Re: V-10 Hemi Cuda
[Re: dodger mope]
#1860126
06/30/15 12:23 AM
06/30/15 12:23 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
your friend Larry has a lot of skills Yes good work on the engine components , not so much on car.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: V-10 Hemi Cuda
[Re: TrWaters]
#1860127
06/30/15 12:24 AM
06/30/15 12:24 AM
Posts: 1,845 Tampa
DusterDave
Tampa
So, what was the point of posting a pic of that show-only car in THIS forum? If its to elicit a response, well, here is mine, with particular emphasis to the back wheels....... Hopefully, Dragula will see this and chime in. Why? Because I felt like it. The engineering that went into this car can be appreciated by some of the members here. This car was hand built, not pieced together out of a catalog. Designed and cast any cylinder heads or intakes lately? If you're asking me that question, there's no reason to. My comments were directed strictly at the over the top, cartoonish body mods. Now, regarding the hand made heads and intake, he earns my respect, no question.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: V-10 Hemi Cuda
[Re: TrWaters]
#1860143
06/30/15 12:43 AM
06/30/15 12:43 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of you oldtimers will have to help me out here but 50 years ago in the comics there were rod roosters (rat fink) if I am remembering right. 3 x 3 stickers that we as kids stuck on everything. Way to cartoon looking for my tastes and just another all show and no go example for the car show crowd
Re: V-10 Hemi Cuda
[Re: TrWaters]
#1860278
06/30/15 09:42 AM
06/30/15 09:42 AM
Guitar Jones
And yes, the whole idea was to make a full size Muscle Machines replica. The blower and scoop aren't big enough. Just messin' with ya. Obviously the amount of skill, talent and work that went into it is certainly something to be admired. Personally I don't get it but whatever blows your skirt up...
