Re: Need opinions on improving my cooling system
[Re: ProSport]
#1823272
05/10/15 10:43 AM
05/10/15 10:43 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Had the same problem in my buddy's 67 Barracuda. Had about the same distance but was using an electric pump. This is what we ended up with. Derale also has several low profile fans with shrouds. http://www.summitracing.com/parts/der-16217/overview/
[Re: ProSport]
#1823297
05/10/15 11:10 AM
05/10/15 11:10 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Thanks guys, I actually found the rest of the shroud that came in the kit downstairs, I'll check it out tomorrow to see if it fits everything and add it to my round shroud. I should've done that in the first place.
I'm not a fan of the flex fans either but it is all that would fit in my application. Do you guys know of any steel fixed fans or clutch fans that will work in a 2.75" space? I'll try to google the Bouchillon clutch that you mentioned.
My radiator is up against the core support, no room to move it without hacking the car up. Bob I have a couple OEM direct drive fans over here..... come take your pick Yes the outer part of that shroud needs to be installed as said.
[Re: 383man]
#1823299
05/10/15 11:11 AM
05/10/15 11:11 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Bob, you might have room for a dual electric fan setup, if you can find one that has room in between the fans to clear your pulley. With the right pair of twins, depth won't be an issue anymore. What is the length and height of your rad's fin area? What is the diameter of the front of the pulley? Take measurements of the location of the pulley, with respect to the fin area: vertically and horizontally. If you can PM me those dimensions, I can draw it out and tell you what size twin fans will fit, and possibly find you a dual electric setup that will fit nicely.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: 383man]
#1823426
05/10/15 01:54 PM
05/10/15 01:54 PM
Posts: 7,506 Az
Crizila
Az
Nice! I like the flex fans. They pull a lot of air at idle and lay flat at speed. OP doesn't have a shroud. It's more like a finger guard.
Fastest 300
[Re: ProSport]
#1823439
05/10/15 02:06 PM
05/10/15 02:06 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
Ditch the motor mounted water pump. Go to a remote Meziere pump and Dual Electric Fans that will cover the rad completely.
[Re: Crizila]
#1823487
05/10/15 03:34 PM
05/10/15 03:34 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Nice! I like the flex fans. They pull a lot of air at idle and lay flat at speed. OP doesn't have a shroud. It's more like a finger guard. It's funny you say that cuz that's exactly why I installed it lol. My fingers were getting real scared around that fan! This is just a street car so I avoided running anything electric besides the fuel pump. There's really no reason I can't make the mechanical pump work but the remote electric water pump sure does free up alot of room. Pricey though.
[Re: ProSport]
#1823495
05/10/15 03:52 PM
05/10/15 03:52 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Hey bob hows it going, did you finally get the 950 carb tuned out or did you have to get a different one? on your cooling problems, i think you need to build a shroud that covers the whole radiator surface. Right now a lot of the rad core is open and might not be getting the air flow pulled across the fins, if that makes sense? Have you thought about replacing the mechanical water pump and installing a drop in electric water pump like a summit/cvr one? Then installing a ford torus 3.8 electric fan? one thing i liked about the ford fan compared to the HHR fan is the ford,s electric fan motor is offset to the drivers side. Now i don't know if what i have is the best set up, but last year i drove my dart to town back in July in 90 degree heat/ high humidity and my car never got over 200. On the thermostat i ran a stock one that i took the guts out of it. But that is how i had the car set up for racing, did that to help cool the car down between races. I never changed it for the street, never got around to trying a 160 degree one to see how it would work on the street. also just remembered you have a 500 engine and i have a little wimpy 440 so what i am telling you might not work for your car.lol on my dart i am using a summit 27.5x19 aluminum rad, summit electric drop in water pump and the ford electric fan. but if you are wanting to use what you have now, i would suggest you get a shroud made that will cover your whole radiator. that has to help keep the car run cooler. here is a pick of the rad/fan set up on my dart. of bob got any new pics of the duster?thanks Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: ProSport]
#1823499
05/10/15 04:02 PM
05/10/15 04:02 PM
mopar65
oops i see every body has already said to fix the shroud.I really dislike the upgraded website.lol So for get everything i just said becasue its already been said.lol but if you are wanting to try a different water pump pulley i have a march under drive one you can have.
support our troops
[Re: DusterDave]
#1823522
05/10/15 04:51 PM
05/10/15 04:51 PM
ProSport
Akron, Ohio
Bob, you might have room for a dual electric fan setup, if you can find one that has room in between the fans to clear your pulley. With the right pair of twins, depth won't be an issue anymore. What is the length and height of your rad's fin area? What is the diameter of the front of the pulley? Take measurements of the location of the pulley, with respect to the fin area: vertically and horizontally. If you can PM me those dimensions, I can draw it out and tell you what size twin fans will fit, and possibly find you a dual electric setup that will fit nicely. DusterDave,The width is 22, height is 19.5, the water pump pulley snout is 3.5" and is offset towards the passenger side. I'm really leaning towards an electric fan now, it kinda sucks to not be able to cool things down for a few minutes when you stop somewhere. Mopar65, what is the total thickness of the Ford fan? I ended up selling carb and putting that money towards a new ProSystems carb and it runs awesome! I actually think the other one ran pretty good but I was having an ignition problem I found later. Also, I'm trying to avoid going to an electric water pump, really want to make this mechanical setup work like it should.
[Re: ProSport]
#1823558
05/10/15 05:56 PM
05/10/15 05:56 PM
Posts: 34,937 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Friend of mine fought this problem with a 390 furd, tried everything I talked him into putting a timing light on it ..
way,way off ..set it right, problem was gone
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: ProSport]
#1823633
05/10/15 08:22 PM
05/10/15 08:22 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Bob, you might have room for a dual electric fan setup, if you can find one that has room in between the fans to clear your pulley. With the right pair of twins, depth won't be an issue anymore. What is the length and height of your rad's fin area? What is the diameter of the front of the pulley? Take measurements of the location of the pulley, with respect to the fin area: vertically and horizontally. If you can PM me those dimensions, I can draw it out and tell you what size twin fans will fit, and possibly find you a dual electric setup that will fit nicely. DusterDave,The width is 22, height is 19.5, the water pump pulley snout is 3.5" and is offset towards the passenger side. I'm really leaning towards an electric fan now, it kinda sucks to not be able to cool things down for a few minutes when you stop somewhere. Thanks Bob. I need two more measurements from you. A dimension from the center of the pulley to the top of the fin area, and another from the center of the pulley to either the driver's side, or to the passenger side of the fin area (and tell me which one you measured). I need to know where the pulley is in relation to the fin area.
[Re: ProSport]
#1823648
05/10/15 08:35 PM
05/10/15 08:35 PM
Posts: 209 Mesa, Arizona
6pak2go
Mesa, Arizona
I used a Hayden 2765 fan clutch with a stock 18" 7 blade A/C steel fan. It's close (5/8") to the radiator, but works fine. It's the shortest one I could find. http://www.summitracing.com/parts/HDA-2765/The shroud is a repro B-body modified to fit. I opened up the core support to 26" as the radiator core is 26" x 19". I used foam to seal all the edges so all the air flow is through the core. It seems to cool fine so far (175 degrees idling in traffic), but haven't seen +100 degree days yet here in AZ. I built the car to run Drag Week, so it'll see plenty of stop and go traffic in the heat.
Robert R Mesa, AZ 70 Challenger R/T 440-6 4-Sp Cruiser 67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
[Re: ProSport]
#1823658
05/10/15 08:46 PM
05/10/15 08:46 PM
ProSport
Akron, Ohio
DusterDave, I'll let ya know. Thanks.
Pbody, that 22" width doesn't include the tanks on the side but it is still a smallish radiator for a 500" engine. Need upgrades$$$ already.
[Re: ProSport]
#1823683
05/10/15 09:26 PM
05/10/15 09:26 PM
ProSport
Akron, Ohio
DusterDave, it's kinda hard to get my fingers in there and be precise but I got it pretty close. I got 8 5/8 from center of water pump snout to top of radiator, and 9 1/8 to passenger side.
[Re: ProSport]
#1823685
05/10/15 09:27 PM
05/10/15 09:27 PM
ProSport
Akron, Ohio
6paktogo, that looks like a nice setup.
