Re: Pinion angle again
[Re: Evil Spirit]
#1822743
05/09/15 03:59 PM
05/09/15 03:59 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Last observation on the subject..........seems the guys who BUILD or RACE cars and who have been doing it a long time, McAllister, Bob George, Darren Tedder, Al Alguire, myself.......seem to do it one way and the keyboard warriors and parts vendors do it another.........hmmm.....Oh yeah, lets not leave out David Wolfe, builds car for a living........he apparently is all wrong as well.
Evil, your wrong and Darren Tedder is right. Suspension angle changes aside, more pinion angle CAN make a leaf car hit the tire harder. You can crunch all the numbers you want and SHOW any amount of proof it can't help........but it does at the track and that is what matters. That's an "old school" trick that was used long ago when tracks and tires were junk, but it DID work.........wouldn't be needed today. Now, you want "engineering" logic as to why, sorry can't help you, even though I have mechanical engineering background myself, just know it works. But it is nothing new for the "numbers" not to make sense. How many millions of new things you think have been engineered that SHOULD have been better, but were not. Race cars in particular are full of things that SHOULD or should NOT work better or worse.........but what SHOULD happen at times don't always work out like that
Oh, and Jerry, YOU are wrong, how about YOU get over it
Monte Unless you cut the perches off and re-weld them every time you make a pinion adjustment, you are making other changes that affect traction. Anything that you do that effects ride height changes static/instant centers and CHANGES TRACTION. Using a shim changes rear ride height, which CHANGES TRACTION. Moving the front mount point up or down to adjust pinion angle changes ride height and CHANGES TRACTION. Simply clamping the front segment together, Cal Trac bars, slapper bars, etc. shanges the spring rate which CHANGES TRACTION. Pretty much anything that you do, other that re-welding the perches back in the same location/different angle CHANGES OTHER THINGS WHICH IS WHAT ACTUALLY CHANGES THE TRACTION. You guys aren't the only ones that ever raced or built cars, chassis, etc. I've welded a few bars and made a few passes myself, starting in the mid 70's at Detroit Dragway, among other places. The fact that I never tried to make a living at racing doesn't mean that I never raced successfully or built cars CORRECTLY. And as to the guys that have been doing things forever, so it must be right. Over 20 years ago I was having a driveshaft made for a car, and to make a long story short, they hand me a shaft with the u-joint grease zerks lined up. I told them that I didn't want that style joint, and they had them installed wrong, anyways. He very arrogantly informed me that was the correct way and he had been doing it that way for over 20 years. I explained to him that for 20 years he was doing it wrong - under power the joint is stronger when you are compressing the zerk hole, not opening it. I then showed him in the Spicer powertrain book where it explained the same thing. Yeah, it will work that way; most won't know the difference - but in my case I had ordered a performance shaft and it wasn't what I needed. Fast forward 20+ years - a friend manages that shop now. I had them build me a shaft for my Dakota. He hands me a shaft with the u-joints installed with the grease zerks lined up. When I mentioned it to him, his boss comes out of the office and informs me that they have been doing it that way over 40 years. I laughed and left the shaft there and ordered one from AutoZone. It came with the grease fittings correctly staggered LOL. Morel of the story is you can show some people why they are doing something "wrong" and show them why it is "wrong" but they refuse to accept common sense logic or "textbook explanations". I may be hardheaded, but I try to learn something new every day, and I'm not so blatantly arrogant that I can't accept help from others. I take things at face value, not implied worth - I evaluate the material, instead of simply accepting opinions. I am not a sheep that can be blindly led down a blind path without reason. If that offends people or causes differences in opinion, so be it. Monty, you are obviously an intelligent person, and believe it or not, I respect your opinion. We simply dis-agree. You may be right - I may be right, or it may be somewhere in the middle. But one area that you are dead wrong is assuming that I have no experience at racing or building cars - far from it. I've spent far more time in the shop or at the track than I have at the keyboard. It's been FUN On a leaf car, when you shim the pinion down.......have you changed the spring, have you changed the pickup point, have you changed the leverage point on the chassis, or have you changed the instant center........the answer to all is NO. The amount of ride height change with a 2* shim MIGHT be a 1/4". On a 4-bar car, you shorten the top, lengthen the bottom and you have put more pinion angle in the car, with the SAME instant center, the SAME ride height, the SAME everything, but it WILL hit the tire harder. Every action or force, has an opposite and equal reaction. Angles DO change that. So the angle that the force hits the pinion can change how the housing initially reacts as the pinion trying to climb the ring gear is what rotates a housing in the first place. All about leverage. Now MORE angle at the pinion WILL eat some power, but it will initially hit the tire harder. So maybe THATS why it will help it hook, who knows, but it will. Like I said though, would never do this today with better tires and tracks.............but we used to. Now days you adjust the suspension to hit the tire and set the joint to eat as little power as possible. My theory and it is ONLY a theory as to why this works, is that with excessive pinion angle and the way it speeds the joint, is that on initial "hit" with lots of pinion angle, is that the joint tries to "throw" the pinion up, which rotates the housing faster, which will hit the tire harder. Don't know if that is what it does, but is only legitimate reason I can come up with. On a modern car with a data logger, shock sensors, pressure transducers and other things, it would actually be very EASY to test. But whats the point, I really don't care enough to find out..........Although I will point out something that happened recently that I just thought about. A customer with a new 4-link car that I set up. I set the front/rear percentages, set the 4-link, shocks and everything else. It SHOULD have worked just fine. When it was carried to the track, it was just "crushing" the tire and should not have been. Finally got him to bring it here and sure enough, it was trying to put the rims through the track. So I am jacking the car up to move the 4-link, when I notice it has about 6* of pinion angle. Asked him who changed it. He said the body shop took the rear apart to powder coat the bars(guess he didn't like my rattle can job)........this I did NOT know. Anyway, set the pinion angle back to 1.5* and car acted like it SHOULD have. This is a 2600 car with a 4-link, 738 nitrous motor and a 10.5x 29.5 M/T slick. Last pass that day had a 1.03 sixty foot. Earlier was in the teens, just "crushing" the tire. So, form your own conclusions. I form mine by what happens to me at the track, not by what a formula tells me "should" happen
[Re: RV2]
#1822763
05/09/15 04:30 PM
05/09/15 04:30 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Here's a video I stumbled on, I'm guessing it's a truck, leaf springs and no traction devices. You can see how much the pinion rotates just under normal driving. It's not a race car but interesting (to me) none the less. Sorry guys I lost the link and can't find it.
[Re: NITROUSN]
#1822764
05/09/15 04:31 PM
05/09/15 04:31 PM
Monte_Smith
North Alabama
Monte on this pic the shaft is out of phase and the red dust by the rear cap indicates a bad joint.
So is your suggestion to point the pinion straight ahead, to "equal" the planes? Can you imagine the angle the shaft will be on? Sorry, believe I will PASS on the fix...........And the red you see is not dust, but red colored dust seals on the joint. I have had this thing a LONG time. I believe if it had a bad joint, I would know it........Plus, this is how it came from the factory
[Re: Monte_Smith]
#1822772
05/09/15 04:40 PM
05/09/15 04:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So is your suggestion to point the pinion straight ahead, to "equal" the planes? Can you imagine the angle the shaft will be on? Sorry, believe I will PASS on the fix...........And the red you see is not dust, but red colored dust seals on the joint. I have had this thing a LONG time. I believe if it had a bad joint, I would know it........Plus, this is how it came from the factory Monte.. he is referring to the location of the U-joint caps but if I recall that spline section is a one location only so you cant change it... but normally the caps are square to each other
[Re: Quicktree]
#1822773
05/09/15 04:41 PM
05/09/15 04:41 PM
Monte_Smith
North Alabama
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!!
[Re: Monte_Smith]
#1822775
05/09/15 04:44 PM
05/09/15 04:44 PM
Posts: 18,417 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
So is your suggestion to point the pinion straight ahead, to "equal" the planes? Can you imagine the angle the shaft will be on? Sorry, believe I will PASS on the fix...........And the red you see is not dust, but red colored dust seals on the joint. I have had this thing a LONG time. I believe if it had a bad joint, I would know it........Plus, this is how it came from the factory I am not talking about angles I am talking about the joint phasing. Looks to me like the shaft is one spline out of time. If its red dust boots fine. Just red dust 99 percent of the time indicate rusted grinding up rollers in the cap. I am not stirring a pot I just thought my suggestions would be helpful.
[Re: MR_P_BODY]
#1822777
05/09/15 04:46 PM
05/09/15 04:46 PM
Monte_Smith
North Alabama
So is your suggestion to point the pinion straight ahead, to "equal" the planes? Can you imagine the angle the shaft will be on? Sorry, believe I will PASS on the fix...........And the red you see is not dust, but red colored dust seals on the joint. I have had this thing a LONG time. I believe if it had a bad joint, I would know it........Plus, this is how it came from the factory Monte.. he is referring to the location of the U-joint caps but if I recall that spline section is a one location only so you cant change it... but normally the caps are square to each other True..........just caught the "phase" comment, assumed he was talking about something else. But you are right, the shaft is out of phase. Don't know if that is a one position slip joint or not. I have NEVER had the shaft out myself, but it doesn't vibrate now, so would hate to fool with it...... Clock it right and it might shake my teeth out........LOL!!! I bought this thing as a "beater" years ago just to play around with. I don't work on it, I drive it. And today is the first time I have ever even looked at the drive shafts more than passing..........LOL!!!........I do NEED to see if I can clock that cap right though.....good catch
[Re: Monte_Smith]
#1822780
05/09/15 04:48 PM
05/09/15 04:48 PM
Quicktree
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it.
[Re: RV2]
#1822784
05/09/15 04:53 PM
05/09/15 04:53 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Next weeks topic.
Proper U-joint installation " why and how " LOL.
[Re: Quicktree]
#1822785
05/09/15 04:57 PM
05/09/15 04:57 PM
MR_P_BODY
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it. Tony... what happened to the parallel to the trans thing.. that "pinion angle" is close to zero but about 30* off of the trans angle
[Re: Quicktree]
#1822789
05/09/15 05:03 PM
05/09/15 05:03 PM
Monte_Smith
North Alabama
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it. You have GOT to be kidding me?...........but I just went and put my digital protractor on it for grins. The motor/trans is on a 2* down in rear angle. The pinion is pointed up 18* and the driveshaft is on a 21* down angle..........sooo, if my math is correct, it has 3* of pinion angle and the driveline angle is 16* AWAY from parallel.............nah, that's not "far off".......LOL!!! Mr.P.........now that doesn't apply to 4 wheel drive......they're "magic' shafts and angles. I mean that can be the only "real" difference.....right?.........LOL!!! Monte
[Re: Quicktree]
#1822804
05/09/15 05:23 PM
05/09/15 05:23 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it. A digital one, because Dave Morgan's book said they are the best.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: RV2]
#1822863
05/09/15 06:58 PM
05/09/15 06:58 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
In the 4x4 world they have to make all kinds of compromise to get the driveshaft to be acceptable. Turning that pinion down probably will make the angle to extreme for the u joint to handle, I had a jacked up ramcharger in here where they made them parralell but it ate u joints like crazy as the joints were maxing out and hitting themselves, we made the angle "wrong" and the vibration went away and so far no more joints gettin wasted. It is not ideal but just has to be done that way no way around it on a short wheel base jacked up rig. I think he could have gone with a CV shaft but it would have been more money than the truck was worth.
On leaf spring street cars I shoot for parralell or even put the pinion pointing 1 -2 degrees less than the engine/trans center. I don't know if that is ideal but has worked for me to keep vibration away and long u joint life. If it is powerful enough to twist the spring that bad I add a leaf, cal trac, clamp the front segment or even gasp! Pinion snubber.
I confess I do not do much race car stuff, no race tracks around here.
[Re: Monte_Smith]
#1822866
05/09/15 07:08 PM
05/09/15 07:08 PM
Quicktree
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it. You have GOT to be kidding me?...........but I just went and put my digital protractor on it for grins. The motor/trans is on a 2* down in rear angle. The pinion is pointed up 18* and the driveshaft is on a 21* down angle..........sooo, if my math is correct, it has 3* of pinion angle and the driveline angle is 16* AWAY from parallel.............nah, that's not "far off".......LOL!!! Mr.P.........now that doesn't apply to 4 wheel drive......they're "magic' shafts and angles. I mean that can be the only "real" difference.....right?.........LOL!!! Monte the picture is very deceptive looking to me so don't go getting your panties in a bunch
[Re: sixpackgut]
#1822867
05/09/15 07:12 PM
05/09/15 07:12 PM
Quicktree
Monte they dang near look parallel now You're smoking crack. The drive shaft is nearly inline with the pinion shaft and look at the joint on the back of the transfer case.............You think THAT is parallel centerline angles.......no wonder you have a hard time grasping the concept.........LOL!!! it's not that far off, put an angle finder on it. A digital one, because Dave Morgan's book said they are the best. boy you are really down on Dave Morgan, I am sure you are much smarter than he is.
