Lucas Octane Booster
#1849775
06/15/15 06:28 PM
06/15/15 06:28 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Is it snake oil or does it make a difference? This particular one has good reviews on Summit and I have always heard good things about Lucas's products. Granted I know that nothing will take E-10 87 swill and turn it into 106 octane race gas... I picked one up on and order while I had free shipping. In my case I am right on the edge of pinging. I curved my dizzy so it won't ping at WOT but on hot days 80*+, I can get it to ping at 3/4 throttle or so. I'm sure this is because of the vacuum advance on the dizzy but I am trying to not have to disconnect it. What say you?
Re: Lucas Octane Booster
[Re: cjskotni]
#1850245
06/16/15 05:00 AM
06/16/15 05:00 AM
RapidRobert
You might buy a drum of race gas & add a gallon or so as needed on hot days before you go out cruisin. Wouldn't be a whole lot more work than adding a bottle of that stuff. No opinion on the financial differences & as you know ANY pinging is way too much. If you build a monster you gotta feed it what it wants (needs) & maybe that stuff DOES work but here's a BTT on this for ya
[Re: RapidRobert]
#1850571
06/16/15 04:54 PM
06/16/15 04:54 PM
dogdays
Well, I checked the Material Safety Data Sheet. It does not appear to have any metallic compounds or methanol. Seems to be straight petroleum distillate of some sort or sorts.
I for one would like to see results from an independent testing lab on the octane-boosting properties of this stuff. Otherwise it's just the placebo effect. Research shows that the placebo effect is so strong that around 40% of test subjects had an improvement of symptoms attributable solely to the placebo effect.
The claim: " Tested and proven to deliver three times more boost than most other brands."
This claim means nothing, as most other brands give little or no boost. It could be completely true or completely false and there's not enough in the statement to call it false advertising if it's false.
It never ceases to amaze me how some companies are given "reliable" status while others aren't, and on no factual basis whatsoever. For example, everyone and his dog thinks that Lucas is on the up-and-up. Anything they say must be true. But, what do they actually do? Yes, they are sponsors and probably have contingency money (advertising budget). But their PRIME BUSINESS is selling oil products. They EXIST to make money selling stuff, like any other commercial enterprise. Not that there's anything wrong with that.
Whoever designed their product containers was a genius, as was the guy who invented their little gear demonstrator machine found in the auto parts stores. Boy, it really worked. The knowledge gained from that hand-cranked demo machine would be extremely useful IF WE ALL DROVE LITTLE HAND-CRANKED GEAR MACHINES! The average car guy doesn't understand that the additive may have an unexpected consequence of making the oil release air more slowly and therefore cause foaming which can lead to lubrication failure. Maybe it does, maybe it doesn't, but my point is that the possibility wasn't even considered by the guys turning the crank.
On the other hand, Joe Gibbs Racing puts out a line of oils with some very believable claims and most everyone here says they're just trying to make money selling oil. Joe Gibbs Racing at least has a competitive race team and has spent thousands of hours dyno testing, PLUS competing in all those NASCAR events. I find their rationale much more believable.
Your mileage may vary. Like believers in any religion or subjects of a Journey song, believers won't stop believing.
R.
[Re: cjskotni]
#1850581
06/16/15 05:21 PM
06/16/15 05:21 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
After many years of 'testing', here's my thought on 'boosters'... Go find some CAM2... (Detonation is not always audible)...
[Re: cjskotni]
#1850878
06/17/15 01:27 AM
06/17/15 01:27 AM
Posts: 114 Oregon
Wagonman1967
I use it in my 11.5-1 SBC with 93 clear gas.Works for me.They also have 110 leaded race fuel for 68$ for 5 gals at my local Shell. The Lucas is about 8$ for a pint. Do the math. When I feel like getting frisky 110 stuff is fun.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: cjskotni]
#1850947
06/17/15 09:02 AM
06/17/15 09:02 AM
cjskotni
North Carolina
Yeah seems that the nearest station with non ethanol premium gas is 15 miles and race gas is even further. I'm not lucky enough to live real close to a place where I could buy a couple of gallons of hi-octane race gas and spike my tanks. I am trying to buy some time until I decide what to do with my motor. I undercammed it and I think this is part of my problem. I'd like to go with a higher lift roller setup which would probably cure all this BS instead of throwing money away on expensive race gas. My car is a street car and I wanted to avoid this having to go to exotic fuels. Thanks for the input, guys. Kinda what I expected that this is probably not going to do much, if anything. Oh well it was only 6.95 so worth a shot I guess.
[Re: 62maxwgn]
#1851278
06/17/15 08:09 PM
06/17/15 08:09 PM
BradH
If you spend a lot of time searching the web for octane booster test results, you may come to the same conclusion I did, which is that most of the stuff sold is junk.
The ones that do work (and I'm not even sure which ones those are right now, since formulations change and what worked 5 years ago might just be more junk now) don't make a huge improvement. But they'd be good enough for some margin of safety if you're running on the edge. But all that hype about turning pump gas into race gas is total b.s.
I wonder what he was paid to say that !! By whom? Certainly not the octane booster companies!
[Re: cjskotni]
#1851337
06/17/15 09:38 PM
06/17/15 09:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Petroleum distillates, as an octane booster, helps minimally, you basically average the octane levels of the constituent parts. TEL works much better and in substantially smaller quantities https://en.wikipedia.org/wiki/Tetraethyllead#History_of_TEL_in_fuels.
[Re: cjskotni]
#1851472
06/17/15 11:49 PM
06/17/15 11:49 PM
Supercuda
About to go away
About to go away
up yours
A point or two is not 91 octane to 92 or 93 octane.
It's 91 octane to 91.2 or 91.3 octane. That's the "point" as in point two or point three octane.
But yes, MMT works better than petroleum distillates, much better, but not as good as TEL.
