Page 4 of 12 1 2 3 4 5 6 11 12
Re: Pinion angle again [Re: MR_P_BODY] #1820435
05/06/15 05:52 PM
05/06/15 05:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Originally Posted By MR_P_BODY
The ground never comes into play when talking pinion angle
wave
iagree so what is he talking about when he said it goes positive?
Re: Pinion angle again [Re: Quicktree] #1820439
05/06/15 05:55 PM
05/06/15 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
He is referring to the relationship of the DS and the pinion
the teepee aspect
wave
Re: Pinion angle again [Re: MR_P_BODY] #1820443
05/06/15 06:01 PM
05/06/15 06:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
wave
the teepee aspect
wave
what angle was the drive shaft?
Re: Pinion angle again [Re: Quicktree] #1820466
05/06/15 06:28 PM
05/06/15 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
the teepee aspect
wave
I dont recall the numbers.. go back and look
EDIT
if I recall it was 3* rear of the shaft up
wave
Re: Pinion angle again [Re: MR_P_BODY] #1820487
05/06/15 06:58 PM
05/06/15 06:58 PM
Q
Quicktree Offline
Quicktree  Offline
Q
hmmmm i didn't see the shaft even mentioned?
Re: Pinion angle again [Re: DoctorDiff] #1820740
05/06/15 11:37 PM
05/06/15 11:37 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By DoctorDiff
No. I mentioned 3 degree negative pinion angle.
I did not mention any specific (2, 3, 5 degree) driveline angle.
BTW, your quote from Jerry Bickel is correct. You want the pinion to become parallel to the transmission (which is a "straight line" in some cars) when the vehicle is under power.
If you can't build a race car so the drivetrain becomes a STRAIGHT LINE under power, you build the car so the drivetrain becomes PARALLEL. This is true weather the rearend is above or below the transmission.
This is the simple answer here, as whether or not the rear end is above or below the front universal. I concur, as it is True info. No toenail hanging rack or slapping around needed, like for wolfy. That prior statement in my other post was just some humor, lighten up there louise, lol No one is supposed to get angry. Come on ,its just the old pinion angle argument. If you don't get that, theres some room left on the toe nail rack. Never said anything about hanging from private parts, that was, well you know.
Its my hopes, someday that all of us pinion angle arguers are all on the same page. Not 25 pages.
Re: Pinion angle again [Re: Monte_Smith] #1820799
05/07/15 12:37 AM
05/07/15 12:37 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Monte_Smith
[quote=Quicktree][quote=Monte_Smith
Lets use your own logic against you. Would you agree, that most every factory car, has some downward angle in the rear of the motor, from the factory. Most would agree yes and be right. That factory car is set up for a certain size tire and to achieve "proper" driveline angle that you preach about......agreed?........Now, put a TALLER tire on the back, but give the car the SAME ride height. Factory geometry immediately wrecked because the pinion is HIGHER and any attempt to get "proper angle" results in positive pinion angle.........Think about that one a while.............LOL!!!
You need to think about that. When considering the pinion angle, you are not concerned about the ground. The car could be hanging from a toe rack, with the pinion straight above.
Trust me , you will get this. Thumps up. You have Nitrous nailed, but not pinion angle yet. Thumbs up again, since the icons aren't working for me.
Re: Pinion angle again [Re: Sport440] #1820839
05/07/15 02:12 AM
05/07/15 02:12 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I never mentioned anything about the ground, because the ground doesn't matter. Put a taller tire on and keep the same ride height, means the pinion is higher in the car, because the car sits over the tire more........... And as far as a handle on pinion angle, my handle is plenty good, some others around here, I am not so sure.
And Quicktree, if you have to ask me what positive pinion angle is, why are you even IN this discussion.
And still.......NOT ONE GURU has answered the question. Which WAS, if the front joint is lower than rear joint, the trans points toward the ground(and since some are SO caught up in exact numbers, lets say 3* tail down), which means the shaft runs UPHILL to pinion, would you roll the pinion UP 3*, to maintain a parallel angles, even though that HAS to put the joint broken over the WRONG way(positive).......when we ALL KNOW, or at least SHOULD know, that on acceleration the pinion climbs MORE and will make that joint angle even MORE wrong............waiting on an answer
How about a picture. So according to some of you THIS would be considered CORRECT since the engine/trans and rear are on the same angle. Even though the rear joint angle is over center and going to get worse on accel.........OK, find me a chassis guy who would set a rear angle up like this on a race car, thinking that is good to go and I will be quiet. For further clarification, we will even say this is where it is under power. Now I was always taught, that you NEVER want the rear joint to go over center under power in a race car.........but apparently it seems all those people who say that are full of hooey......LOL!!!
Re: Pinion angle again [Re: RV2] #1820849
05/07/15 04:14 AM
05/07/15 04:14 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Here's a couple video's that show the importance of having the trans and pinion centerlines parallel. Pretty simple concept, really. The only trick is to determine where the pinion angle needs to start at so the 2 angles are PARALLEL UNDER POWER. But this should put to rest any of the nonsense that has already been beat to death about the angles not needing to cancel each other out - but I doubt if it will. Enjoy the videos.
https://www.youtube.com/watch?v=gmV4qwLfOMY
https://www.youtube.com/watch?v=T4P75ZQvpws
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Pinion angle again [Re: Monte_Smith] #1820852
05/07/15 04:44 AM
05/07/15 04:44 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
[i]
If in your picture the angles are in fact being measured under power, making the trans 3* down, and the pinion 3* up, this makes the tailshaft and pinion parallel - HOW IN THE H*** IS THE U-JOINT GOING OVER CENTER? It's the mirror image of the front, and would cancel out the angles. Since in most cases this would be a big tire - ladder bar/4 link situation with little movement from static to loaded, I would set the pinion at 0-1* up, figuring it would only gain 2* under power and end up at 3* UP to cancel out the 3* DOWN of the tailshaft. At that point the u-joint IS NOT "OVERCENTERED" - it hasn't went past the front u-joints mirrored angle.
Re: Pinion angle again [Re: RV2] #1820860
05/07/15 06:53 AM
05/07/15 06:53 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Since all these threads always spin out of control, like a winter time valve lash discussion, why not just....?
Put the drive shaft in it, slap the angle finder on the shaft, and check it against the pinion. It's a door car that you're not going to change the driveline angles in, so knock that off the worry list. It needs pinion to bite.
Put three in it, hit it, and see. The object is to get to the track right? I've been as high as 10 degrees on a ladder bar before.
Re: Pinion angle again [Re: Monte_Smith] #1820871
05/07/15 07:29 AM
05/07/15 07:29 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte you know I am not asking you what positive pinion angle is. I was asking you what you were basing your statement off of. what is it in relation to. Positive to what??????
Re: Pinion angle again [Re: dthemi] #1820872
05/07/15 07:29 AM
05/07/15 07:29 AM
Q
Quicktree Offline
Quicktree  Offline
Q
absolutely, thats the way we did it 40 years ago
Re: Pinion angle again [Re: Quicktree] #1820905
05/07/15 09:03 AM
05/07/15 09:03 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Positive with respect to the back end of the driveshaft. Monte has explained several times that the driveline (trans/engine angle) is not considered, only the relationship of the back end of the driveshaft to pinion. Under power, you want the pinion to be in perfect alignment (or as close as possible without ever going positive) with the back end of the driveshaft, so you'll want to set the pinion angle several degrees negative with respect to the back end of the driveshaft. Hopefully that is an accurate interpretation of what Monte is trying to drive into the skulls of the unwashed masses.....LOL
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Pinion angle again [Re: Evil Spirit] #1820916
05/07/15 09:22 AM
05/07/15 09:22 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Originally Posted By Evil Spirit
[i]
I believe Monte drew that at static conditions. At the hit on leaf springs, that will end up ~+6 over center. Just hammering home the point that mirroring the trans and pinion angles at static conditions do not work in every situation.
Re: Pinion angle again [Re: RV2] #1820920
05/07/15 09:27 AM
05/07/15 09:27 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Pinion angle is only relative to the front joint angle and has nothing to do with drive shaft angle.....what is so difficult to understand about this?
If your measuring from drive shaft to pinion your doing it wrong.....period.
Additionally.....pinion angle has absolutely nothing to do with bite/hook......holy smokes!!!!
Re: Pinion angle again [Re: Jerry Kathe] #1820947
05/07/15 10:03 AM
05/07/15 10:03 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Ding, Ding, Ding - we have a W I N N E R !
The driveshaft doesn't even have to be in to check or set PINION angle.
And I'd like to punch the person that started the M Y T H that changing pinion angle changes traction right in the boy marbles.
Re: Pinion angle again [Re: Evil Spirit] #1820956
05/07/15 10:35 AM
05/07/15 10:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
So I assume you make it parallel to the trans then rollin
the pinion angle..... sure am glad you didnt set the pinion
angle on my old Jeep.. with the 33" tires and set up your
way the U-joints would have been in bind just sitting there
wave
Re: Pinion angle again [Re: MR_P_BODY] #1820984
05/07/15 11:37 AM
05/07/15 11:37 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
wave
I think we both know that lifted trucks - especially short wheelbase ones - have totally different issues and guidelines to follow. You generally try to minimize u-joint angles and any resulting vibrations are expected and are usually masked by the aggressive tire designs. Comparing the two applications is comparing apples to chicken wing seasonings. Why even go there?
Re: Pinion angle again [Re: Evil Spirit] #1820991
05/07/15 11:47 AM
05/07/15 11:47 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
And I'd like to punch the person that started the M Y T H that changing pinion angle changes traction right in the boy marbles. [/quote]
it is the same person that said the pinion snubber does some other magical thing besides keeping your overloaded cars driveshaft from rubbing in the tunnel...redneck traction control----hahahaha
