Re: How much NA HP to equal NOS HP
[Re: AndyF]
#1857659
06/26/15 08:30 PM
06/26/15 08:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
If you have a 700 hp nos motor, how much hp NA would you have to make to go the same time in the quarter. A 700 hp NA motor will go the same exact time as a 700 hp NOS motor if the power curve is equal. If the power curve is different between the motors then you have a more difficult question to answer. In that case it will depend on gearing, aero, traction, chassis setup, etc. And that's just it, The power curve will be different and wider on the NOS motor. Take advantage of that with a lower stall and a NA motor would need more HP to make up for that. How much, there will be no one solid answer, just depends.
[Re: 1967dartgt]
#1857663
06/26/15 08:32 PM
06/26/15 08:32 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Properly geared and with right converter........700hp is 700hp and should run the same in the same car.
Nitrous does ONE thing, it allows you to burn more fuel, which makes more power. So a 700hp N/A motor and a 500hp motor with a 200hp shot are doing the SAME thing.
As far as torque...........that's why we have these things called "torque converters"...........LOL!!
[Re: Monte_Smith]
#1857975
06/27/15 03:28 AM
06/27/15 03:28 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
As far as torque...........that's why we have these things called "torque converters"...........LOL!! Interesting, Mike Thermos thinks that you have more area under the curve and the nitrous car would be faster. I was just throwing this out there.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1858139
06/27/15 02:02 PM
06/27/15 02:02 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Would seem to me that if an engine made 700 hp continuously over a wide range of rpm(let's say from 3000 to 7000 rpm) that it would be faster in a quarter mile than an engine that makes 700 hp at finally at say 7000 rpm only.
Isn't this why electric motor power vehicles are so quick,,,,peak torque begins at zero rpm?
Therefore if using or not using nitrous,,,,all the the numbers might change the quarter mile et's and mph based upon rather or not nitrous(or super or turbo chargers) were part of the formula, even if peak hp of each combination remained at 700 hp.
Some of you into HI Fi systems recall that an amp rated at peak 200 watts performs far differently driving low efficiency speakers than one that produces 200 watts over a wide range of frequencies.
I have no idea of all this, just wondering.
When does the ground war begin!
[Re: 1967dartgt]
#1858175
06/27/15 02:47 PM
06/27/15 02:47 PM
Posts: 31,082 Oregon
AndyF
As far as torque...........that's why we have these things called "torque converters"...........LOL!! Interesting, Mike Thermos thinks that you have more area under the curve and the nitrous car would be faster. I was just throwing this out there. Sure, that might be true but like I said before, it gets complicated. You have to get all of that extra area under the curve to the track which might be difficult. Too much power down low and the car won't hold it. Transmission gearing also becomes important when you compare a peaky powerband to a broad powerband. The combination is always more important than one particular number.
[Re: 1967dartgt]
#1858233
06/27/15 04:22 PM
06/27/15 04:22 PM
Posts: 4,213 New York
polyspheric
New York
X2 And there will be an advantage to a car with only 2 or 3 gears (vs. 4 or 5): the big RPM drop on shifting won't be as important.
Boffin Emeritus
[Re: polyspheric]
#1858641
06/28/15 12:38 AM
06/28/15 12:38 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Since HP is derived from tq/time, an equal hp is an equal hp. If you can get a power curve from a nitrous engine and an equal power curve from a n/a engine, and they weigh the same, the e.t mph will be the same. An Allison engine making 1000 hp will make more power in the curve than a 1000 hp nitrous car engine. A n/a bbc that makes 700 hp will have more power and tq than a 700 hp nitrous turbo'ed rotary trough the power band.
[Re: 1967dartgt]
#1858665
06/28/15 02:03 AM
06/28/15 02:03 AM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
I am of the belief that the less efficient a motor is to start with, the more nitrous will help it.
On my 232 a 150 shot picked it up about 2.5 seconds and 14 mph in the quarter. Pretty sure it won't do that on a 632.
[Re: 1967dartgt]
#1858681
06/28/15 03:10 AM
06/28/15 03:10 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Hilarious what some peoples concept of what "power" is.
You can have 1000 ft/lbs of torque and 0 HP.
It's I M P O S S A B L E to make 1000 HP and 0 ft/lbs of torque.
A 700 HP NOS motor that makes 600 ft/lbs at 4000 RPM is making more POWER than a 700 HP N/A that is making 500 ft/lbs at 4000 RPM.
An engine makes torque - a calculator makes HP. Period.
A 700 peak HP engine - 500 engine/200 NOS should have more torque under peak HP and should be quicker than a 700 HP N/A engine, unless you have a converter that stalls about 50 RPM under peak HP. You should be able to run a tighter, more efficient converter and take advantage of the extra torque below the peak HP.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 1967dartgt]
#1858890
06/28/15 02:26 PM
06/28/15 02:26 PM
polyspheric
New York
"1000 ft/lbs of torque and 0 HP"
Electric motor or steam engine stalled at 0 RPM.
Boffin Emeritus
[Re: 1967dartgt]
#1858891
06/28/15 02:28 PM
06/28/15 02:28 PM
polyspheric
New York
The "point of diminishing returns" with a small engine is where the exhaust valve and port won't flow the volume.
Boffin Emeritus
[Re: polyspheric]
#1858921
06/28/15 03:17 PM
06/28/15 03:17 PM
Evil Spirit
Newport, Mi
The "point of diminishing returns" with a small engine is where the exhaust valve and port won't flow the volume. Correct. An engine that hits that point the earliest in it's power curve, as in a NOS engine that has more torque at lower RPM's, will make the max power for a broader RPM range. For example, a N/A engine may only "max out" the exhaust port from 6500-7000, where the NOS one may do it from 4500-7000, making more average "power".
[Re: 1967dartgt]
#1858972
06/28/15 04:43 PM
06/28/15 04:43 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
900 NA HP = 20,000$ 900 N20 HP =9,000$
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1859099
06/28/15 08:10 PM
06/28/15 08:10 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
900 NA HP = 20,000$ 900 N20 HP =9,000$ 900 hp NOS motor after going a tad lean just one time $18000, hood blown off from backfire, sturdier drive train (converter, trans, drives-haft, upgrade to 9 inch because them are the most awesome rear known to man ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) )to handle the extra TQ $$$... it may end up cheaper but it is not as easy or cheap as just hanging a hose from the bottle to the air cleaner and certainly not as fun having to go get the special sauce all the time in my opinion. Also a lot more hoses and wires running all around under your hood and that just annoys me.
[Re: 1967dartgt]
#1859242
06/28/15 10:42 PM
06/28/15 10:42 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
So how much more hp would you have to make NA to equal a NOS engine? Easily understood question, but hard to give an accurate answer as to the additional hp needed. Seeing how no engine stays at peak hp as it accelerates through it's power curve on the track, one peak hp number doesn't determine performance, the average hp in the rpm range your engine sees as it runs down the track will. Seeing how a N2O engine will produce a larger avg. hp in the rpm range your engine sees as it runs down the track, yet may have the same peak hp, it will out-accelerate the N/A engine.
[Re: HotRodDave]
#1859447
06/29/15 02:01 AM
06/29/15 02:01 AM
Monte_Smith
North Alabama
900 NA HP = 20,000$ 900 N20 HP =9,000$ 900 hp NOS motor after going a tad lean just one time $18000, hood blown off from backfire, sturdier drive train (converter, trans, drives-haft, upgrade to 9 inch because them are the most awesome rear known to man ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) )to handle the extra TQ $$$... it may end up cheaper but it is not as easy or cheap as just hanging a hose from the bottle to the air cleaner and certainly not as fun having to go get the special sauce all the time in my opinion. Also a lot more hoses and wires running all around under your hood and that just annoys me. Got any more using nitrous clichés you want to throw in there. I think you missed a few
