Re: Horsepower on stock Hemi block
[Re: mprhound]
#1930470
10/11/15 10:23 PM
10/11/15 10:23 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
That block has got to be heavy as a mack truck. Looks like you could punch it out to 4.5 and save a lot of weight.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: mprhound]
#1931337
10/13/15 12:23 PM
10/13/15 12:23 PM
Posts: 3,505 DFW
mr_340
DFW
Jimi, did your marine blocks come with the Hemi caps and machined for the side bolts? I have a marine block and it has the bosses cast into the insides of the pan rail, but it is not machined for side bolts and has regular caps on it. Mine doesn't have a casting number on it anywhere.
Did you run those blocks in SS with a MW? I was wondering if the side bolts would be legal in SS on a MW engine?
Floyd Lippencott IV
[Re: mprhound]
#1933623
10/17/15 01:22 AM
10/17/15 01:22 AM
Posts: 3,505 DFW
mr_340
DFW
I believe that was the fueler block cast only in 1970. They were supposed to have beefier features than a regular Street Hemi block, maybe had the pearlitic iron main caps, etc. I'd have to dig out the old white DC book to read up on that block.
Floyd Lippencott IV
[Re: ScottSmith_Harms]
#1933788
10/17/15 02:18 PM
10/17/15 02:18 PM
Posts: 81 Sweden
MikeN
Sweden
This should be the D5 block with extra space for pushrods (because of the D5 valve angle). See attached pics (red block has cast no 3577430-2) and compare with the repro MP hemi block. Regarding the difference in casting number (-1 and -2) see http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm .
[Re: mr_340]
#1933906
10/17/15 08:21 PM
10/17/15 08:21 PM
Posts: 428 wappinger falls new york
Jimi_Vignogna
Did you run those blocks in SS with a MW? I was wondering if the side bolts would be legal in SS on a MW engine? only one had hemi caps the others had provisions but regular caps, yes you can use the "hemi" cap block in stock.
[Re: mprhound]
#1939150
10/26/15 08:20 PM
10/26/15 08:20 PM
Hemi_Joel
Minnesota
mprhound, did you ever get that block onto a scale? I'm guessing 275#
[Re: Hemi_Joel]
#1939415
10/27/15 01:12 AM
10/27/15 01:12 AM
Posts: 409 Texas
mprhound
Texas
mprhound, did you ever get that block onto a scale? I'm guessing 275# Not yet, in the middle of finishing a new house. So the cars got put on hold for a bit until I finish the move. Took the block to my machinist, one less thing to move.
[Re: mprhound]
#1939462
10/27/15 04:21 AM
10/27/15 04:21 AM
Posts: 345 Nebraska
451Cuda
Nebraska
I ask because I have a factory block that the bottom end is cross bolted and just like a Hemi but it is wedge top end. It has never been used , still at 4.25 bore. The consensus of the people I have asked and talked to is that it is an ex factory cast nascar block. I am going to build a stroker out of it 4.50 stroke crank. I am going to put it my challenger for drag week. And was just wondering how much more this bottom end will take over the standard 2 bolt main block Is that block worth something to someone doing a vintage Nascar restoration? I'd look into that, try to get enough to buy a modern race block.
[Re: mprhound]
#1939767
10/27/15 05:38 PM
10/27/15 05:38 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
I ask because I have a factory block that the bottom end is cross bolted and just like a Hemi but it is wedge top end. It has never been used , still at 4.25 bore. The consensus of the people I have asked and talked to is that it is an ex factory cast nascar block. I am going to build a stroker out of it 4.50 stroke crank. I am going to put it my challenger for drag week. And was just wondering how much more this bottom end will take over the standard 2 bolt main block Basically a Mega block then? Or a different casting altogether?
