Re: 64 Dodge - NSS this past weekend
[Re: 383man]
#1836447
05/29/15 03:34 AM
05/29/15 03:34 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
My '64 Dodge never ran that good and that is why it lives in Chicago now. Maybe it will get faster the closer it gets to wisconsin?????
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Gabby63]
#1837213
05/30/15 11:30 AM
05/30/15 11:30 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
I definitely like your setup . Can you give any details on engine . Thanks for posting this . Gary Gary, Engine was built by Todd Goodwin from Goodwin Competition. It's a KB 572 machined by Todd, heads are based from a -13 but 100% done by Goodwin. Valve train designed and built by Todd, sheet metal manifold (again Goodwins design), 55mm cam ( don't know the specs), and don't know compression. I'd share if I knew more. Footbrake and launch at 3000/3500 and normally shift at 8000/8300. Transmission is a 727, 2.45/1.45/1.1 built by Jim Rush with a ATI convertor. Ladder bar car, weight 3550 lbs
[Re: sjs64polara]
#1837250
05/30/15 12:46 PM
05/30/15 12:46 PM
Posts: 3,505 DFW
mr_340
DFW
I didn't think sheet metal intakes were legal in NSS?
Floyd Lippencott IV
[Re: mr_340]
#1837259
05/30/15 01:11 PM
05/30/15 01:11 PM
Posts: 995 Addison,IL
OUTLAWSSAA
Addison,IL
I didn't think sheet metal intakes were legal in NSS? Sure they are,depending on which NSS group you run with. This group allows them,the NMCA also allows them. The Victory series does not allow them.
[Re: OUTLAWSSAA]
#1838115
05/31/15 06:13 PM
05/31/15 06:13 PM
Posts: 9,897 MI, usa
dvw
MI, usa
I didn't think sheet metal intakes were legal in NSS? Sure they are,depending on which NSS group you run with. This group allows them,the NMCA also allows them. The Victory series does not allow them. Wouldn't matter anyway. Victory has low ET limit 9.0 Doug
[Re: sjs64polara]
#1839171
06/01/15 08:53 PM
06/01/15 08:53 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Wow what a cool car! I love it.
