1st fire-up for this years 408
#1829511
05/18/15 09:25 PM
05/18/15 09:25 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
Re: 1st fire-up for this years 408
[Re: 1967dartgt]
#1829557
05/18/15 10:20 PM
05/18/15 10:20 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can't seem to get link to work Try is now. I had issues getting this off my cell phone.
[Re: Quicktree]
#1829603
05/18/15 10:46 PM
05/18/15 10:46 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
come on already, you can build a motor and can't make a link work Its working for me now. Isn't it working yet? I down-loaded it and it didn't have sound for some reason. And heck engine building is simply fun.
[Re: pittsburghracer]
#1829608
05/18/15 10:47 PM
05/18/15 10:47 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Tells me to log in when I go to the link????????!
Get it working so I can hear it ....lol
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
#1829613
05/18/15 10:49 PM
05/18/15 10:49 PM
Quicktree
#1829661
05/18/15 11:13 PM
05/18/15 11:13 PM
B3422W5
Portage,michigan
Sweet!!!
Sounds healthy and crisp.
#1829669
05/18/15 11:16 PM
05/18/15 11:16 PM
Posts: 361 Canada
onig
Canada
Now it works. Sounds good.
69 Dart
#1829670
05/18/15 11:17 PM
05/18/15 11:17 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Pittsburgracer, Your motor sounds healthy. Can't wait to here what it runs. I am still having throttle problems. What throttle cable are you using? I tried the Lokar braided stainless and it moves around too much.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1829741
05/19/15 12:16 AM
05/19/15 12:16 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pittsburgracer, Your motor sounds healthy. Can't wait to here what it runs. I am still having throttle problems. What throttle cable are you using? I tried the Lokar braided stainless and it moves around too much. Thanks guys. I put a lot of hours in this set of Edelbrock heads and added a roller cam and modified Indy intake to take advantage of the extra cfm. I will post a couple of pictures of my throttle tomorrow but its a pretty basic set-up.
#1829761
05/19/15 12:40 AM
05/19/15 12:40 AM
Posts: 7,506 Az
Crizila
Az
Sounds good. Looks good. - but can it fight?
Fastest 300
[Re: roadhazard]
#1829782
05/19/15 01:02 AM
05/19/15 01:02 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sounds like those gaskets are making some pretty good power Better hang on those superformance gaskets are fantastic.
[Re: mopar dave]
#1829795
05/19/15 01:37 AM
05/19/15 01:37 AM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
sounds real good. what cam and compression does it have? Compression is a little lower than my last 408 as these are open chamber heads that have a small cut. Compression is now around 11.0 Cam specs. roller cam 672 intake and ex with 1.6 rocker.278@.050 duration. 310 advertized.
