Re: 69 440 A body Exh. Manifold spacer ?
[Re: RR6BBL1969]
#1864666
07/05/15 10:51 PM
07/05/15 10:51 PM
Posts: 4,284 Florida
blewbyu
What is the web address or phone number of big-block-Dave so I can order one of his A body 440 exhaust spacers? Sounds like his is the best from everyone's posts. Thanks G.G. You do understand that you only need this if you have the correct drivers side 440 manifold and want to use the original exhaust system. If you are having an exhaust system made locally you do not need really need it it.
[Re: blewbyu]
#1864729
07/05/15 11:23 PM
07/05/15 11:23 PM
Posts: 391 Kentucky USA
RR6BBL1969
Kentucky USA
I am quite aware, thank you. I just need the contact info for Dave.
[Re: RR6BBL1969]
#1865183
07/06/15 04:23 PM
07/06/15 04:23 PM
Posts: 43,650 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I am quite aware, thank you. I just need the contact info for Dave. Were you able to get ahold of him? ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: 493RT]
#2035690
03/21/16 01:19 PM
03/21/16 01:19 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
If that is from Dave its correct
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: Tom Swope]
#2036018
03/21/16 09:38 PM
03/21/16 09:38 PM
Posts: 16,167 Mesa, Arizona
dart4forte
Mesa, Arizona
Our design is the two lazer cut flanges that are welded together. The available cast appearing external coating makes the part appear to be pretty close to the original rare piece. The numbers matching user probably would require an nos cast part but this kit was designed to be an economical option to fill a need not for the points correct application. We have had good success over the years with these kits with no complaints other than a few on this board so we will continue with this design for our specific market. We are appreciative of those on this board that have supported us in the past with both their business and comments. Being a manufacturer of over 500 Mopar exhaust parts any input regarding our product(s) is very much appreciated. I have to speak for Tom and his crew. I have the stock exhaust on my GTS 383 big block. The fit was great. Had a little difficulty putting the system on but I figured it out. Great workmanship and a great product. Cudos to Tom and his crew.
Abe Lincoln
[Re: 493RT]
#2036110
03/21/16 11:29 PM
03/21/16 11:29 PM
davesmopars
cheshire, ct
Dons Exhaust is made from NOS pipes, His son took over the business. Its looks awesome. Use Dave's spacer.
[Re: big-block-dave]
#2036238
03/22/16 03:09 AM
03/22/16 03:09 AM
Posts: 1,187 USA
big-block-dave
USA
nudder
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: RR6BBL1969]
#2036595
03/22/16 05:18 PM
03/22/16 05:18 PM
Rhinodart
Rhinotruck
Rhinotruck
The measurements are precise and fit the 440 ex. manifold perfectly. No it's not Dave's , I was given the measurements from an original one. I had several made. Looks good to me! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
A-Body's RULE!
