Re: MUSCLE MOTORS 30 MIN ENGINE
[Re: steve660]
#1856898
06/25/15 07:18 PM
06/25/15 07:18 PM
Posts: 4,213 New York
polyspheric
New York
If i did send it to them they would find something to charge me for and if i dont pay they got the engine...thats what i have to lose. And i dont know if what they repair would be the right way.
X2 Seen this happen with cars and bikes for 50 years. Not addressing MM specifically, but in the past once a shop has the engine back, the clock stops - it won't get any work unless they stop booking new work - the same reason it didn't get done on time. They'll find something wrong that's your fault and you have to ransom the engine back.
I noticed that MM's remarks didn't address all the issues you raised - like 150 psi at 12:1 CR...
Boffin Emeritus
[Re: steve660]
#1856899
06/25/15 07:18 PM
06/25/15 07:18 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
It's a shame that bad news travel so fast when there are so many variables in performance motors. I would buy it and have it fixed if I didn't have so many motors already. I have a hemi built by Muscle motor and a wedge built by Best machine and a couple of others that are all good motors. Things can happen to any of these motor due to the variables. Most the time with any of these reputable builder they are fine when the leave. I would sure HATE to be a builder and have somebody put a motor in their car with the issues that can arise like oil, filter, timing, fuel, fuel systems, crank thrust from spacing the convertor wrong and so on!
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: steve660]
#1856900
06/25/15 07:20 PM
06/25/15 07:20 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Guess the point is the motor had less oil pressure than you think it should have, but was that something talked about during the build? I agree I might want a bit more but that does not mean necessarily it is bad. I do agree the valve issue certainly needs fixing, should not have happened but perhaps it is something that got overlooked, or could be a parts issue. Assuming you have not had it torn down to determine the exact cause of course, as I did not see that it had been. But you yourself admit you have not run it at all much really, and while we can all speculate and be skeptical about the power numbers is made you do not have anything to show different. Just trying to play a little devils advocate here..
[Re: steve660]
#1856938
06/25/15 07:50 PM
06/25/15 07:50 PM
Posts: 791 Bama
Randy..
Bama
[Re: steve660]
#1856940
06/25/15 07:52 PM
06/25/15 07:52 PM
Al_Alguire
Las Vegas
I have no dog in this fight at all but I don't know what else Mike and MM can do to try and make this right honestly.
[Re: steve660]
#1856975
06/25/15 08:51 PM
06/25/15 08:51 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time.
[Re: rickraw]
#1856987
06/25/15 09:04 PM
06/25/15 09:04 PM
Posts: 13,616 md
mopars4ever
md
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time. I agree plus your not talking about a couple bucks here. That is a lot of money in my book for it not to be done correctly the first time. Trust is a major issue here from what I see.
[Re: rickraw]
#1857011
06/25/15 09:28 PM
06/25/15 09:28 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
Now that is what I call standing up. Way to go Mike. If the op doesn't take that offer, hate to say it, he is an a-hole. well they did a predator head motor for me that couldn't fall out of a tree. the back yard mechanic of me tore it down and found the valves hitting the pistons and the pistons hitting the head. after alot of help from boat racer I had some one else notch the pistons and cutting them for clearance on the head. put it back together myself and it picked up 6 miles an hour in the 1/8. mike offered for me to send it back but after everything I had been through just to get it hell no they had there chance. I had bought a ton of stuff through them before this.
[Re: steve660]
#1857123
06/25/15 11:17 PM
06/25/15 11:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
There is not an engine builder alive, that hasn't at one time or another, let something slip through the cracks........... So let them fix it for free and move on, or don't, then take a huge loss parting it out, or PAY someone else to fix it. Seems to be your choices. I think I would try the FREE one first.
Stuff happens. I built a motor for a member on this board. Took me WAY too long to get it done, but when it was, I ran it on the dyno and it make good power, was sealed up good, made good vacumn, no blowby. He gets it in the car, makes a few passes and it is oiling a plug....BAD. Checks the usual things, so we narrow it to the rings. I send him some rings for that hole, puts it back together, no change. Now by this time, he is pretty darned upset with me. I offered to have it shipped down at my cost and have a look, but he elects to have somebody else look at it. I tell him, if it is something I did wrong, we will TALK about the bill, but I won't guarantee anything...........Well turns out the head developed a crack where it was ported so thin, by another VERY well known and VERY respected Mopar guy on a previous build and was oiling the cylinder. So as I said, ANYTHING can happen to ANYBODY.
[Re: MuscleMike]
#1857141
06/25/15 11:31 PM
06/25/15 11:31 PM
Posts: 289 Lowes
steve660
Lowes
All I want is for Mr. Edwards to be enjoying his car. That being said, you don't buy something from Home Depot, have an issue and take it to Lowes to have it fixed and send Home Depot the bill. Obviously We are under a micro scope and it is in our best interest to bring this situation to a speedy conclusion. For the record: I, Michael Ware, owner of Muscle Motors will bring the engine back here, replace the bent valve, verify and adjust guide clearance if necessary.
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: B3422W5]
#1857154
06/25/15 11:42 PM
06/25/15 11:42 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time. No worse than selling someone a car that is not 100% to their expectations. You offer for them to bring it back so you can determine what the issues are and they have already decided the trust is not there.
[Re: steve660]
#1857202
06/26/15 01:12 AM
06/26/15 01:12 AM
Monte_Smith
North Alabama
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams. I'm not sure why you seem so concerned about the cylinder pressure issue. Not sure where you think it needs to be, but this is a big motor, with a very efficient head, that is going to run on pump gas. Lots of pumping pounds will NOT be your friend
