Re: Lost 60 ft.............
[Re: fishy340]
#1843629
06/07/15 07:57 PM
06/07/15 07:57 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Haven't heard many if any say I'm gonna put a 4150 on to go faster then a 4500. My 440" made 40hp from proper timing...I saw it with every degree added. And I didn't say that either. I said on some motors they might not pick up swapping out a 4150. On a heavier car without a lot of motor, 4150 might well ET better.My old 422 W5 motor being an example. That said I took off a 1025 race a Demon rs, and I didn't lose by the swap, just didn't gain anything. Depends on the intake as well, a dominator flanged intake has definate advantages. My 422 intake I used an adapter, probably part of the equation no doubt. The 1025 wasnight and day better on the street. I was an idiot getting rid of it to gain nothing and suffer in drive ability. Patrick at pro systems is a friend of mine. He loaned me a 750 4150 carb, and a 1000 cfm 4150 carb. Tried both those, the 1100 dominator and the 1025 race demon. The 750 only ran about 13 hundreds worse than the Dom and race demon. Bigger isn't always better. My little 318 was dyno'ed at engine masters with a 950 on it. It I am sure made the most power with it. I put a 750 on it the other night, and the car seemed noticeably quicker pretty much right out of the box.Have yet to verify the results at the track, but will soon
[Re: D-50]
#1843635
06/07/15 08:16 PM
06/07/15 08:16 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Here is pic of intake and adapter that Brett done on my motor.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1843636
06/07/15 08:18 PM
06/07/15 08:18 PM
D-50
North, Alabama
i will try the carb spec sheet again.
[Re: D-50]
#1843682
06/07/15 09:04 PM
06/07/15 09:04 PM
Thumperdart
State of confusion
That's a wacky tune up in my humble opinion.................What`s the emulsion set up?
[Re: D-50]
#1843693
06/07/15 09:15 PM
06/07/15 09:15 PM
B3422W5
Portage,michigan
Same exact carb I had. It's an 1100, not a 1050. Only difference is squirters sizes that I can see.
[Re: Thumperdart]
#1843696
06/07/15 09:18 PM
06/07/15 09:18 PM
D-50
North, Alabama
That's a wacky tune up in my humble opinion................. Thumper do you see anything that would cause me to loose 60ft? Or anybody else got any ideas.
[Re: D-50]
#1843754
06/07/15 10:12 PM
06/07/15 10:12 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
1 tenth and 2 mile an hour WOW.this thread should be Pro System kicks butt. that's very impressive.I'd say try the timing thing.and talk to your converter people it might need to be loosened up a few. Rpm can help air speed down low dominators don't like slow Air speed.but like what was mentioned more timing would be my first test
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: D-50]
#1843906
06/08/15 12:48 AM
06/08/15 12:48 AM
Thumperdart
State of confusion
That's a wacky tune up in my humble opinion................. Thumper do you see anything that would cause me to loose 60ft? Or anybody else got any ideas. I`d size down the squirters for starters and mess w/float level and emulsion sizing and maybe a t-slot jet and as others mentioned timing stall etc.
[Re: D-50]
#1844115
06/08/15 12:32 PM
06/08/15 12:32 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
No 4500 experience, but I'd get timing squared away first.
Distributor locked out or have advance curve? Initial timing will have a large impact on idle characteristics, signal strength, etc. Need that set up before you mess with the carb or you will just end up chasing your tail.
Rich at the hit and rich at part throttle can be tuned with squirters, idle feed restriction and transfer slot, as Thump stated.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: D-50]
#1844197
06/08/15 02:05 PM
06/08/15 02:05 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Would love to see your spec sheet posted up. I bet it is VERY similar to ALOT of others he does, regardless of the combo it was built for. Seen it many times before.
[Re: D-50]
#1844357
06/08/15 06:07 PM
06/08/15 06:07 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Put the timing in the motor, I went from 9.70s to 9.50s with 4° of timing. It will help 60 ft too.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Dodgem]
#1844531
06/08/15 09:51 PM
06/08/15 09:51 PM
D-50
North, Alabama
When I bought my Dommy it had 28 squirters thinking they were too small went 42 before I tried it picked up 1 tenth and 2 mph. but 60 was slower. next week after a couple tt's changed back to the 28 sqirters it came with and 60 foot cam back so was now .2 and 2 mph faster. Guess guy who owned it before me had it right. Thanks, that sounds what I need to try. It has #40 squirters in it now. Also I forgot to say that I FOOT BRAKE. I do not have a trans brake.
[Re: D-50]
#1844594
06/08/15 10:59 PM
06/08/15 10:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I bought my Dommy it had 28 squirters thinking they were too small went 42 before I tried it picked up 1 tenth and 2 mph. but 60 was slower. next week after a couple tt's changed back to the 28 sqirters it came with and 60 foot cam back so was now .2 and 2 mph faster. Guess guy who owned it before me had it right. Thanks, that sounds what I need to try. It has #40 squirters in it now. Also I forgot to say that I FOOT BRAKE. I do not have a trans brake. Why is it so hard to just add timing... I would start at 2* per jump
[Re: D-50]
#1844619
06/08/15 11:23 PM
06/08/15 11:23 PM
B3422W5
Portage,michigan
The 1100 of Patrick's I had came armed with 45 squirters. Either off the foot or the brake the car 60 footed the same number( and if the car is sorted out that should be the case with most such bracket cars) Don't think I ever tried smaller squirters, the 45's were just as crisp as could be. I have no idea why he uses such big squirters after getting all the combo information and then building a custom carb to suit that combo..... But they seem to be the norm.
[Re: MR_P_BODY]
#1844655
06/08/15 11:55 PM
06/08/15 11:55 PM
D-50
North, Alabama
When I bought my Dommy it had 28 squirters thinking they were too small went 42 before I tried it picked up 1 tenth and 2 mph. but 60 was slower. next week after a couple tt's changed back to the 28 sqirters it came with and 60 foot cam back so was now .2 and 2 mph faster. Guess guy who owned it before me had it right. Thanks, that sounds what I need to try. It has #40 squirters in it now. Also I forgot to say that I FOOT BRAKE. I do not have a trans brake. Why is it so hard to just add timing... I would start at 2* per jump I have the timing set exactly where it was when I had the 950 on it when I was having 1.33-1.34 60ft. times. I did not know that you had to change the timing when you changed the carb. I was just wondering why I lost 60ft. with the bigger carb. That was the only change. I lost at least 6 hundreds in the 60 ft. But I am here to learn something..
[Re: D-50]
#1844670
06/09/15 12:10 AM
06/09/15 12:10 AM
MR_P_BODY
When I bought my Dommy it had 28 squirters thinking they were too small went 42 before I tried it picked up 1 tenth and 2 mph. but 60 was slower. next week after a couple tt's changed back to the 28 sqirters it came with and 60 foot cam back so was now .2 and 2 mph faster. Guess guy who owned it before me had it right. Thanks, that sounds what I need to try. It has #40 squirters in it now. Also I forgot to say that I FOOT BRAKE. I do not have a trans brake. Why is it so hard to just add timing... I would start at 2* per jump I have the timing set exactly where it was when I had the 950 on it when I was having 1.33-1.34 60ft. times. I did not know that you had to change the timing when you changed the carb. I was just wondering why I lost 60ft. with the bigger carb. That was the only change. I lost at least 6 hundreds in the 60 ft. But I am here to learn something.. I dont know didilly but if the guy that built the engine says jump the timing up... thats what I do
[Re: SpareParts]
#1844677
06/09/15 12:19 AM
06/09/15 12:19 AM
D-50
North, Alabama
I thought it would be better to figure out the carb problem before I started changing the timing. I guess I will try more timing next time to the track.
