How to increase torque
#1830328
05/19/15 09:15 PM
05/19/15 09:15 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
I'm lloking for a way to incease torque in my SB 408, do you have any ideas ?
Here is what I have..
408 ci Indy 360-1 heads milled to 55cc ported to 343 cfm Indy intake 10.8 cr 255*/263* solid roller cam ,1.6 rockers .640 lift 1 3/4 headers 3in pipes electric fan and water pump 950 main body carb dynoed at 606 hp and 553 lbs tq
Dan
Re: How to increase torque
[Re: Wedgeman]
#1830334
05/19/15 09:26 PM
05/19/15 09:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
How much more are you after?
Add another point of compression. With that much duration and aluminum heads it should be fine on pump premium. I have run that much with smaller cams and iron magnum heads with real tight quench.
Also where is your cam degreed to? What is the LSA? Seems like a ton of EX duration compared to intake... Shorter EX duration should give a little more burn down time and a little less overlap.
Sometimes a tappered carb spacer adds a few pounds of TQ on the cheap.
Thinner oil maybe... what are you running?
[Re: Wedgeman]
#1830362
05/19/15 10:09 PM
05/19/15 10:09 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
collector extensions. edit sorry I see you have pipes.
[Re: Wedgeman]
#1830429
05/19/15 11:37 PM
05/19/15 11:37 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
IMO, your combo has plenty of torque for its build. NA, you need to add More comp, advance the cam, or just add more CI, with the before mentioned mods. Also, longer Pipes, maybe. 3 "s aren't to long. But your primary 1.75" diameter isn't very large either for your HP
[Re: Wedgeman]
#1830449
05/19/15 11:54 PM
05/19/15 11:54 PM
Sport440
Canton, Ohio
I have a 2in spacer
If I could get 10 more lbs of tq..... Open,???, replace it with a 4 hole tapered.
[Re: Wedgeman]
#1830459
05/20/15 12:00 AM
05/20/15 12:00 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Maybe a 1" 4 hole tapered spacer on top of a 1" open spacer would help increase bottom end throttle response. The 950 might be a little large for the engine to handle out of the hole. Maybe you could even borrow an 850, just to try. I ran a mild 388 Brodix head Chevy in a Mustang for several years with some friends. Always had a 850 on it. Picked up 3 tenths when we switched over to a 750.
[image][/image]
[Re: Wedgeman]
#1830831
05/20/15 03:01 PM
05/20/15 03:01 PM
HotRodDave
Kalispell Mt.
What quench clearance are you running? Could be as easy as tightening up the quench/compresison and the TQ will increase across the RPM range.
[Re: HotRodDave]
#1830883
05/20/15 04:00 PM
05/20/15 04:00 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
What's the lobe spread and intake centerline? If you're looking for more torque you're probably not using up all your gear at the stripe so that would generally benefit from an earlier (+4 to 6 degrees advanced) ICL. That would hit the converter a little harder out of the whole and advance the torque curve ~300-400 rpm sooner all else being equal.
Not a huge cam but the big indy port might still be a little lazy for your weight and gear. Talk to Mshred, he had a similar combo in a fairly heavy A-body. 3" collector is going to limit your peak torque RPM with a big head but you don't have a lot of Compression either....I'd start with an 8-10" collector extention to see if it helps velocity below the peak without hurting it much more above it.
[Re: Wedgeman]
#1830907
05/20/15 04:29 PM
05/20/15 04:29 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
What is your 60ft and 1/8 ET and mph. And weight. My 360-2 heads flow about the same as yours and compression is the same. My cam is close also except for lift (255/266 @.050) But my motor is a 394 ci. I was running a 950 but switched to a ProSystems 1050 dominator. So far it has picked up about a tenth and 2 mph in the 1/8. It made 533 torque on dyno.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Wedgeman]
#1831157
05/20/15 10:59 PM
05/20/15 10:59 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
The cam is installed at 106* ICL
Average 60ft is 1.32, 6.42 sec 1/8 mile, no mph....
I was thinking of a smaller carb for ET's......
Yes I want quicker acceleration !!!!!!! That 60 ft. times is outstanding I know some very successful NHRA SB Mopar stocker racers that would kill for those 60s The 1/8 miles times don't seem to jive with those 60. ft times to me How about some of the other SB racers on here, how does his 60 ft compare to yours? I'm thinking that the motor is running out of fuel in the upper gears, maybe not
