Re: New bullet, W5, 408 injected on alky
[Re: greendart408]
#182175
01/03/09 02:56 PM
01/03/09 02:56 PM
Posts: 12,015 Finally a HUSKER again
Moparnut426
How about a little info on the motor, what weight car it is going in, etc
It is going in a 69 dart with ladder bars, and coilovers. It weighed 3050lbs race ready before with w2s on it. It should be 2975 or so with the w5s or so I am hopeing. I have lost a little weight also . Motor is 408ci, 14-1comp,SDSS max effort w5s with a 683,728 roller. IT has a 727 trans with a 5200 vert. Hopefully it will run.
What Guts are in it?? Crank, Rods, Pistons, and what block you using?
![](/ubbthreads/images/graemlins/drool5.gif)
[Re: greendart408]
#182177
01/03/09 04:05 PM
01/03/09 04:05 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Mp, scat 4340 4in crank, eagle 6.200 rod, je pistons. Stock block, sonic checked with pro gram billet splayed caps.
Just so you know, with the 650-680 horse you are throwing at that block, it will split.
Its a definate mistake...sorry gotta say that
[Re: B3422W5]
#182179
01/03/09 08:26 PM
01/03/09 08:26 PM
Posts: 426 Cairns Queensland Australia. T...
vc360
It sounded like it was a killer combo till the stock block bit. Don have you broken a stock block before?
