Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1856114
06/24/15 07:29 PM
06/24/15 07:29 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry to highjack but how much performance increase can be found with a drag cam?
I really dont know what i have in mine exept its a roller and most likely a nascar grind.
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1856290
06/24/15 11:52 PM
06/24/15 11:52 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Originally Posted By R5P7Duster
Compression wrecked Bobs engine due to the wrong rocker arm length? Or just the rocker length in general?
This engine was already running, I put over 2000 miles on it. Just refreshing everything now. Only change is a little less stroke and compression ratio.
Read post again. Compression had nothing to do with the exhaust valve breaking. The pistons were original NASCAR. One got trashed by the valve. He had new domes built for it. Sold car before assembling engine. I bought assembled and saw no increase in power. Mph is power. Others like Eatman, Arrigtin, EEI did not find power with domes.
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1856361
06/25/15 01:32 AM
06/25/15 01:32 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I would say it is easy to see why. That is a big knot in a tiny chamber, plus increased valve shrouding. Seldom do big honking domes make enough extra power to offset the amount they disrupt the flame front in chamber
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1856369
06/25/15 01:45 AM
06/25/15 01:45 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
So why does a w8 engine with big compression make power? Is it because the chamber is bigger? They are almost the same animal as a P7 engine.
I totally misread your post Leon, it makes sense now after reading both of your posts.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1856710
06/25/15 03:35 PM
06/25/15 03:35 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
A friend of mine work at Felix Sabats shop when nascar came in and said lower the compression to 12-1 from 14-1 when it was all said in done he said they maybe lost 20hp I'm not so sure your going to see a 80hp increase just by the Pistons best of luck with it
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: scottb] #1856872
06/25/15 06:55 PM
06/25/15 06:55 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Drag race W8 combos ran larger than 4.2 bore where you are 4.182". P7 valve angles are also different. The whole shape and design of a W8 drag race head is different.
I truly hope I am wrong. Hope you have the ticket. Just know my experience. Could have sold you 8 pistons. One you could test your welding talents on. Keeper scuffed it just a little LOL
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: Leon441] #1857229
06/26/15 03:11 AM
06/26/15 03:11 AM
Menomonee Falls
Menomonee Falls
That billet would weld up just fine. It's the cast aluminum and pot metals that are a MF'er to put a decent bead on.
I'd take a look at it if you wanted it fixed.
SDG Motorsports
Re: Custom billet BLING, diamond pistons for the R5 P7 [Re: DemonDust] #1857507
06/26/15 05:30 PM
06/26/15 05:30 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I don't plan to put them back. They made less lower. I might would weld the original billet flat top and put that set in. But, no.
Theses pistons have to much piston to wall clearance for drag race. New set is just too cheap. Then I can get a better for application ring pack to.
