Re: Price of NOS fill? [Re: n20mstr] #182696
01/04/09 02:39 PM
01/04/09 02:39 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Welding supply places. I have always used the easy method of frezzing my bottles and just hook up a line to the mother bottle, thats it.
you need to know if your mother bottle has a dip tube or not. If it does not have a dip tube, you need a stand that will hold the bottle upside down. You freeze your bottle for 3-12 hrs. Place you bottle on a scale, hook up a line to the mother bottle. Crack the valve on the mother bottle, crack the line to purge it of air at the small bottle, then open both valves and watch the scale. Do not overfill ....thats about it.
Sounds simple BUT be very careful as liquid nitrous CAN give you a freeze burn. Its best to have someone walk you through it the first couple times. I learned how to do it becasue instead of getting my bottles filled all the time, i would freeze bottles and transfer from 1/2 full to make a full bottle. This gave me a lot of practice..LOL LOL
What do I ask for at the weld supply place?
Re: Price of NOS fill? [Re: Blown61] #182697
01/04/09 02:47 PM
01/04/09 02:47 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
ask for NitrousPlus or Supernitrous, that is nitrous oxide with sulfur in it ( thats to prevent people from sniffing it to get high)
Or jsut explain to them that you want to buy nitrous oxide for use in a race car, usually 64 or 54lb mother bottles. Also be sure to find out if the have dip tube or not, If you have a choice get the one with NO diptube. Also get in touch with Monte Smith or someone, you will need the stand that hold the mother bottle, braided lines and bottle nuts and possibly nitrous in line filter to hook up the bottles. Good luck
....BAD A$$ STREET CAR.....
Re: Price of NOS fill? [Re: n20mstr] #182698
01/04/09 03:39 PM
01/04/09 03:39 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
How much spray do you think a forged piston stock rod and crank 383 could take?
Re: Price of NOS fill? [Re: n20mstr] #182699
01/04/09 03:43 PM
01/04/09 03:43 PM
Kirkland, Washington
Pacnorthcuda Offline
I don't think he has to worry about getting 'pure' (medical grade) Nitrous! Its very much a controlled substance. Without a license (you have to be a dentist/ortho etc, or an anetheisiologist.) you ain't gonna get it if you tried.
Re: Price of NOS fill? [Re: Pacnorthcuda] #182700
01/04/09 04:36 PM
01/04/09 04:36 PM
N
n20mstr Offline
n20mstr  Offline
N
Very true, BUT, the last place i bought from gave me TWO 64lb MEDICAL Grade nitrous cyl.....
When i went back for two more they asked me how i got the medical grade, i laughed and told them, you gave them to me....LOL LOL LOL
Re: Price of NOS fill? [Re: n20mstr] #182701
01/04/09 04:39 PM
01/04/09 04:39 PM
You were LAUGHING as you told them? Hee hee. "I want more of this stuff, puhhhleeese."
Re: Price of NOS fill? [Re: Blown61] #182702
01/04/09 04:43 PM
01/04/09 04:43 PM
N
n20mstr Offline
n20mstr  Offline
N
THe weak link in that combination is the Rod, It will tansfer ANY detonation right to the block, your other weak link, I would say 175hp (.073 square jetted) should live fine, you might also get away with 225 or more....BUT you need to run good fuel, and be conservative on the timing, Keep the motor out of detonation at all costs. I had a Stock block, stock crank 446, It had a JE piston and an alum rod, Even with stock caps, i sprayed close to 300 and made over 100 passes. The stock caps had massive cap walk, but that was about it. Pushed my then 3600+ car to 9teens 9.20s pretty consistently. Get used to reading plugs and looking for the signs of detonation on them
Re: Price of NOS fill? [Re: n20mstr] #182703
01/04/09 05:25 PM
01/04/09 05:25 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Going to run e85 with this motor and thinking max 200 hp shot. What timing you running and you locked out?
Re: Price of NOS fill? [Re: Blown61] #182704
01/04/09 10:46 PM
01/04/09 10:46 PM
N
n20mstr Offline
n20mstr  Offline
N
My engine is a different combination than yours, dont go by me, go by your sparkplugs...I run 30 intial then i am at 18 with everything on. Now i check my plugs and they sometimes had a little black spec on some, i prob could have pulled more timing and dropped some fuel out of it, BUT i was in that process and the car was picking up....I dont know what head your using, what type of quench etc...whatever you do, start out conservative all you can do by pulling too much timing is slow the car dow, add it back in 1-2 degrees at a time thats all...watch the plugs and the mph on your time slips...Best thing is contact Monte smith on here, he can sell you a flow tool and tech you how to use it properly as well as put you in the right direction as far as jetting , fuel psi, timing etc.
Re: Price of NOS fill? [Re: n20mstr] #182705
01/04/09 10:58 PM
01/04/09 10:58 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Ok cool, I am not looking to set the world on fire here, just a 100 to 150 shot. What about the guys that buy a kit and throw it on without messing with timing?
Re: Price of NOS fill? [Re: Blown61] #182706
01/04/09 11:08 PM
01/04/09 11:08 PM
N
n20mstr Offline
n20mstr  Offline
N
they get lucky LOL LOL
WHat i would do is get the car running well on motor....Whatever timing you get it to run well on, id retard it 6 degrees for 100, 8 for a 150. Then READ THE PLUGS....The best thing for you as a beginner is get in touch with Monte Smith, Get the kit from him, and a flow tool, Thats the best advice i can give you
Re: Price of NOS fill? [Re: n20mstr] #182707
01/04/09 11:14 PM
01/04/09 11:14 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Ok, cool thanks for all your help.
