aabsolutely recommend. Did everything my self. T6 s475, twin 38mm wastegates, 2.25" hotside on a 400"ish sb. 137 mph @ 3550lb on 10lbs. Fixing to turn it up and run a local 8.5 tire class here soon.
My advice is to no buy cheap parts especially wastegates I've heard alot of horror storys.
#1854825
06/22/15 11:38 PM
06/22/15 11:38 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Looks good, do you use meth/water injection?
Brett Miller W9 cnc'd heads STR Chassis fabraction
#1854862
06/23/15 12:13 AM
06/23/15 12:13 AM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
We have a member here with a small block turbo car who is intending to build exactly such a kit. I would guess he will see this thread at some point.
[Re: 1967dartgt]
#1855015
06/23/15 09:12 AM
06/23/15 09:12 AM
1980volare
Dayton, OH
Looks good, do you use meth/water injection? Nope. Blow through e85
#1855149
06/23/15 01:50 PM
06/23/15 01:50 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Yes still working on the kits. The last few months have been focused on getting mine back together with my old setup so I could race while I keep working on them!
To the original poster... how much power and/or how much do you want to spend on the turbo. That will go a long way in determining what turbo you need.
There are $400 75mm turbos, and $2000 75mm turbos.
If you have a stock block, 904, and 8 3/4" I'm guessing you're not looking for max effort.
The S475's (1.32 A/R, T6 Flange) can be had for under $700 and will make just over 1000hp. Pretty good bang for the buck on a small block. They are pretty big/bulky though, and there are other options.
There are some other "offshore" turbo's that can be had in the 75mm range in a T4 flange that are a little cheaper and will spool better, but won't make the power of the S475.
If you want to make less power, you can get something that isn't rated for that power level, but will spool better.
If you want more power, that can be had for more money, but I'm not sure how well the stock block will like it.
My advice is to set a realistic budget, base some realistic power goals from that, and stick to that plan when you start buying parts.
No sense in putting a $2000 turbo that will make 1400hp on a $100 block.
#1855794
06/24/15 10:35 AM
06/24/15 10:35 AM
dizuster
Oakland, MI
I don't think you'll get a stock block to go 5.50's. The problem is that is uncharted territory. There are not a lot of turbo small block mopars out there, so it's really hard to judge how much power the stock block will take. Mine makes around 800hp, but it's shown some signs of block fatigue (odd main bearing wear from flexing, excessive blow by under boost requiring puke tank, etc...) Mine is filled, and even has a girdle on it now, but I'm not sure how much more power it would take. There are some very fast stock block ford/chevy examples out there though, and I don't think the Small block mopar is any worse then a 350/351 combo. Here is my story so you can see if it helps you. Started with a cast crank/stock block/stock rod/forged shelf piston combo with iron heads, transbrake 727, 8 3/4, S475 turbo running through stock dodge ram manifolds. First thing it broke was the sprag in the trans, it even had a low band apply valve body. Upgraded to super sprag, replaced warn clutches because some of them were hot looking (stock clutches). This was at the 10.60~10.70 range. Then I kept turning it up... went from 10.60~10.20's pretty easily. Turned it up looking for 9's. 10.08@136 on 20psi. Next pass all hell broke loose. Sheared the pinion off the 8 3/4" at the starting line. Had to replace with a Dana 60. Took the trans apart, and the front planetary was 1/2 ripped out (unknown if it happened before or during the gear break). Needed a planetary, new direct drum (again old one had hot clutches even with Alto's). Took the motor apart to put better rods in it, and found 3 of the 8 pistons caved in. Not melted through... just overpowered. Found that the bottom end had some weird main bearing wear attributed to the block/crank flexing, so I put a girdle on it. Every pair of valves had a crack between both cylinders, so I had to put heads on it. Since with the better heads, it's been 9.88@138 on 15~16psi. (Which equates to 6.31@110 if you're wondering). So just from my experience no where NEAR 5.50... I'd be leary of trying a 8 3/4 and 904 combo. That being said... if you're looking to use what you have, I see no issue with building a lower powered combo to get your feet wet, and stepping up. Put a cheap T4 turbo on it, and build yourself a good hot side. That way later when you want to step up on power, you can just replace the turbo without having to rebuild everything else. Low 10's in an a-body could be done fairly low cost, and be fairly reliable. I would put one of the offshore lower cost turbo's on it. Either the GT45 80mm, or the 80/75. Build yourself a 2.25" hotside, and let it rip. IMG_20140723_183648_773
[Re: dizuster]
#1856013
06/24/15 04:25 PM
06/24/15 04:25 PM
Posts: 8,375 fredericksburg,va
cudaman1969
fredericksburg,va
[quote=dizuster]I don't think you'll get a stock block to go 5.50's. The problem is that is uncharted territory. There are not a lot of turbo small block mopars out there, so it's really hard to judge how much power the stock block will take.
I would put one of the offshore lower cost turbo's on it. Either the GT45 80mm, or the 80/75. Build yourself a 2.25" hotside, and let it rip. --------------------------------------------------------------------------------------------------------------- I know where're talking LA stuff but I have a good stock 5.7 sitting here, would the same parts,ideas, work for the it?
[Re: TheOtherDodge]
#1859239
06/28/15 10:41 PM
06/28/15 10:41 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I don't think you are going to get into the 5.50 range with an 8 3/4, 904 and stock block, unless you are looking to just make 1 banzai pass.
If you want to get in the 6.50 range, you can do it easily with a "cheapie" 76mm and the combo you want to run. FYI, I run a "cheapie" 76mm T-4. What's a "cheapie" turbo?? What converter and gear are you running? Diz...what about your converter and gears? Any pics of your motor you care to share? Thanks!
