Question about factory tach in my '93 Dakota.....
#1856335
06/25/15 12:53 AM
06/25/15 12:53 AM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
Is it common for them to die or work erratically? What controls them? Reason for asking, I'm noticing how my truck runs in relation to the tach. When the tach is basically flat line or off in la-la land, the truck seems sluggish, almost like I'm riding with the e-brake on. If the tach is working somewhat correctly, the truck has snap, and accelerates quickly. Am I imagining things or is there a correlation between the two?
John
Re: Question about factory tach in my '93 Dakota.....
[Re: SattyNoCar]
#1857096
06/25/15 10:59 PM
06/25/15 10:59 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I think those gauge clusters even date back before the Dakota? If I remember, the same cluster was used in Dodge Lancers and LeBarons. Parts bin engineering.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1857727
06/26/15 10:06 PM
06/26/15 10:06 PM
SattyNoCar
In Lancers, is the speedometer mechanical or electrical?
John
[Re: 79powerwagon]
#1858080
06/27/15 12:28 PM
06/27/15 12:28 PM
SattyNoCar
While I haven't confirmed it, I read somewhere that '93 was the last year for mechanical speedometers in Dakotas (which is what mine has). The pic of the Lancer dash also emphasizes just how blown out and faded the gauge assembly is in my truck...
John
[Re: SattyNoCar]
#2261272
02/28/17 09:00 PM
02/28/17 09:00 PM
Posts: 1,680 Raleighwood
2Bad360sfromNC
Raleighwood
I found this old thread while I'm searching for something else, but I have the solution. The tach on my '91 Dak was usually at 2,000 rpm forever, but sometimes zero, and sometimes whipping around like crazy. At least with it doing that, I knew the little motor inside the tach still worked. A couple weeks ago I took the dash apart and greased the speedometer cable, and while I was in there, I popped the circuit board for the tach off to see if I could fix it. This also works on old Daytonas that have a similar setup. The board is about 2 or 3 inches square and is on top of the cluster over the tach. Just lift the back of it off the main circuit board and then slide it towards the front of the vehicle (as the cluster would be installed). Look at all the solder joints. Sometimes you can actually see a cracked joint, but sometimes you just see a tiny divot in them. Fire up your soldering iron and reflow any and all questionable looking joints on the board. Make sure you don't use acid core solder. I'm not sure what the best kind would be, but I know acid core ain't it. Install the tach board back onto the cluster and put the dash back together. If none of the actual components were bad, your tach should be back in business.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D) 1974 Challenger 360 2012 Challenger R/T 1991 Dakota 5.2
[Re: SattyNoCar]
#2261411
03/01/17 12:42 AM
03/01/17 12:42 AM
Posts: 2,275 ILLINOIS
volaredon
ILLINOIS
well I know taht up til (and including) 93, the Dakotas were mechanical and 94-up are electronic. the 93-older have a speed sensor with a 2 wire plug for the computer AND a thread on fitting for the cable, 94+ they eliminated the cable drive. If you see the 2 right next to one another you can tell a slightly different "font" to the odometer digits between them. I have had 89, 90, 92 (still do) 93 (miss that one, it was a 5 speed truck) 94, and 96 (just bought, this one's 4X4) Dakotas. so I can tell from what I remember that mine have had. (unless it's a 4 banger) 93 was also last yr for 2 line (feed/return) fuel system and also last yr for inline fuel filter. I have to look, I know I still have a good 94/95 computer for a V6, MIGHT still have a 93 one. Not saying that's your issue but just mentioning just in case....
