Re: tow rig?
[Re: blown340]
#183412
01/10/09 06:18 PM
01/10/09 06:18 PM
Posts: 250 kerrville, tx
bigbertha72
kerrville, tx
also tossing around the idea of swapping the v10 setup. i'll still end up having to fix the trans problem but be cheaper than geting the 4bt and trans to match. so might go that route and i can keep the 4x4 easier that way. still tossing it around. depends on how the v10 measures out. but should be able to make it work too. and i'll post some pics once we get started on it
Re: tow rig?
[Re: bigbertha72]
#183414
01/10/09 11:56 PM
01/10/09 11:56 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
If your Jeep is 4X4 like the one pictured, then your v10 transfer case will have the output on the wrong side. If you are going the 4bt route, then find a later model 6 speed(or even a 5 speed) that was behind a cummins in a dodge, and a dodge diesel 205 will mount to it. The Dodge 205 will have the output on the passenger side.
Or use any type of 2wd transmission (auto, manual, 6spd, 7 speed, 10 speed,) that can be mated to the cummins, and a divorced transfer case......
Just some options for an old tow pig like that.
FWIW, before 1989, if you wanted to tow a large trailer, you only had small block Dodges to tow with. In the 70's you could go big block. On the farm we used to tow 20-30,000# on a gooseneck behind dad's 77 dodge 4X4, 400, truck. It did not do it as nicely as our diesels do now, or as efficiently, but it did the job we needed it to. Its all about good brakes, proper gearing, and the appropriate mindset of the nut behind the wheel.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: tow rig?
[Re: bigbertha72]
#183421
02/15/09 02:49 AM
02/15/09 02:49 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
If you were closer, I have a 40" Freightliner sleeper I could fix you up with. All Alumnium. All the interior is there just no mattress. That was the standard width for the sleepers that were made separate fron the cab. Bryce ![](/ubbthreads/images/graemlins/shruggy.gif)
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: tow rig?
[Re: bigbertha72]
#183423
02/16/09 09:21 AM
02/16/09 09:21 AM
Posts: 2,648 GA
Boosted
GA
if you go 4bt I think you are going to have to drive the little diesel on the floor everywhere you go. It only comes with around 120hp...
As far as gasser motors vs the 6bt... Yea a gasser will pull a trailer, but no where like a 6bt.. The analogy that comes to mind is ... A chevette will get you back and forth everyday but who wants to drive one?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: tow rig?
[Re: bigbertha72]
#183425
02/17/09 05:31 AM
02/17/09 05:31 AM
shinnery
super street
super street
Hawley, Texas
There is not a lot of demand for the separate sleepers as most modern trucks are a one piece cab/sleeper. I would take $250 for the one I have. I believe that is a Peterbuilt on your sample and may not be as deep (fore and aft) as the one I have. May have to kick the camera a couple of times to see if I can convince it to work. Bryce ![](/ubbthreads/images/graemlins/popcrn.gif)
