Page 2 of 8 1 2 3 4 5 6 7 8
Re: Heads Up Races for 2006 [Re: MIKES_DUSTER] #18121
11/15/05 02:24 PM
11/15/05 02:24 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I would also be interested in running at Englishtown.
Re: Heads Up Races for 2006 [Re: DodgeCharger] #18122
11/15/05 02:56 PM
11/15/05 02:56 PM
Indianapolis, IN
P
PROMAX Offline OP
super gas
PROMAX  Offline OP
super gas
P
Indianapolis, IN
I have had quite a few request to add W5 and Indy 360 heads to Muscle Street. I think it would be good but may have to add some weight. Any thoughts or comments?
I have also put a call in to E town, so we will see what happens.
Ben J. Gorman
Re: Heads Up Races for 2006 [Re: PROMAX] #18123
11/15/05 03:27 PM
11/15/05 03:27 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
My car come's close to fitting extreme street but there are some gray areas. If I have a 4-link can the car be back 1/2'd? if so does the wt also get you by the stock frame rail rule front to back? Also I would think a fiberglass door car would have trouble with the glass rule as well. I know you don't want the flush mount with the rivit's showing but as long as you can't tell
And I guess it's ok to remove the T-bars with a bolt on front K?
And lastly, come south for a race
Re: Heads Up Races for 2006 [Re: PROMAX] #18124
11/15/05 03:28 PM
11/15/05 03:28 PM
Mohnton, Pa
Mohnton, Pa
Is the Mopar Performance hemi block legal? I have a siamese block with aluminum mopar hemi heads. Low compression motor 10to1 compression.
I have never run the car but it should run at least low 11's.
Re: Heads Up Races for 2006 [Re: DodgeCharger] #18125
11/15/05 03:37 PM
11/15/05 03:37 PM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
I should have my car ready for the Indy race in June.
Steve
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Heads Up Races for 2006 [Re: StrokedW7] #18126
11/15/05 04:32 PM
11/15/05 04:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Steve
of what year???
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Heads Up Races for 2006 [Re: B3422W5] #18127
11/15/05 04:55 PM
11/15/05 04:55 PM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
Steve
of what year???
Hey!!! At least I have a car.
Re: Heads Up Races for 2006 [Re: StrokedW7] #18128
11/15/05 05:01 PM
11/15/05 05:01 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
One other problem no W5 heads surely not going to let W7 in .I would like to race in that class also see what happens
Re: Heads Up Races for 2006 [Re: scottb] #18129
11/15/05 05:15 PM
11/15/05 05:15 PM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
Huh??? They ARE allowed. You just need to add 50 pounds. I should be close to perfect. 3200 base weight less 300 pounds for naturally aspirated add 50 pounds for unconventional heads and 50 pounds for ladder bars (3,000 pounds).
I might have to get a BIGGER bottle... Then I just need to dial in the digital 7 and go have some fun.
Steve
Re: Heads Up Races for 2006 [Re: StrokedW7] #18130
11/15/05 05:31 PM
11/15/05 05:31 PM
Indianapolis, IN
P
PROMAX Offline OP
super gas
PROMAX  Offline OP
super gas
P
Indianapolis, IN
How about a race at the Rock on April 14-15 2006? I spoke with them today and are interested in adding the PFSC to their event.
I need to get a roll call on who would consider coming and racing.
We have thought about allowing all cast iron blocks for Muscle Street. The down side is that you can build some big cube motors with a Mega block. Any thoughts or comments?
Ben J. Gorman
Re: Heads Up Races for 2006 [Re: PROMAX] #18131
11/15/05 05:46 PM
11/15/05 05:46 PM
I've signed up as an associate sponsor. Thanks for the opportunity Ben. Good luck to all those who participate !
Re: Heads Up Races for 2006 #18132
11/15/05 06:14 PM
11/15/05 06:14 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Im in for the Rock. I wanted to race there anyway. only 1 question though. It doesnt say it anywhere but is a Motor Plate o.k. for muscle street. I fit everything else, and the motor is in stock location just has a plate. thanks for considering a race in the south. Bristol is another to consider.
Re: Heads Up Races for 2006 [Re: PROMAX] #18133
11/15/05 08:08 PM
11/15/05 08:08 PM
Mohnton, Pa
Mohnton, Pa
I think you can build up to a 604" motor out of a Mega block.I have never seen one on the street.I don't believe many people will build a big motor like this and put it in a stock apearing car. Unless you have a huge payout to pursue. Then you will attract special purpose built cars. I just want to run my street car in a heads up race.My car is my cruise night Sunday driver. It even has air conditioning.I would not build a car special to meet race rules just to possibly win a few hundred dollars and have bragging rights. The bottom line is to attract alot of cars the rules need to be broad enough that many different setups will be allowed to run.
I think the best way to equalize the field is with the tires allowed. No slicks allowed.
Re: Heads Up Races for 2006 [Re: DodgeCharger] #18134
11/15/05 08:38 PM
11/15/05 08:38 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Just to clarify, any aluminum block is allowed in Extreme? If so, please let us/me know if Extreme will be running at Vegas. Thank You, Chris
Re: Heads Up Races for 2006 [Re: B1CUDA] #18135
11/15/05 08:55 PM
11/15/05 08:55 PM
detroit area
moderncylinder Offline
detroit area
i dont have whatever it takes to open and read those rules,, why not just post them?? would a nhra ss a/a or b/a car run in that higher class?
jeff
Re: Heads Up Races for 2006 [Re: moderncylinder] #18136
11/15/05 09:08 PM
11/15/05 09:08 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
jeff
I would assume that if they allowed Super Stockers in, Michael Ogburn would want in at the Vegas race. I invited him to a PSCA race and he seemed to like the racing. I would love to line up against him in a heads up race. Hemi vs. Wedge. What a blast that would be.
Re: Heads Up Races for 2006 [Re: moderncylinder] #18137
11/15/05 09:11 PM
11/15/05 09:11 PM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
Ben-Questions on Extreme
Is there a weight penelty for ladder bars and leafs?
Is the clutch assist jerico legal?
What about a 50#-100# minimum reduction for a factory iron head?
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
Re: Heads Up Races for 2006 [Re: PROMAX] #18138
11/15/05 10:08 PM
11/15/05 10:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, it just opens another can of worms, and is outside the intent of an entry level class.
i understand the desire to try and broaden the rules to attract more competitors, but since it IS a heads up class....if the big cube cars start showing up and dominating, you'll lose some of your original competitor base in the process because they will no longer be competitive.
if someone wants to run in a heads up class that is beyond what the intent of Muscle Street is....they need to look at stepping up to the next level.
changing the rules to try and make everyone happy is how just about every good entry level class gets ruined.....my
also, i have no problem allowing the small blocks to use W5 and Indy heads in the class....so long as they are still used on OE blocks.
if Muscle Street is contested at E-town.....i'd participate.
Re: Heads Up Races for 2006 [Re: fast68plymouth] #18139
11/15/05 10:36 PM
11/15/05 10:36 PM
Mohnton, Pa
Mohnton, Pa
If somebody starts dominating with a big cube engine why can't the slower cars in muscle street step up and make their cars faster? My car is a Muscle car that I drive on the street. I would not convert it into a race car just to compete in a heads up class. The more cars that can be qualified to run in the class the more popular the class will become.
Re: Heads Up Races for 2006 [Re: DodgeCharger] #18140
11/15/05 10:55 PM
11/15/05 10:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
you answered your own question.
you dont want to change your car to fit the rules, but you expect someone else to change their car to be competitive so that an allownace can be made so that your car will fit in the class.
if they have a car that they built around the current rules...and the rules change to allow a bunch of faster cars in, and those cars dominate(which they should), most of the other guys either wont compete, or will step up.
if they are forced to step up....they will often step up to another class.
i've seen this same cycle many times in all forms of racing.
when the rules keep getting changed to allow more cars in that are outside the scope of the intent of the rules....the class ends up being a dud because the true entry level guys arent competitive any more, and the higher-end cars can compete in classes with better pay-outs by doing nothing more than jumping into a power adder class.
if aftermarket blocks are allowed....i wouldnt bother with that class any longer.
one more thing....its a little tough to build a new, big CI motor out of a new MegaBlock...when there arent any to be had.
