Re: Race/ Street strip radial front runners, and height/ fitment
[Re: B3422W5]
#1919219
09/25/15 12:22 AM
09/25/15 12:22 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'm using a 205/75/15 on a 4" wide Centerline qualifier wheel.They work well with no problem
[Re: B3422W5]
#1919356
09/25/15 11:39 AM
09/25/15 11:39 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That's great news^^^!!
I was looking at a Chevelle last night with that size and I thought they looked great for a street car and he said they ride nice. I think his were Triumph brand or something like that. What brand are yours?
[Re: B3422W5]
#1934532
10/18/15 11:02 PM
10/18/15 11:02 PM
ProSport
Akron, Ohio
Well, I made the decision to purchase a couple 205/75/15 front radials for my Duster and they are way too big. I went from 3" of oil pan clearance to 4.5" so I was happy with that and I thought they looked pretty good although the sidewalls were a little wider than what I wanted for an A-body but when I slowly turned the wheel they were gonna hit the rear part of the front fender badly and they were awfully close to hitting the top of the fender wheel opening. My 26" M/T Sportsmans measure 24 3/4 just standing up with a level and tape measure, these 205/75's measure just shy of 27". I REALLY need to find a radial that's a little taller than my 26" M/T's. Anybody want to buy some new tires cheap?
[Re: B3422W5]
#1934818
10/19/15 10:43 AM
10/19/15 10:43 AM
ProSport
Akron, Ohio
Might want to ask Hoosier if they measure 27 or go to there spec page. I call moroso and they couldn't say for sure there 28 measures 28. Circumferance is 86 3/8 is the best they could do. Circumference on the 27 Hoosier is 85. When I go over to Lane automotive to get them, will see if they are chalk marked like rears are. Will get two tallest matched pair. My 205/75's are 84" circumference and they don't fit my Duster.
[Re: B3422W5]
#1934828
10/19/15 11:04 AM
10/19/15 11:04 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I ended up buying Hoosier bias 27 inch fronts. Long story short, the passenger side one needed up hitting the fender and bent it, first time i took it out for a drive. Bought the same tire in a 26 and they are fine.
I will sell the 27 fronts if anybody needs them for a good deal.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1934833
10/19/15 11:27 AM
10/19/15 11:27 AM
Posts: 368 michigan
turbo toad
michigan
I will sell the 27 fronts if anybody needs them for a good deal. I might be interested in the 27 inch tires I'm just east of you in the jackson area pm me and maybe we can work something out
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: B3422W5]
#1934846
10/19/15 12:03 PM
10/19/15 12:03 PM
ProSport
Akron, Ohio
I will sell the 27 fronts if anybody needs them for a good deal. That sucks about the fender Don, luckily I turned mine slowly and looked at it, it would have hit badly.
[Re: B3422W5]
#1934869
10/19/15 12:41 PM
10/19/15 12:41 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Sorry they didn't work for you Bob. I've always thought those 205-75 tires looked big. They always get brought up in posts like these, but it's really too big to be considered a skinny front tire to me.
[Re: B3422W5]
#1934877
10/19/15 12:56 PM
10/19/15 12:56 PM
ProSport
Akron, Ohio
Yea I prefer them skinnier too, just tired of the wandering steering and the 3 inches of oil pan clearance. I don't even know what to do now. I drive this car alot.
[Re: B3422W5]
#1934881
10/19/15 01:01 PM
10/19/15 01:01 PM
an8sec70cuda
I know exactly what you mean. Looks like we're both gonna have to spend the $$$ on those tall M/T radials.
[Re: B3422W5]
#1935253
10/19/15 10:48 PM
10/19/15 10:48 PM
ProSport
Akron, Ohio
I'm sure the tall ones would hit my fenders so I'll have to go with the 26" radials. I called M/T today and asked why their 26" front radials are only about 25" tall according to everyone I've talked to and he said everyone must be measuring them wrong.
I measured my 26" Sportsman tires tonite after they were remounted and properly inflated and they are only 25.25" tall measured with a level on top.
[Re: B3422W5]
#1935452
10/20/15 10:41 AM
10/20/15 10:41 AM
an8sec70cuda
I've never measured my 28" sportsman fronts...might need to just to see.
[Re: B3422W5]
#1935541
10/20/15 02:03 PM
10/20/15 02:03 PM
ProSport
Akron, Ohio
http://m.summitracing.com/parts/cok-579878What do you guys think about this 185/15 Coker radial for a street car? 26.25" 7.40 section 5.50 tread I'd bet that it's a tad taller than the 26" M/T.
[Re: Chris2581]
#1935591
10/20/15 03:19 PM
10/20/15 03:19 PM
Posts: 485 Raleigh, NC
j.mcconnell
Raleigh, NC
I'm using a 205/75/15 on a 4" wide Centerline qualifier wheel.They work well with no problem Same size on a 4" x 2.25" backspace Weld wheel. Car sits on the lower bumpstops and clears fine.
[Re: B3422W5]
#1935688
10/20/15 06:01 PM
10/20/15 06:01 PM
ProSport
Akron, Ohio
I don't know how you guys are doing that, my 4" wheel only has 1.75 backspace but it was hitting the rear of the wheel opening badly, and it looked like it might hit the top of the opening if I hit a bump while turning. I guess that's why we test fit stuff, every car is a little different.
[Re: B3422W5]
#1937161
10/23/15 08:27 AM
10/23/15 08:27 AM
ProSport
Akron, Ohio
I went to Summit Yesterday To Check Out The Coker 579878 but it was a special order deal so I didn't get to see it. If it's a little taller than the 26" M/T radial I'd be happy.
[Re: ProSport]
#1937243
10/23/15 12:56 PM
10/23/15 12:56 PM
BradH
I don't know how you guys are doing that, my 4" wheel only has 1.75 backspace... Think that extra 1/2" of backspace the other guys' wheels have would result in enough extra room not to have your clearance problems?
