Re: Test and tune..... Broke it.....
[Re: B3422W5]
#1857333
06/26/15 11:56 AM
06/26/15 11:56 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Stripped axle or ring gear, doesn't matter. The engine/driveshaft rpm instantly went high when the axles stripped...it still "freewheeled". With stripped axles, the driveshaft wouldn't stop when the car did if there was enough RPM on the motor to power through it. There has to be something connecting the driveshaft to the tire...in this case, the axles were not, so the spool kept spinning but the axles didn't. Hope that makes sense..lol
[Re: B3422W5]
#1857434
06/26/15 03:07 PM
06/26/15 03:07 PM
an8sec70cuda
The driveshaft is still turning the pinion which is turning the ring gear/spool. The axle splines strip out so they slow down or stop as the car coasts, but the spool will keep going if you still have your foot in it. As soon as the splines stripped, the engine/trans/driveshaft/spool will "freewheel" b/c there's no load anymore. That's when the trans damage can occur.
He said when it broke the car pushed like it was in neutral all the time and wouldn't move under it's own power. It might as well have dropped the driveshaft, but it stripped the axle splines. Different location of the breakage, but same result.
[Re: B3422W5]
#1857518
06/26/15 05:45 PM
06/26/15 05:45 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Sorry to hear the news. I hate when stuff breaks! Hope you get it all sorted out asap.
2 kids and a dog
[Re: TonyS451]
#1857535
06/26/15 06:05 PM
06/26/15 06:05 PM
Thumperdart
State of confusion
Sorry to hear the news. I hate when stuff breaks! Hope you get it all sorted out asap. Same here, never good and I cringe everytime I romp on mine..............
