Re: If you change from an 8¼" to an 8¾" rearend in a '69 Charger
[Re: MaximRecoil]
#1855198
06/23/15 02:43 PM
06/23/15 02:43 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I would do the change and see if you can have your driveshaft shoten locally ![work work](/ubbthreads/images/graemlins/custom/work.gif) I'm almost sure that the 8 3/4 pinion yoke sticks out further, its longer, than the 8 1/4 does ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Let us know what you do ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) BTW, you may have a 7 1/4 instead of the 8 1/4 ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: John_Kunkel]
#1855274
06/23/15 04:08 PM
06/23/15 04:08 PM
RapidRobert
find the correct donor shaft for your rear axle & if you have one cut mockup so you can get an exact/correct C to C number (I like 5/8-3/4" end play) loaded/level. Wouldn't hurt to check the end play of a donor shaft during installation also
[Re: MaximRecoil]
#1855284
06/23/15 04:21 PM
06/23/15 04:21 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
According to the chart it's about 5.8" too long.
The factory yoke to seal clearance is WAY too generous in every application I've seen. There is often more than 1.5" of clearance and 3/4" is plenty for a leaf sprung car.
I'd recommend installing the old driveshaft and checking yoke to seal clearance before you cut anything. If there is 3/4" or more, it will be fine. As long as it doesn't bottom out, the more spline engagement, the better.
[Re: Magnum]
#1855309
06/23/15 04:54 PM
06/23/15 04:54 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You mean 5/8" right? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) If there is no dust boot on the transmission you could probably get away with the shaft you now have.
[Re: Magnum]
#1855310
06/23/15 04:54 PM
06/23/15 04:54 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
According to the chart it's about 5/8" too long.
Fixed... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Edited for getting TREED!!!!!!!
...FAFO...
[Re: Cab_Burge]
#1855383
06/23/15 06:35 PM
06/23/15 06:35 PM
Posts: 19 Maine
MaximRecoil
Maine
BTW, you may have a 7 1/4 instead of the 8 1/4 It is definitely an 8¼" rearend. I thought the 8-1/4 didn't come out till late 70 early 71. Don't remember ever seeing a Charger-Coronet with anything but an 8-3/4 in 69. I changed out quite a few carrier bearings after that time from defects in the 8-1/4. In fact I can't remember seeing any in the 71-72 Charger just the 4-door Coronets. 1973 up, a-b-c base models 8-1/4, e-body 8-3/4. Could be wrong been awhile. Unfortunately, a lot of 318 '69 Chargers came with a 904 transmission and an 8¼" rearend like mine did, rather than a 727 and 8¾". The changeover seems to have happened at some point during the 1969 model year. I asked about this a couple of years ago on another forum: http://www.dodgecharger.com/forum/index.php?topic=104494.0According to the chart it's about 5.8" too long.
You mean 5/8" right? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) If there is no dust boot on the transmission you could probably get away with the shaft you now have. Thanks for the chart. I assumed there would be some difference in length; I just didn't know if it would be enough to matter.
[Re: cudaman1969]
#1855464
06/23/15 08:14 PM
06/23/15 08:14 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I thought the 8-1/4 didn't come out till late 70 early 71. Don't remember ever seeing a Charger-Coronet with anything but an 8-3/4 in 69. I changed out quite a few carrier bearings after that time from defects in the 8-1/4. In fact I can't remember seeing any in the 71-72 Charger just the 4-door Coronets. 1973 up, a-b-c base models 8-1/4, e-body 8-3/4. Could be wrong been awhile. I had several 318 69 chargers with the 8 1/4 axle.
[Re: MaximRecoil]
#1855475
06/23/15 08:27 PM
06/23/15 08:27 PM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
"Unfortunately, a lot of 318 '69 Chargers came with a 904 transmission and an 8¼" rearend like mine did, rather than a 727 and 8¾". The changeover seems to have happened at some point during the 1969 model year. I asked about this a couple of years ago on another forum:"
Well that's what I like about this forum, never too old to learn something new. What a bummer by the way, couldn't see Dodge doing that to a great car just to save a few bucks.
[Re: Alaskan_TA]
#1855476
06/23/15 08:33 PM
06/23/15 08:33 PM
Posts: 19 Maine
MaximRecoil
Maine
The 8 1/4" rear was a new addition for some 1969 model year cars. That's right: ![](http://i.imgur.com/nJdSFsj.jpg)
[Re: dogdays]
#1856001
06/24/15 04:12 PM
06/24/15 04:12 PM
cudaman1969
fredericksburg,va
If you save $5 on 100,000 cars it's a half-million. Every car manufacturer does the math.
R. They didn't sell 100,000 Chargers total but I know where you're coming from, dad worked at Fisher Body-Buick division in the 50s and said they would look for a haft cent to save.. In retrospect I don't think you could get the 904 with anything but the base rears. Upgrade the rear and this got the 727 I guess. Got two Dusters, one is 3 on the tree 6 cyl-7-1/4, other is synchronized 3 speed 6 cyl-8-3/4 so I'm thinking packages. Question for the group, where there any 318-904 mated to the 8-3/4 or just the 318-727 from 66-68 in the big cars- b&c bodys?
[Re: cudaman1969]
#1856022
06/24/15 04:40 PM
06/24/15 04:40 PM
Posts: 19 Maine
MaximRecoil
Maine
Question for the group, where there any 318-904 mated to the 8-3/4 or just the 318-727 from 66-68 in the big cars- b&c bodys? In the thread I linked to earlier, someone posted: I have owned several 1968 and 1969 Chargers that were factory 318 cars. All had a 8 3/4 rear end and 904 transmission. I don't know if he intended to type 8¾ instead of 8¼ or not.
[Re: cudaman1969]
#1856066
06/24/15 06:12 PM
06/24/15 06:12 PM
skicker
"The Champ"
"The Champ"
Western Md.
Question for the group, were there any 318-904 mated to the 8-3/4 or just the 318-727 from 66-68 in the big cars- b&c bodys? I sold a 68 Coronet 440 h/t a couple years ago that was 318-904-8 3/4... ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
...FAFO...
