Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE!
[Re: smos001]
#1852662
06/19/15 04:38 PM
06/19/15 04:38 PM
Posts: 1,057 The Great White North
RAMM
Ran engine on the dyno for 90 mins. Performed 8 tests. NO LEAKS!!!!! NO LEAKS!!!!! Not a single drop!!
What did I do this time? Three things in conjunction.
1: Machine backside of #5 cap for more oil escape clearance
2: Install new normal black seals as Monte suggested
3: Omit OEM windage tray
While I was skeptical Monte's method would work--apparently it does. My hunch though tells me the windage tray was the real culprit. Don't know for sure at this point. Greatest Friday ever. Thanks for everyone's help and thoughts and possibly prayers. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1852675
06/19/15 04:55 PM
06/19/15 04:55 PM
Posts: 152 usa
smos001
usa
[Re: RAMM]
#1852690
06/19/15 05:22 PM
06/19/15 05:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
While I was skeptical Monte's method would work--apparently it does. My hunch though tells me the windage tray was the real culprit. Don't know for sure at this point. Greatest Friday ever. Thanks for everyone's help and thoughts and possibly prayers. J.Rob Glad to hear you made some leak free pulls... now I'm wondering what the REAL fix was/is
[Re: RAMM]
#1852694
06/19/15 05:31 PM
06/19/15 05:31 PM
Posts: 361 Canada
onig
Canada
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail.
69 Dart
[Re: MR_P_BODY]
#1852697
06/19/15 05:32 PM
06/19/15 05:32 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Congrats on getting that thing sealed up Jesse I know it had to be frustrating Time for a cold one ! Ron
[Re: Monte_Smith]
#1852793
06/19/15 07:53 PM
06/19/15 07:53 PM
RAMM
Glad you fixed it..........but I can pretty much assure you that the windage tray was NOT the problem............LOL!!! Care to make a wager? I still could install tray and test. Seriously though thankyou, Monte. I doubt I would have ever considered arranging seals that way. J.Rob
[Re: 9secondsatellite]
#1852796
06/19/15 08:03 PM
06/19/15 08:03 PM
RAMM
WINNER! WINNER! CHICKEN DINNER! glad you fixed the problem. one heck of a learning experience. Boy you aren't kidding about the learning experience. I have to give the customer some credit here actually. He is an older gentleman that did not pressure or belittle even once. He and I relayed experiences back and forth over the course of this saga and I could not have asked for a better person to have this happen to. I know that sounds bad, but HE supplied the billet Mancini retainer-which leaked worse than ever. HE supplied 3 oil pan gaskets. He supplied fuel when it wasn't even asked for. HE made countless trips to the shop and he exhausted every one of his resources trying to resolve this problem, all the while remaining in good spirits. J.Rob
[Re: onig]
#1852810
06/19/15 08:30 PM
06/19/15 08:30 PM
RAMM
Glad to hear you got this fixed. I am now breathing a sigh of relief for you and all your frustrations that you went through. So the seal is installed 90* from normal? When I started reading this thread and all the work that you went through, in, out, tear down, put back together, dyno again etc... to fix that leak, my thoughts were "this guy cares and goes the extra mile for his customers". Just curious now, who bit the bullet on this one, you, customer, or both. I am 4 hours away from you and am seriously considering using you for my machine work on the gen 3 hemi that is going to start sooner or later, just because of your work ethic and meticulous detail. Thankyou Onig, Thankyou so much. I do care. I cannot just give up without knowing the answer. I will share that when I dyno'd it this last Wed and it leaked, I texted the customer right away. He texted back--"What's next?" I responded with "A 20 foot tree limb and a 10 foot rope". There were some dark moments to be sure. To answer your question: The customer ate it in terms of some parts, and time and anguish. I ate it in the same fashion. I cannot charge someone that has entrusted me because of my expertise in a given area and I fail to deliver. This was in NO way shape or form the customers fault. I am just glad to have solved the problem. 12 pan gaskets, 3 intake valley pan gaskets, 1 set of rings and 7 rear main seals later.. Lucky for you member MattW here and I are about to embark on G3 HEMI development. Thanks J.Rob
[Re: onig]
#1852821
06/19/15 08:48 PM
06/19/15 08:48 PM
RAMM
So the seal is installed 90* from normal? That is correct. The seals are test installed in a pic above. J.Rob
[Re: firefighter3931]
#1852838
06/19/15 09:14 PM
06/19/15 09:14 PM
RAMM
Congrats on getting that thing sealed up Jesse I know it had to be frustrating Time for a cold one ! Ron Thankyou Ron! I am currently about 3 Bud tallboys in. p.s. How did your 440 Stealth headed project turn out? J.Rob
[Re: RAMM]
#1852886
06/19/15 10:26 PM
06/19/15 10:26 PM
Posts: 361 Canada
onig
Canada
My son and I were at MattW's place last year on his Indy head transaction. Looking forward to the Gen 3 development.
69 Dart
[Re: tman]
#1852916
06/19/15 10:49 PM
06/19/15 10:49 PM
RAMM
Curious. Which seal retainer did you end up using? Reconditioned stock one. J.Rob
[Re: onig]
#1852919
06/19/15 10:51 PM
06/19/15 10:51 PM
RAMM
My son and I were at MattW's place last year on his Indy head transaction. Looking forward to the Gen 3 development. Great! Matt and I have known and grown with each other for about 13 or so years now. We have big things in the works concerning G3's. J.Rob
Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long)
[Re: RAMM]
#1853021
06/20/15 01:48 AM
06/20/15 01:48 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
do you have a rope seal you can install?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
