Re: Horsepower on stock Hemi block [Re: mprhound] #1930096
10/11/15 11:11 AM
10/11/15 11:11 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Yes mine have ti valves, don't really like the valve cover arrangement. I thought about machining a plate so I could bolt on a regular big block valve cover and gasket
Re: Horsepower on stock Hemi block [Re: mprhound] #1930470
10/11/15 09:23 PM
10/11/15 09:23 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That block has got to be heavy as a mack truck. Looks like you could punch it out to 4.5 and save a lot of weight.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Horsepower on stock Hemi block [Re: mprhound] #1930528
10/11/15 10:49 PM
10/11/15 10:49 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
But almost hate taking out do big just to save weight? Need to weight it to see what it is
Still semi worried about the main web. It is bigger than the standard rb block but not as big as the 230 b block
Re: Horsepower on stock Hemi block [Re: rt66jim] #1931098
10/12/15 09:18 PM
10/12/15 09:18 PM
wappinger falls new york
Jimi_Vignogna Offline
that is actually a marine block, I have had a few over the years, never seen a new one. the mains are not usually the problem . if you look at the side of the block it has extra ribs cast into it like a marine block which 1st run hemi's did not have. our s/s hemi engines back in the day with stock blocks used to split down the outside length roughly 1 1/2" to 2 " below the deck. this block should not have a problem, it also seems to have much thicker walls according to the sonic test. does it have a casting date? I would also install main studs and have it line honed.
Re: Horsepower on stock Hemi block [Re: mprhound] #1931337
10/13/15 11:23 AM
10/13/15 11:23 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Jimi, did your marine blocks come with the Hemi caps and machined for the side bolts? I have a marine block and it has the bosses cast into the insides of the pan rail, but it is not machined for side bolts and has regular caps on it. Mine doesn't have a casting number on it anywhere.
Did you run those blocks in SS with a MW? I was wondering if the side bolts would be legal in SS on a MW engine?
Floyd Lippencott IV
Re: Horsepower on stock Hemi block [Re: mprhound] #1931341
10/13/15 11:34 AM
10/13/15 11:34 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
There are no casting dates or stamps on the block, on the front there is a 6 cast in the block that is it
Re: Horsepower on stock Hemi block [Re: mprhound] #1933068
10/16/15 06:31 AM
10/16/15 06:31 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I've got a set of Breweres, they have way smaller port window than B1 MC's I once had flowed in the same bench, and they flowed better. Perhaps not the worlds best heads, but should move the C-body once sorted out.
Plynouth VIP '67 TT IC EFI
Re: Horsepower on stock Hemi block [Re: jyrki] #1933470
10/16/15 08:42 PM
10/16/15 08:42 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Jyrki, have you got yours together yet? Made any passes? Thanks again for the cast brewer intake, you were correct, it is a wild peace!
Re: Horsepower on stock Hemi block [Re: mprhound] #1933548
10/16/15 10:59 PM
10/16/15 10:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Speaking of oddball Hemi blocks, have any of you seen one of these? Notice the casting number
Re: Horsepower on stock Hemi block [Re: mprhound] #1933623
10/17/15 12:22 AM
10/17/15 12:22 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I believe that was the fueler block cast only in 1970. They were supposed to have beefier features than a regular Street Hemi block, maybe had the pearlitic iron main caps, etc. I'd have to dig out the old white DC book to read up on that block.
Floyd Lippencott IV
Re: Horsepower on stock Hemi block [Re: ScottSmith_Harms] #1933788
10/17/15 01:18 PM
10/17/15 01:18 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
This should be the D5 block with extra space for pushrods (because of the D5 valve angle).
See attached pics (red block has cast no 3577430-2) and compare with the repro MP hemi block.
Regarding the difference in casting number (-1 and -2) see http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm .
Re: Horsepower on stock Hemi block [Re: mr_340] #1933906
10/17/15 07:21 PM
10/17/15 07:21 PM
only one had hemi caps the others had provisions but regular caps, yes you can use the "hemi" cap block in stock.
Re: Horsepower on stock Hemi block [Re: mprhound] #1939150
10/26/15 07:20 PM
10/26/15 07:20 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
mprhound, did you ever get that block onto a scale? I'm guessing 275#
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Horsepower on stock Hemi block [Re: mprhound] #1939413
10/27/15 12:06 AM
10/27/15 12:06 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would like to find a D-5 block to go with the heads and rockers I have.
2011 Drag Pak Challenger
Re: Horsepower on stock Hemi block [Re: Hemi_Joel] #1939415
10/27/15 12:12 AM
10/27/15 12:12 AM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Not yet, in the middle of finishing a new house. So the cars got put on hold for a bit until I finish the move. Took the block to my machinist, one less thing to move.
Re: Horsepower on stock Hemi block [Re: mprhound] #1939462
10/27/15 03:21 AM
10/27/15 03:21 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Originally Posted By mprhound
I ask because I have a factory block that the bottom end is cross bolted and just like a Hemi but it is wedge top end. It has never been used , still at 4.25 bore. The consensus of the people I have asked and talked to is that it is an ex factory cast nascar block. I am going to build a stroker out of it 4.50 stroke crank. I am going to put it my challenger for drag week. And was just wondering how much more this bottom end will take over the standard 2 bolt main block
Is that block worth something to someone doing a vintage Nascar restoration? I'd look into that, try to get enough to buy a modern race block.
Re: Horsepower on stock Hemi block [Re: mprhound] #1939725
10/27/15 03:09 PM
10/27/15 03:09 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Would trade for a modern 4.500 bore block. Any takers?
Re: Horsepower on stock Hemi block [Re: mprhound] #1939767
10/27/15 04:38 PM
10/27/15 04:38 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Basically a Mega block then? Or a different casting altogether?
Re: Horsepower on stock Hemi block [Re: mprhound] #1940653
10/28/15 07:54 PM
10/28/15 07:54 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Different casting looks like an early cold weather casting
