Page 2 of 3 1 2 3
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: PorkyPig] #1822093
05/08/15 08:20 PM
05/08/15 08:20 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Originally Posted By PorkyPig
Did it go from having no quench to a real quench area with the milling? If so, I'd think that would have something to do with it needing less ignition lead.
Did the BSFC numbers improve, too?
This is what I was getting at. .040 compressed head gasket?
Just looked and saw RAMM got a 6% increase, much higher than the Vizard chart I posted predicted. I suspect he found some "bonus points" by building quench into it, too.
Well, RAMM? grin
Yes as I have stated many times over I am a BIG believer in quench. Because Mopars suffer so badly from basement level piston to deck heights from the factory this serves as a prime example of getting it "right" and can and does reap excellent results. Also in play is the extreme reduction of "crevice volume" I believe quench and crevice volume share an extremely close relationship. Yes the gasket is a true .039" compressed thickness--I reused them BTW.
The BSFC's did improve by a remarkable amount. They are low to mid .4's as of now. I also believe that the intial "suck" on the intake port is a touch better with the closer relationship with respect to the intake valve/valve pocket--This is why minimum valve to piston clearance can be a power maker. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: 67Satty] #1822098
05/08/15 08:25 PM
05/08/15 08:25 PM
RAMM Offline OP
RAMM  Offline OP
Originally Posted By 67Satty
Would a switch to aluminum heads allowed you to keep running the 38 degrees of timing and resulted in even more of a power jump?
This is interesting. I would like to have expanded on this even further.
What if I had preserved the comp ratio @ 9.4 with a -.055" deck vs. a 9.4 comp ratio @ zero deck? I believe the difference would have been more on the order of 1.5-2%--maybe less!
To answer your question--first I don't have an answer I have never done this. Second--I doubt it. Aluminum heads are not some magical engine parts. I'm not going to explain it here but --think of excessive advance as "negative torque" or not getting the job done as "fast burn" stuff. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822104
05/08/15 08:32 PM
05/08/15 08:32 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By RAMM
Like the title implies I had the chance to test a 440 RB @ 9.4 static compression ratio and then again (due to an oil leak) @ 10.4 static compression.
This is a 446 I recently built for a customer using '915 heads and flat top Wiseco forged pistons. It ran all right during the initial dyno session but the rear main was leaking a little and that was not acceptable so I took it off the dyno and couldn't leave it alone.
When I was assembling the engine the pistons measured .055" in the hole. Also understand the customer really wanted to save these pistons so I cleaned them up and CNC machined them with a slight conical dish netting a little more volume. Basically I knew there was plenty of room to play with here so I decked the block exactly .045" per side which put it @ 10.4 comp. I had the chance to re-dyno with NO other changes. The power increase is somewhat expected but the timing requirements changed dramatically. Previous timing for max power was 35-36 total--Now 30-31 total is all that it likes. Interesting to say the least. So +30 HP +38 ft/lbs at the peaks was observed--the graph tells a much better story. J.Rob
Although positive, just too many changes to equate the gain to CR change alone - which renders the info - info.
Fastest 300
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: Crizila] #1822115
05/08/15 08:50 PM
05/08/15 08:50 PM
RAMM Offline OP
RAMM  Offline OP
That's all that I am saying. I increased through machine work-the compression ratio exactly 1 full point--these are the results. Make of them what you may. I offered my thoughts on why and how--I do not know for sure--I only know what I know and have observed. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822117
05/08/15 08:53 PM
05/08/15 08:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I for one thank-you for sharing info. keep up the good work.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822166
05/08/15 09:42 PM
05/08/15 09:42 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The quench helped more than the compression.Try a steel shim gasket and get a perfect quench. Cometic .027 would make an ideal .037
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: PorkyPig] #1822223
05/08/15 10:30 PM
05/08/15 10:30 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Thanks for the info Mr P !!!! Porky great chart thanks for posting !! Ramm great topic !!! Thanks for all the info !!! Marty
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822257
05/08/15 10:55 PM
05/08/15 10:55 PM
Central NC
gch Offline
gch  Offline
Central NC
Thanks for taking the time to do it and post it.Quench not withstanding that is a fairly healthy cam so I can see it liking the extra compression.
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822349
05/09/15 12:31 AM
05/09/15 12:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
What fuel where you using on both test? Any idea of how much the weather changes where? One of the local Mopar races did some testing on one of his pump gas street motors and had a issue with ignition timing on that motor, he says he verified the TDC on the motor and tried 34 or 36, CRS realcrazy and it pinged noticably enough to stop the pull. We talked about the plug heat range, carb. jetting, timing light accuracy and jetting, the AFR where fat and the symtoms he was having. He ended up retarding the timing to 25 BTDC for the best results, which where substanstial shock shruggy I'm having troubles with my computer and ISP opening PDF files so I can't open and read the dyno sheets to help illustrate thhis results blush Test, test and test some more up wrench
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: pittsburghracer] #1822425
05/09/15 02:32 AM
05/09/15 02:32 AM
Washington
skrews Offline
skrews  Offline
Washington
X 2
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822462
05/09/15 05:39 AM
05/09/15 05:39 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Thanks that was a very intresting test!
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: Cab_Burge] #1822494
05/09/15 09:49 AM
05/09/15 09:49 AM
RAMM Offline OP
RAMM  Offline OP
Fuel was Esso 91. I can tell you the weather was similar both times. In fact I can tell you that density altitude was 1800+ feet both times. Weather aside the Correction Factor was almost identical both times. Raw power was up same amount as Raw power before. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822531
05/09/15 11:11 AM
05/09/15 11:11 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice job!
My opinion is that you created a more efficient combustion camber.
plain and simple. Using more of the mix for power. Matt
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822548
05/09/15 11:42 AM
05/09/15 11:42 AM
Az
Crizila Offline
Crizila  Offline
Az
Sorry if my reply came off a little harsh, but your thread title leads one to believe that the HP gain could be attributed to a CR change alone, and my point was that that was not the case ( although stated poorly by me ). As stated in this thread, I think a quench change had partly to do with the improvement, and maybe piston top reshaping, etc. I to, appreciate all your hard work and sharing the results. Just wanna clarify to all that adding a point to your CR my not automatically have the same positive results as you did. Making multiple changes is my personnel nemesis, as I don't have easy access to a dyno - and 2 - 3 trips down the track once a month can give pretty limited info. beer
Fastest 300
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822550
05/09/15 11:43 AM
05/09/15 11:43 AM
New York
polyspheric Offline
polyspheric  Offline
New York
What does that prove?
That there was much more taking place than the CR increase.
Boffin Emeritus
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: Crizila] #1822583
05/09/15 12:19 PM
05/09/15 12:19 PM
RAMM Offline OP
RAMM  Offline OP
The piston tops were reshaped for the initial build. I did not do anything different other than decking the block .045" This was the ONLY change. Pistons were in the same configuration both times. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: skrews] #1822607
05/09/15 01:00 PM
05/09/15 01:00 PM
BPE Offline
BPE  Offline
X 2
x 3
Rod
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822643
05/09/15 01:52 PM
05/09/15 01:52 PM
Az
Crizila Offline
Crizila  Offline
Az
Not how I read your OP - "CNC machined them with a slight conical dish". No matter, interesting post anyway. Regarding timing, had a similar experience when going from cast iron heads to aluminum heads. Timing requirements changed considerably. Wanted lots more. Besides changing the CR and in turn chamber design, could be material also ( cast iron to aluminum ). Think you were pretty much in the "sweet spot" as far as getting as much as you did with the CR change. I remember when the 426 max wedge motor first came out in 63. two versions - 11:1 and 13.5:1. In 64 they were only offering 12.5:1 on the high side. shruggy Diminishing returns?
Fastest 300
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MR_P_BODY] #1822656
05/09/15 02:02 PM
05/09/15 02:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By MR_P_BODY
Good info... from the testing I did.. the lower the starting
compression the bigger the gain... as in going from 9.1 to 10.1..
its a deminising return thing
wave
EXACTAMUNDO..........found similar results.
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: BPE] #1822662
05/09/15 02:10 PM
05/09/15 02:10 PM
X 2
x 3
Rod
iagree X4 up
Page 2 of 3 1 2 3
