Re: inverted rear shock? [Re: Clanton] #1836077
05/28/15 04:49 PM
05/28/15 04:49 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Their JOB is to stop housing roll...........so crank on them some more
Monte
Re: inverted rear shock? [Re: Clanton] #1836079
05/28/15 04:50 PM
05/28/15 04:50 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I called Caltrack and they said to put 1/4 turn pre load in both sides but is this enough?
Re: inverted rear shock? [Re: Clanton] #1836124
05/28/15 06:12 PM
05/28/15 06:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
cool
Re: inverted rear shock? [Re: Clanton] #1836131
05/28/15 06:43 PM
05/28/15 06:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The Rancho was about 1/2" away from axle tube and there is no bind when I cycle it so it is still good but now I have the new ones on.The brake pads do slide out the top but to take the rotor off a hose may help on stress on the tube.Thanks Dave for pointing that out tho.
Re: inverted rear shock? [Re: Clanton] #1836169
05/28/15 07:35 PM
05/28/15 07:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The damage on the tube is 7 1/2" from the lower shock eyelet and the o/c to the axle/eyelet is about 5 1/2" at rest.The shock is at a 45* so ^ makes sense.I am rambling I know.:)
