Re: How much NA HP to equal NOS HP [Re: AndyF] #1857659
06/26/15 08:30 PM
06/26/15 08:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By AndyF
Originally Posted By 1967dartgt
If you have a 700 hp nos motor, how much hp NA would you have to make to go the same time in the quarter.
A 700 hp NA motor will go the same exact time as a 700 hp NOS motor if the power curve is equal.
If the power curve is different between the motors then you have a more difficult question to answer. In that case it will depend on gearing, aero, traction, chassis setup, etc.
And that's just it, The power curve will be different and wider on the NOS motor. Take advantage of that with a lower stall and a NA motor would need more HP to make up for that. How much, there will be no one solid answer, just depends.
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1857663
06/26/15 08:32 PM
06/26/15 08:32 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Properly geared and with right converter........700hp is 700hp and should run the same in the same car.
Nitrous does ONE thing, it allows you to burn more fuel, which makes more power. So a 700hp N/A motor and a 500hp motor with a 200hp shot are doing the SAME thing.
As far as torque...........that's why we have these things called "torque converters"...........LOL!!
Re: How much NA HP to equal NOS HP [Re: Monte_Smith] #1857975
06/27/15 03:28 AM
06/27/15 03:28 AM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Interesting, Mike Thermos thinks that you have more area under the curve and the nitrous car would be faster. I was just throwing this out there.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858139
06/27/15 02:02 PM
06/27/15 02:02 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Would seem to me that if an engine made 700 hp continuously over a wide range of rpm(let's say from 3000 to 7000 rpm) that it would be faster in a quarter mile than an engine that makes 700 hp at finally at say 7000 rpm only.
Isn't this why electric motor power vehicles are so quick,,,,peak torque begins at zero rpm?
Therefore if using or not using nitrous,,,,all the the numbers might change the quarter mile et's and mph based upon rather or not nitrous(or super or turbo chargers) were part of the formula, even if peak hp of each combination remained at 700 hp.
Some of you into HI Fi systems recall that an amp rated at peak 200 watts performs far differently driving low efficiency speakers than one that produces 200 watts over a wide range of frequencies.
I have no idea of all this, just wondering.
When does the ground war begin!
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858175
06/27/15 02:47 PM
06/27/15 02:47 PM
AndyF Offline
AndyF  Offline
Sure, that might be true but like I said before, it gets complicated. You have to get all of that extra area under the curve to the track which might be difficult. Too much power down low and the car won't hold it. Transmission gearing also becomes important when you compare a peaky powerband to a broad powerband.
The combination is always more important than one particular number.
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858233
06/27/15 04:22 PM
06/27/15 04:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2
And there will be an advantage to a car with only 2 or 3 gears (vs. 4 or 5): the big RPM drop on shifting won't be as important.
Boffin Emeritus
Re: How much NA HP to equal NOS HP [Re: polyspheric] #1858641
06/28/15 12:38 AM
06/28/15 12:38 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Since HP is derived from tq/time, an equal hp is an equal hp. If you can get a power curve from a nitrous engine and an equal power curve from a n/a engine, and they weigh the same, the e.t mph will be the same. An Allison engine making 1000 hp will make more power in the curve than a 1000 hp nitrous car engine. A n/a bbc that makes 700 hp will have more power and tq than a 700 hp nitrous turbo'ed rotary trough the power band.
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858663
06/28/15 01:37 AM
06/28/15 01:37 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
So let's say you take a 440 with decent heads, cam, and carb and fuel delivery and put a 200 shot on it to get to 700 HP, everyone would probably agree that is doable.
But could you take something more anemic with a tiny cam and restricted heads like a bone stock 318 with 230 HP, upgrade the fuel system and throw a 200 shot at it to get 430 HP?
There's got to be some point where it doesn't work right? Where is that point? I mean you can't put a 200 shot on a 3 HP Briggs and Stratton motor and get 203 HP right?
What does the baseline motor have to be for the 200 shot to more or less actually equal close to 200 extra horsepower when given a 200 HP shot.
Maybe this is what the OP was asking?
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858665
06/28/15 02:03 AM
06/28/15 02:03 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I am of the belief that the less efficient a motor is to start with, the more nitrous will help it.
On my 232 a 150 shot picked it up about 2.5 seconds and 14 mph in the quarter. Pretty sure it won't do that on a 632.
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858681
06/28/15 03:10 AM
06/28/15 03:10 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Hilarious what some peoples concept of what "power" is.
You can have 1000 ft/lbs of torque and 0 HP.
It's I M P O S S A B L E to make 1000 HP and 0 ft/lbs of torque.
A 700 HP NOS motor that makes 600 ft/lbs at 4000 RPM is making more POWER than a 700 HP N/A that is making 500 ft/lbs at 4000 RPM.
An engine makes torque - a calculator makes HP. Period.
A 700 peak HP engine - 500 engine/200 NOS should have more torque under peak HP and should be quicker than a 700 HP N/A engine, unless you have a converter that stalls about 50 RPM under peak HP. You should be able to run a tighter, more efficient converter and take advantage of the extra torque below the peak HP.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858890
06/28/15 02:26 PM
06/28/15 02:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"1000 ft/lbs of torque and 0 HP"
Electric motor or steam engine stalled at 0 RPM.
Boffin Emeritus
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858891
06/28/15 02:28 PM
06/28/15 02:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The "point of diminishing returns" with a small engine is where the exhaust valve and port won't flow the volume.
Boffin Emeritus
Re: How much NA HP to equal NOS HP [Re: polyspheric] #1858921
06/28/15 03:17 PM
06/28/15 03:17 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Correct. An engine that hits that point the earliest in it's power curve, as in a NOS engine that has more torque at lower RPM's, will make the max power for a broader RPM range. For example, a N/A engine may only "max out" the exhaust port from 6500-7000, where the NOS one may do it from 4500-7000, making more average "power".
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1858972
06/28/15 04:43 PM
06/28/15 04:43 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
900 NA HP = 20,000$ 900 N20 HP =9,000$
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: How much NA HP to equal NOS HP [Re: MoparBilly] #1859099
06/28/15 08:10 PM
06/28/15 08:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
900 hp NOS motor after going a tad lean just one time $18000, hood blown off from backfire, sturdier drive train (converter, trans, drives-haft, upgrade to 9 inch because them are the most awesome rear known to man rolleyes )to handle the extra TQ $$$... it may end up cheaper but it is not as easy or cheap as just hanging a hose from the bottle to the air cleaner and certainly not as fun having to go get the special sauce all the time in my opinion. Also a lot more hoses and wires running all around under your hood and that just annoys me.
Re: How much NA HP to equal NOS HP [Re: 1967dartgt] #1859242
06/28/15 10:42 PM
06/28/15 10:42 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
So how much more hp would you have to make NA to equal a NOS engine?
Easily understood question, but hard to give an accurate answer as to the additional hp needed. Seeing how no engine stays at peak hp as it accelerates through it's power curve on the track, one peak hp number doesn't determine performance, the average hp in the rpm range your engine sees as it runs down the track will.
Seeing how a N2O engine will produce a larger avg. hp in the rpm range your engine sees as it runs down the track, yet may have the same peak hp, it will out-accelerate the N/A engine.
Re: How much NA HP to equal NOS HP [Re: HotRodDave] #1859447
06/29/15 02:01 AM
06/29/15 02:01 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Got any more using nitrous clichés you want to throw in there. I think you missed a few
