Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long)
[Re: sasquatch]
#1851945
06/18/15 05:29 PM
06/18/15 05:29 PM
Posts: 1,051 The Great White North
RAMM
Plug the valve covers up and put some air in it and try soap bubbling the seal area. I know of several top shelf mopar engine builders who are ready to rip their hair out right now over these dang seals. Todd Forgot to mention that--On attempt #4 I rigged an air fitting right where the sending unit comes out of the back of the block. I pressurized it with up to 5 psi and sprayed the crank flange--no bubbles. I realize I may have to pressurize crankcase but really at that point I may as well dyno it and bring it up to temp. I have already proven it a few times--no leaks until you rev it up @ temperature.Thanks though. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1851953
06/18/15 05:45 PM
06/18/15 05:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It might pay to try an electric vacuum pump off a new car. They can be bought pretty cheap. Pretty sure Summit even carries one now.
[Re: JCCuda]
#1851973
06/18/15 06:08 PM
06/18/15 06:08 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I am not aware of this hole. Does anyone have a picture that shows the location of this hole? The hole is just over the main bearing, it was clogged with machining debris I must add this was on a Indy Maxx aluminum block, but is was causing the exact problem you have
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#1852021
06/18/15 07:21 PM
06/18/15 07:21 PM
RAMM
Here's the 3 retainers that have been tried. You can see the clearancing for the studs/nuts. J.Rob
[Re: RAMM]
#1852027
06/18/15 07:27 PM
06/18/15 07:27 PM
RAMM
Studying this closely I think I may have to provide more clearance between the #5 cap rear and the "deflector" on the crank. The black squiggle is where I could machine .057" off. It may do the trick. I really don't think there is any issue with the seal itself. I am leaning towards a severe oil/pressure buildup that NO seal can handle. I'm also starting to think the windage tray should be left out to provide more room between the rear counterweight and the cap. J.Rob
[Re: ross]
#1852151
06/18/15 10:15 PM
06/18/15 10:15 PM
RAMM
RAMM Did you happen to tank the block really good before the rebuild. I read a piece by Rick Ehrenburg a few years ago and he stated that some blocks because of poor manufacturing were porous at the rear and were sealed by some coating applied to the block at the factory.He warned about possible oil leaks after a good tank cleaning as it could remove this sealant. In your case it may be seeping just above the crank and presenting itself as a seal leak. I sure feel for you on this one. Ross This is actually something the customer suggested to me this morning. I do not have a hot tank but I do have a very good jetwash. It was suggested that I could have cleaned out or dislodged some material that was previously blocking some porosity. I will coat with Glyptol tomorrow as it is not difficult to do. Thanks, J.rob
[Re: Triggerfish]
#1852235
06/18/15 11:47 PM
06/18/15 11:47 PM
Posts: 152 usa
smos001
usa
I don't have a good pic of the problem. But, I am telling you this is the problem. I talked to some real experts on this. It's about components. It's about math. You have to measure everything. Something is out of tolerances. Things don't fix a leak because of knurling or smooth polish on the crank surface, grooves in bearings, or the grinding of OEM retainers.Ropes seal don't last and 1960 and 70s era motors did not have rope seals. It's about tolerances.
when we found the measurable problem. We did not even have to test the solution on the stand. We knew we had solved the problem.
Here is one guys solution that started our research I found on another site. He was very helpful. Our solution was similar but using micrometers. His discussion saved my engine (he was a saint!):
Install The rear main lip seal half in the block "flush" with the cap parting line. Install the Crank. If your Lip Seal compression on one side, is less than the other under close inspection with a light, with the Crank in the block, you have a potential for a leaky main. Gently, using a small screwdriver, GENTLY, insert it behind the offending side of poor compression, and "eyeball" the amount required to equal Lip compression "side to side". DO NOT damage the back of the seal with the screwdriver. It doesn't take much. Record the amount required to move the lip seal into equal compression.
Now dis-assemble.
Re-assemble this time, with the Block side Rear Seal lip half protruding approx. 1/4" above the parting line on the offending side. Reverse the same Seal offset installation in the Retainer. Now use the Retainer when installing, to CAPTURE and DRAG the offending poor contact side over into proper seal lip compression, the same amount as you recorded earlier, as you Tighten & Torque the Seal Retianer into place. Silicon up the sides of the Seal Retainer to the Block, deleting the paper inserts. (The paper side inserts probably won't go in anyways due to the Retainer offset installation)
[Re: RAMM]
#1852243
06/19/15 12:07 AM
06/19/15 12:07 AM
Posts: 361 Canada
onig
Canada
WOW, this is a helpful and interesting topic. Can't wait to see what actually worked to fix this.
69 Dart
[Re: 9secondsatellite]
#1852244
06/19/15 12:07 AM
06/19/15 12:07 AM
Posts: 643 southern conn
1969gtx
southern conn
Had a rear main seal tryed evry thing the fix. In my case had a aluminum tool made that fit the seal and fit in the main bairing put the lower seal cap on then shine a flashlight from the back the seal was to low at the block shimed the up worked grate. will never install a rear seal without testing the fit.
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: smos001]
#1852277
06/19/15 12:38 AM
06/19/15 12:38 AM
RAMM
OK,,, I have been through this hell before. I had my 383 engine built by the best in the business; a professional, 30 year, race engine shop. First run it leaked on the stand. Second seal...leaked on the stand. We pulled it apart 4 times. We checked and sent the crank out to an expert. Perfect crank.
Finally... He tore the engine down to the bare block. Checked everything with a micrometer. After measuring and researching we found that a small percentage of MOPAR block rear main seal retaining threads are drilled off to one side, ever so slightly. It is literately thousands of an inch off. Enough for a small leak according to Felpro.
He eventually used an OEM rear main seal retainer (they have some slop in the side to side placement. Driver to passenger side movement). He shimmed the retainer to one side the distance it needed to go to center the retainer exactly over the crank and to pull the weak side seal over to the crank surface. If you look closely you will see the weak seal side against the crank. also you will need to have the seal slightly off center in the block and retainer to have the retainer grab and pull the weak side over to the crank as you push the retainer to one side.
This is about component machine errors. DO NOT believe in crap like the type of knurling on the crank end, Rope seal fixes, and other non-mathematical crap. It's all about tolerances and measurements. Something has to be measurably wrong. either the crank is off or the retainer/block is off. Don't grind the retainer to make it tighter. Look at the seal as it presses all the way around the crank. I believe he said he used a snap gauge to measure the exact distance it was off from center and that measurement is what he used to push the retainer over.
My engine builder now checks every MOPAR block for this error. He spent months on my engine and cost him time and money that he does not want to go through again.
It was a nightmare. I feel your pain. My engine is now dry and runs strong. Thankyou and yes I have noticed this same thing time and time again. On attempt #4 I influenced the retainer to the side in order to increase contact on the weak side. I am aware of this, I have even taken measurements and shimmed fore and aft. I am all about the tolerances and my instincts say a rubber/PTFE/ whatever seal can take up a lot of misalignment. I am dealing with something dynamic--not static. Thanks for the response though. J.Rob
[Re: 1969gtx]
#1852285
06/19/15 12:43 AM
06/19/15 12:43 AM
RAMM
Had a rear main seal tryed evry thing the fix. In my case had a aluminum tool made that fit the seal and fit in the main bairing put the lower seal cap on then shine a flashlight from the back the seal was to low at the block shimed the up worked grate. will never install a rear seal without testing the fit. This is exactly the next step! I am machining a "stub" that will sit in the main journal and feature the seal journal to eliminate the crank flange. I want to "see" WTF is going on without the damn crank flange in the way. Thanks again! J.Rob
[Re: Monte_Smith]
#1852290
06/19/15 12:46 AM
06/19/15 12:46 AM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
Never seen or heard of a hole, that relieves pressure off the seal.
Ramm, just try the sealing ends 90* apart can't hurt. And like I said, I never glue the seal in the block or retainer. Just place it in there. Place lower half of seal, put crank in, then take upper half of seal and work it around crank until you parting lines at 90*. Then put the retainer in ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1852311
06/19/15 01:05 AM
06/19/15 01:05 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have been putting big block mopars together for close to 50 years and never had a leak, except the stud/pan problem mentioned earlier,lucky I guess. I haven't turned a seal 90 degree's but have off set them maybe 3/8" , never has a seal leak. Now watch the next one will pour put like there's no seal in it at all. I think this block is outa wack.
[Re: RAMM]
#1852376
06/19/15 04:16 AM
06/19/15 04:16 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
All this is exactly the reason I say put the seal in the block FIRST, with the ends at 12 and 6 oclock. Then you do whatever you have to do to make the retainer slide over that seal cleanly and freely, with NO influence either direction. With it all dry and no bolts, drop the retainer on and see how it feels and look in the holes to see if it is where it NEEDS to be, not where the bolts, or those idiotic side seals put it. One thing to understand.......the SEAL is what seals the crank. The retainer only holds the seal where it needs to be. With the seal in the block around the crank, the seal IS where it needs to be. Now make the retainer cleanly hold it. This is a piss poor design and always has been, but not unfixable. You need to drill the retainer holes out, drill them, makes no difference. This is NOT a critical piece. It ONLY holds the seal, nothing else. It's just not this hard
Other motors with two piece seals don't have this issue. The reason, is the seal is retained by the rear cap and is always consistent and goes on where it should every time. BBM doesn't have that luxury but is not hard to MAKE it work in a similar way.
If you have never had a BBM rear seal leak.........you simply haven't built enough of them. But since I started doing the above procedure....30 years ago or more........no more leaks
Many also want to "face" the retainer on the bottom, to make sure it sits flush. It MAY need it, but usually not. This generally just makes the seal groove not round any more and changes the crush. If you do that and put the seal where the ends are flush with block and retainer, it will NEVER seal. Its an easy measurement to determine if the retainer NEEDS a shave. Don't do it "just because"
[Re: RAMM]
#1852430
06/19/15 11:06 AM
06/19/15 11:06 AM
RAMM
Studying this closely I think I may have to provide more clearance between the #5 cap rear and the "deflector" on the crank. The black squiggle is where I could machine .057" off. It may do the trick. I really don't think there is any issue with the seal itself. I am leaning towards a severe oil/pressure buildup that NO seal can handle. I'm also starting to think the windage tray should be left out to provide more room between the rear counterweight and the cap. J.Rob Here is how the cap looks after machining. There is about double the room between the back of the cap and the deflector now. I figure it can't hurt. Also I am going to try Monte's method of seal installation. Also reassembling WITHOUT windage tray. Back on the dyno later today. J.Rob
