Re: inverted rear shock?
[Re: Clanton]
#1834415
05/26/15 11:11 AM
05/26/15 11:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you tend to drag race why dont you relocate the shocks.. stand them upright and move the bottom of the shock back another 1/2".. this would give you the best of both worlds ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1834423
05/26/15 11:22 AM
05/26/15 11:22 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
If you tend to drag race why dont you relocate the shocks.. stand them upright and move the bottom of the shock back another 1/2".. this would give you the best of both worlds The simple answer is it is easier to replace the shock.I like to think the stock angle of the shock will help sway,prevent tire rub on the fender... JMO.I would like to go this way.
[Re: Clanton]
#1834433
05/26/15 11:37 AM
05/26/15 11:37 AM
MR_P_BODY
If you tend to drag race why dont you relocate the shocks.. stand them upright and move the bottom of the shock back another 1/2".. this would give you the best of both worlds The simple answer is it is easier to replace the shock.I like to think the stock angle of the shock will help sway,prevent tire rub on the fender... JMO.I would like to go this way. If your concerned with other issues, then kick them back a 1/2".. same angles... this should clear and be the cheapest way out of the problem... will other shocks help.. maybe be.. but I'm looking at what will fix your issue EDIT I'm talking kicking the bottom of the shock back
[Re: MR_P_BODY]
#1834441
05/26/15 11:51 AM
05/26/15 11:51 AM
Clanton
northern,Ohio,USA
If you tend to drag race why dont you relocate the shocks.. stand them upright and move the bottom of the shock back another 1/2".. this would give you the best of both worlds The simple answer is it is easier to replace the shock.I like to think the stock angle of the shock will help sway,prevent tire rub on the fender... JMO.I would like to go this way. If your concerned with other issues, then kick them back a 1/2".. same angles... this should clear and be the cheapest way out of the problem... will other shocks help.. maybe be.. but I'm looking at what will fix your issue EDIT I'm talking kicking the bottom of the shock back I am not so sure moving it back is a fix.The axle hit the rancho's and the tube is 2 3/4" and a QA-1 is 2" and who knows where it would stop[unsure]The inverted shock would give it the most clearance and may be equal to moving the shock back.The ranch tubes got dented 1/4" and I did not hit the tires hard full hook.
[Re: jcc]
#1834460
05/26/15 12:16 PM
05/26/15 12:16 PM
MR_P_BODY
Would simply inverting your current shock solve the issue? I don't see a problem other then maybe on an adjustable with aeration affecting the control valving. Corner turners do it for less unsprung weight, but it raises COG a minuscule and takes the shock out of any cooling airflow, not much of a concern when used at 1/4 mile at a time. I would at least try it or contact manufacturer. Shock can't tell orientation on compression or rebound. Some shocks do know orientation... but that was usually the older style shocks.. gas pressure shocks dont normally have the issue.... so try flipping them over... it sounds like it'll be a yes or no answer ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Clanton]
#1834490
05/26/15 12:52 PM
05/26/15 12:52 PM
Thumperdart
State of confusion
Had the same issues w/my Ranchos also and was told NOT to run em upside down so I moved the shocks more upright from stock location and problem solved although it sounds like the QA-1's may solve that for ya. Fun stuff always.......
[Re: Clanton]
#1835590
05/27/15 10:27 PM
05/27/15 10:27 PM
Posts: 2,126 Byron, NY
W.I.N. Racing
Byron, NY
I think I see a set of worn out/bent shocks in your future...you put the smallest Dia at the greatest arc load...as Monte said...Fix the problem.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Clanton]
#1836074
05/28/15 04:49 PM
05/28/15 04:49 PM
Posts: 1,845 Tampa
DusterDave
Tampa
This is off the subject, but I couldn't help but notice that you're running hard brake line directly to your rear calipers. You should have a short length of flex hose that connects the calipers to a fixed bracket supporting the hard line. This will allow removal of the calipers, for pad replacement.
Gone to the dark side with an LS3 powered '57 Chevy 210
