Re: piston cleaning blues
[Re: Moparnut426]
#184331
01/05/09 04:29 PM
01/05/09 04:29 PM
Posts: 5,080 organ
maximum entropy
organ
comet is better. not too much. maybe a cup or so. coffee grounds mixed with cinder will do in a pinch. iron filings are also excellent.
[Re: TX91971]
#184333
01/05/09 06:29 PM
01/05/09 06:29 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Will it run, sure. Will it be right, no. I understand all about budget and doing something cheap, but I still think it should be done right. Cast pistons are dirt cheap and a bore hone is not expensive. The whole process could likely be done for 150 bucks, with pistons. IMO, if you could not afford that, he should of just left the 250k shortblock assembled and went as is.....but I do realize that he was not asking for opinions, he only wanted to know how to get the carbon off. Seeing as that is the case, I am removing my from this discussion and should not have commented in the first place. Monte
[Re: Monte_Smith]
#184334
01/05/09 06:51 PM
01/05/09 06:51 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Monte,
I totally understand where you are coming from, but in this case, The customer only has about X amount of $$$ and our machine shop charges about 350 to bore the block, and pistons cost 150ish, and then you have to press the old ones off, and press the new ones on, all costs money the customer just didnt have.
We will be fine.
Thanks and If it was mine, and I had the cash it would get bored, Never said it was a perfect world.
Not disagreeing with you at all, but certain things just have to work on a budjet.
Kasey
[Re: Moparnut426]
#184335
01/05/09 08:00 PM
01/05/09 08:00 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
Yeah, it'd be better to replace the pistons, but... I'd try some aircraft paint stripper if I was going to try and reuse 'em. Aircraft stripper is formulated to not eat aluminum. Seems to me I put some on some carbon and it chewed through it like Rosanne Barr on a chunk of roast beef -bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: Monte_Smith]
#184336
01/06/09 05:06 AM
01/06/09 05:06 AM
Posts: 30,484 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Monte
150$ for a bore and hone WITH pistons?
Have I got some work for that shop you deal with !!!
[Re: Monte_Smith]
#184338
01/11/09 11:21 PM
01/11/09 11:21 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Monte
Good thang ya dudn't sugjezt a cam change Her's yer change
[Re: hemi-itis]
#184339
01/12/09 01:26 AM
01/12/09 01:26 AM
Posts: 4,791 Holland MI Ottawa
2boltmain
Holland MI Ottawa
When I was a kid a local snowmobile racer would glass bead blast his pistons. Said it cleaned em up real nice but didnt effect the material.????? High school auto shop teacher would soak them in chem dip carb cleaner. (The shop had a 30 gallon drum) That was 20 years ago. I think the formula now is different and hard on metal?
Keep old mopars alive.
[Re: 2boltmain]
#184340
01/12/09 02:02 AM
01/12/09 02:02 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
It's different but it's not that it's hard on metal...It's ineffective or carbon... EPA approved...
