Re: Harland Sharp rocker hold down studs
[Re: dare_dude]
#1831397
05/21/15 12:59 PM
05/21/15 12:59 PM
BradH
I know Indy offers a stud kit for their heads, but don't have a part #. Any Indy dealer should be able to provide that for you (along w/ the product ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) ). EDIT: If my Google search for ya' is correct, the ICH # is 440-R4-11.
[Re: DoubleD]
#1831630
05/21/15 07:09 PM
05/21/15 07:09 PM
BradH
You can order ARP stuff and make your own kit - these are Summit part numbers...
That's handy to know. I may need something longer than what I have already and had no idea that Summit carried (or at least lists) a variety of ARP studs in different lengths.
[Re: Sxrxrnr]
#2342363
07/24/17 12:14 PM
07/24/17 12:14 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
You ran a die on those cut off Grade 8 bolts with no heads to make your own threads?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dare_dude]
#2342467
07/24/17 03:31 PM
07/24/17 03:31 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I messed around with a couple of non-optimal solutions until I bought the stud kit from AR Engineering. Once those were installed, I never had a problem. I'm running Eddy RPM heads, Hughes Aluminum Rockers, Hughes shafts and the Hughes spacer/hold-down kit. The really nice part about the kit that AndyF put together was that there was an allen head recess in the top of the stud. You could bottom out the stud in the rocker support stand and then back it up one or two threads so that there would be two threads showing up top when everything was torqued down. By inserting an allen key into the top of the stud, you could keep the stud from sinking as you tightened the nut. I've included a picture of the setup but its low-res so you can't really zoom in on the rocker hold-down studs. I also attached a pic of the stud that came with the Eddy heads ... they were too short with the Hughes holddown kit. If you spun the stud until it bottomed out in the rocker support, there weren't enough threads up top to extend out past the nut. If you spun the Eddy Stud out enough so the top nut would have full thread engagement, then the stud didn't have many threads into the rocker stand. The AR Eng kit had all the right thread lengths, shank length and the NF thread up top. I should have bought a few more sets when I had the chance. And I seem to remember that Eddy provided a special stud for the rocker stand where the oil feed comes up through. It had a reduced diameter along the unthreaded shank so that more oil could get through. I couldn't find that when I was finally doing the install and Hughes Tech Support said not to worry about it. I didn't and at pre-lube, with the cam lined up properly for each bank, my rockers were getting plenty of oil. Maybe Andy could share with us the info he put together for ARP when he thought they would put together a proper kit. Or maybe we could do a GroupBuy through Andy. He should have put that info into his book (maybe it's there - I'll have to check so he doesn't tell me to RTFM).
![Name: 120823ValveLashingAt2Am.jpg
ID: 291759 120823ValveLashingAt2Am.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/291759/filename/120823ValveLashingAt2Am.jpg) ![Name: 120821LongRockerArmStud.jpg
ID: 291760 120821LongRockerArmStud.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/291760/filename/120821LongRockerArmStud.jpg)
Last edited by rumblefish72; 07/25/17 09:11 AM. Reason: more descriptive after having coffee
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: jbc426]
#2343139
07/25/17 04:35 PM
07/25/17 04:35 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
You ran a die on those cut off Grade 8 bolts with no heads to make your own threads? Found some at Orchard Supply that were plenty long enough and threaded all the way to the bolt heads.
[Re: Sxrxrnr]
#2343169
07/25/17 05:30 PM
07/25/17 05:30 PM
Posts: 31,112 Oregon
AndyF
You ran a die on those cut off Grade 8 bolts with no heads to make your own threads? Found some at Orchard Supply that were plenty long enough and threaded all the way to the bolt heads. You made your own studs by cutting the threaded portion off of bolts? I know farmers who do that kind of stuff when they are broke down in the field but why not just log onto the Summit website and order the correct ARP studs? When you get ARP studs they have the proper coarse/fine thread so you can correctly pull to torque and they have the broached allen end.
[Re: AndyF]
#2343174
07/25/17 05:38 PM
07/25/17 05:38 PM
Sxrxrnr
Northern Calyfornua
You ran a die on those cut off Grade 8 bolts with no heads to make your own threads? Found some at Orchard Supply that were plenty long enough and threaded all the way to the bolt heads. You made your own studs by cutting the threaded portion off of bolts? I know farmers who do that kind of stuff when they are broke down in the field but why not just log onto the Summit website and order the correct ARP studs? When you get ARP studs they have the proper coarse/fine thread so you can correctly pull to torque and they have the broached allen end. Was putting valve train back together over a weekend, noted potential issue and went to hardware store so not to wait. Torque only 25 or 30 pounds,,,,don't even require grade 8's. Double nut tighten's studs ok.
[Re: AndyF]
#2345383
07/29/17 06:47 PM
07/29/17 06:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Your conversation with ARP didn't get you the correct answer. The ARP studs have 3/4 inch grip length which is 2 diameters of thread or 12 threads. That is more than adequate. Agreed Andy, I think this is getting way overthought here. As mentioned, Summit sells them, I sell them separately, but they arent cheap.I've used H/S rockers for over 25 years, and always used the same thread engagement, didnt need 1" of thread.Before all the ARP stud craze became the rage ( and they are better) we used grade 8 bolts and made thousand and thousand of passes on 9 second cars with bolts. To be fair, the cams now are much more " narly", but we used to run the Lunati .750 roller cam in a lot of engiones,. and it wasnt necessarily friendly.We can think this to death, I'll keep with what has been working fine. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
RIP Monte Smith
