Re: Cooling again...Electric water pump GPM for street
[Re: Thumperdart]
#1857286
06/26/15 10:18 AM
06/26/15 10:18 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Been running the drop in Moroso for years and they don`t give flow numbers but "claim" 33% more flow than the competitors..... Yup, if you new what the starting number was, the "33% more" would be much more relevent for sure. It does make good advertising tho........... I pulled the restrict-or out for giggles and only gained about a 1/4" going from the 1" gutted t-stat to the 1 1/4" t-stat housing. Think it will make a difference? Sorry to hi-jack................. Only one way to find out. Take her for a 30 minute bumper to bumper crawl on one of those California freeways!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1857349
06/26/15 12:34 PM
06/26/15 12:34 PM
Thumperdart
State of confusion
Been running the drop in Moroso for years and they don`t give flow numbers but "claim" 33% more flow than the competitors..... Yup, if you new what the starting number was, the "33% more" would be much more relevent for sure. It does make good advertising tho........... I pulled the restrict-or out for giggles and only gained about a 1/4" going from the 1" gutted t-stat to the 1 1/4" t-stat housing. Think it will make a difference? Sorry to hi-jack................. Only one way to find out. Take her for a 30 minute bumper to bumper crawl on one of those California freeways! Now it`s Vegas freeways and it`s WAY hotter here than the high desert I left............... Will take a putt later after the silicone cures.
[Re: Thumperdart]
#1857355
06/26/15 12:41 PM
06/26/15 12:41 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Now it`s Vegas freeways and it`s WAY hotter here than the high desert I left............... Will take a put later after the silicone cures. Sorry, I forgot you had moved to Lost Wages. My 318/390 stroker's cooling is marginal, so I pulled the t-stat out last night, too. I'm taking it out for a drive tomorrow to see what difference it makes.
[Re: DusterDave]
#1857359
06/26/15 12:48 PM
06/26/15 12:48 PM
Thumperdart
State of confusion
Not a gambler so no 'lost wages"for me......................
[Re: Thumperdart]
#1857365
06/26/15 12:58 PM
06/26/15 12:58 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Not a gambler so no 'lost wages"for me...................... I said that tongue in cheek, not directed towards you personally.
[Re: Thumperdart]
#1857367
06/26/15 01:05 PM
06/26/15 01:05 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Been running the drop in Moroso for years and they don`t give flow numbers but "claim" 33% more flow than the competitors..... Yup, if you new what the starting number was, the "33% more" would be much more relevent for sure. It does make good advertising tho........... I pulled the restrict-or out for giggles and only gained about a 1/4" going from the 1" gutted t-stat to the 1 1/4" t-stat housing. Think it will make a difference? Sorry to hi-jack................. Dom, that 1/4" gave you about 35% more area for flow.
[Re: DusterDave]
#1857373
06/26/15 01:12 PM
06/26/15 01:12 PM
Thumperdart
State of confusion
Not a gambler so no 'lost wages"for me...................... I said that tongue in cheek, not directed towards you personally. No disrespect taken sir.............. Good to know Justin thankxx...............
[Re: sixpackgut]
#1857544
06/26/15 06:14 PM
06/26/15 06:14 PM
Thumperdart
State of confusion
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10* Started to wonder if this mod helps on the MP alum. housing cos there`s a good sized hole in there about 1/2" or bigger from what I saw.................
[Re: Thumperdart]
#1857555
06/26/15 06:27 PM
06/26/15 06:27 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10* Started to wonder if this mod helps on the MP alum. housing cos there`s a good sized hole in there about 1/2" or bigger from what I saw................. Tap drill size for a 3/8 NPT is 37/64, 0r .578.
[Re: DusterDave]
#1857587
06/26/15 07:13 PM
06/26/15 07:13 PM
Thumperdart
State of confusion
So is that a "Yes" on tapping and plugging it w/an 1/8th in hole in it?
[Re: sixpackgut]
#1857612
06/26/15 07:46 PM
06/26/15 07:46 PM
Thumperdart
State of confusion
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10* Ray, your pm`s are full homey.........................
[Re: Thumperdart]
#1857954
06/27/15 02:26 AM
06/27/15 02:26 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Hey Dom how have you been and liking your new place? Well seeing how its going to be a long time till i get my duster running and the dart is to fast to race with out a roll bar, looks like i am going to put it on the street. I have been using the summit electric drop in water pump that with the summit sticker removed is really a CVR water pump. Mine is rated at 30 GPM and i have also been using a gutted T-stat. I had it on the street one time last year and it did OK was in the low 90 and humid. the car did OK ran around 210 but would try and run a little warmer pulling a long hill. So i am going to try the trick you guys are talking about. I will be pulling my T-stat and installing a 3/8 pipe plug with a 1/8 hole. oh dumb question time,lol why cant you drill the 1/8 hole in the plug before you install it?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#1858065
06/27/15 11:58 AM
06/27/15 11:58 AM
Thumperdart
State of confusion
Hey Dom how have you been and liking your new place? Well seeing how its going to be a long time till i get my duster running and the dart is to fast to race with out a roll bar, looks like i am going to put it on the street. I have been using the summit electric drop in water pump that with the summit sticker removed is really a CVR water pump. Mine is rated at 30 GPM and i have also been using a gutted T-stat. I had it on the street one time last year and it did OK was in the low 90 and humid. the car did OK ran around 210 but would try and run a little warmer pulling a long hill. So i am going to try the trick you guys are talking about. I will be pulling my T-stat and installing a 3/8 pipe plug with a 1/8 hole. oh dumb question time,lol why cant you drill the 1/8 hole in the plug before you install it? The heat sukz but the 1/2 naked women and cold beer make up for it. Ya, 210 is more than I ever need to see again and we`ll soon see how it works and I drilled the plug FIRST then installed it......no drilling in the housing just ran a tap and it`s nice and tight. I`ll take street driving any day over racing and I have a street race w/one of the friends of Shawn from here who was on Oakie Outlaws last week in the colorful 55 Chevy. Apparently it`s a 468 rat w/a 300 shot in a late model mustang so again, I`m bringing a knife to a gun fight but have zero worries just like the last two power adder cars I beat...............
[Re: dart440_72]
#1858070
06/27/15 12:08 PM
06/27/15 12:08 PM
Posts: 1,532 off the grid
340B5
off the grid
Could the problem be elsewhere? I just put a 90A alternator on mine and now the voltage doesn't drop @idle so the fans spin faster and it cools better. I could reach 210 idling and now it stalls at 175 and maxed out at 180 after a long idle.
Yeah, it's got a smallblock.
[Re: 340B5]
#1858072
06/27/15 12:11 PM
06/27/15 12:11 PM
Thumperdart
State of confusion
I run a 70 amp denso alt. and have 14.5+ volts at idle and more above so for me I don`t see voltage as a problem but it definately could be if anyone`s voltage is below normal.............
[Re: Thumperdart]
#1858213
06/27/15 03:47 PM
06/27/15 03:47 PM
mopar65
Hey Dom how have you been and liking your new place? Well seeing how its going to be a long time till i get my duster running and the dart is to fast to race with out a roll bar, looks like i am going to put it on the street. I have been using the summit electric drop in water pump that with the summit sticker removed is really a CVR water pump. Mine is rated at 30 GPM and i have also been using a gutted T-stat. I had it on the street one time last year and it did OK was in the low 90 and humid. the car did OK ran around 210 but would try and run a little warmer pulling a long hill. So i am going to try the trick you guys are talking about. I will be pulling my T-stat and installing a 3/8 pipe plug with a 1/8 hole. oh dumb question time,lol why cant you drill the 1/8 hole in the plug before you install it? The heat sukz but the 1/2 naked women and cold beer make up for it. Ya, 210 is more than I ever need to see again and we`ll soon see how it works and I drilled the plug FIRST then installed it......no drilling in the housing just ran a tap and it`s nice and tight. I`ll take street driving any day over racing and I have a street race w/one of the friends of Shawn from here who was on Oakie Outlaws last week in the colorful 55 Chevy. Apparently it`s a 468 rat w/a 300 shot in a late model mustang so again, I`m bringing a knife to a gun fight but have zero worries just like the last two power adder cars I beat............... that's great to hear dom glad you like the move. My x wife was born in reading CA so when would go through Reno on our way there. Boy she was screwed when i found out on our first time through that they had a summit store.lol so any time we went guess wear we all ways stopped at.lol All so i almost got whiplash looking at all the pretty lady's.lol OK back to the water pump housing. you just taped the hole with it still mounted on the engine?
support our troops
[Re: 340B5]
#1858217
06/27/15 03:52 PM
06/27/15 03:52 PM
mopar65
Could the problem be elsewhere? I just put a 90A alternator on mine and now the voltage doesn't drop @idle so the fans spin faster and it cools better. I could reach 210 idling and now it stalls at 175 and maxed out at 180 after a long idle. i am sure it had to help. my dart when i had the factory alt couldn't keep up with the electric fans etc. I put a 120 amp denso AlT on it and now the fans etc run a lot better. after making a pass at the drag strip and driving back to the pits my car never got over 195 and with the water pump and fan on it would cool the engine down to 150 degrees in 10 minutes or less. also don't know if it makes a difference but when i raced the dart ti was through open exhaust and when i took it on its first street drive i had 3.5 exhaust on it.
support our troops
[Re: mopar65]
#1858218
06/27/15 03:55 PM
06/27/15 03:55 PM
Thumperdart
State of confusion
My neck STILL hurtzz.................... Ya, I used a socket on the end of the tap and went at it quick and easy...............
[Re: an8sec70cuda]
#1858311
06/27/15 06:39 PM
06/27/15 06:39 PM
mopar65
I ran the 45 gph Meziere for ever. One thing I did that helped is I tapped the hole in the housing under the thermostat. put a plug in it and drilled a 1/8th inch hole in the plug. that was good for about 10* And did the water just pour out or what? I think you stopped short in your explanation. The 45 gpm pump he's referring to is the drop-in pump that fits the stock housing (same one I have). There is a bypass hole underneath the thermostat in a stock housing. You tap it for 3/8" npt (no need to drill), put a pipe plug in it, then drill a 1/8" hole through the plug. This is def. worth doing...dropped mine about 10° also. It reduces the amount of hot water that's recirculated through the motor. could you post a part number for the one you have?
support our troops
