Page 2 of 4 1 2 3 4
Re: 1971 Haloween V24 340 Duster [Re: ScottSmith_Harms] #1820837
05/07/15 03:07 AM
05/07/15 03:07 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Originally Posted By ScottSmith_Harms
Take some more pics
In referance to the V24 I assume?
I ordered a new dash pad tonight from Dash Pad Pros. See how it looks, but for 215, I figured I couldn't go wrong. I want to get the dash frame stripped and painted this weekend along with my steering column parts. I have some black suede paint from Instrument Specialties. Im also going to send my cluster to Scott from ESE associates in Bartlett, Il probably monday. Glen Ray recomended them so I figured Id try it out. Have to wait a little bit to send the bezels out as this will tap my funds out for the time being. Had 340 demon bezel set re-chromed by Vacuum Orna-Metal out of michigan that turned out really nice and probably go through them again.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1820936
05/07/15 10:47 AM
05/07/15 10:47 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, I meant of the V24, you can't get too many, it's REALLY helpful when you are masking it off, pay close attention to the less obvious areas, in door jambs, behind or next to trim or body lines, etc. and include a tape measure in the shots to get dimensions. I haven't seen one done accurately yet, it's a rare thing to get the V24 right because so few exist with original paint to use for reference. twocents
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1821002
05/07/15 01:02 PM
05/07/15 01:02 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Ill be sure to do that. Do you have access to an original V24 picture showing the mask line running down the fender on the engine bay side? Thats the only piece of the puzzle missing.
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: ScottSmith_Harms] #1821012
05/07/15 01:20 PM
05/07/15 01:20 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
I believe my brother was toying with buying this car when it was for sale previously.
No; I was wrong it was a different car. Can't wait to see this one done.
Re: 1971 Haloween V24 340 Duster [Re: mopars_1] #1821295
05/07/15 08:39 PM
05/07/15 08:39 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Originally Posted By mopars_1
I have already done so Scott. I had them posted in a thread from a few months back in regards to just that. Only thing I dont know for sure is the spray pattern on the fenders themselves as they were missing. (Hint any pics on your end?)
Also located my pullys for the manual steering, a date coded NOS alternator shell with NOS internals, a 215 fan with a 3223 clutch. Still need to restore the clutch.. But this set up should free up some ponies from when i had it in the runner. Lastly, located a set of beautiful date code 340 exhaust manifolds. Ill be sending these out to get ported eventually.
Those pulleys look good! up
Re: 1971 Haloween V24 340 Duster [Re: moparpollack] #1821327
05/07/15 09:55 PM
05/07/15 09:55 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
laugh haha they sure do!!
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1828169
05/17/15 12:28 AM
05/17/15 12:28 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Got the dash frame painted today with instrument specialties suede paint. Threw the glove box door on to avoid dinging it up else where. Send gauges out probably Monday and id like to send out the bezels to get done also.. Be kinda nice to be done with the dash! Will be going with a new harness from M&H.
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1828314
05/17/15 10:08 AM
05/17/15 10:08 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I'm subscribed to your build. '71 340 Dusters are the bomb. It seems that the A body Rallye instrument faces hold up well through the years. Mine only needed a cleaning and needle painting.
I was wondering if you had any photos of the factory pinch weld blackout? My car also had remnants of what looked like blackout behind the rear bumper. Do you have pictures of the rear with the bumper removed?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1828595
05/17/15 04:24 PM
05/17/15 04:24 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I do not have the rear bumper removed yet. I can go snap what i can though. Still wanted to get some pictures posted on the hood blackout tape off areas. Not sure why the gauges on a bodies faired better? Im not arguing as it'll save me a bunch of money!
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1828720
05/17/15 08:26 PM
05/17/15 08:26 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I would appreciate it whenever you get a chance. I haven't been able to find out much about black out around the rear bumper. My car had some evidence but it had been repainted previously. I'd be interested in seeing if your car has some traces of black.
Kevin
Re: 1971 Halloween V24 340 Duster [Re: FJR doc] #1830399
05/19/15 11:04 PM
05/19/15 11:04 PM
Portland , Oregon, United Stat...
smokes Offline
smokes  Offline
Really liking the orange duster! I have a '71 that is getting a big block and I am thinking about painting it the same color with the blacked out hood! I followed your white road runner build and if this one turns out as nice I am sure it will look great! That shark tooth grille you found is really nice! Those are really hard to find. I can't wait to see how this one turns out!
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1830600
05/20/15 04:13 AM
05/20/15 04:13 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
whats goofy is this is my 3rd hemi orange 71 duster in the last 4 years haha. Must be a magnet to them! Im really excited about this car, wish work wasn't so slow otherwise Id be hammering the over time to get more funding for this, thus the slow pace. Im pretty confident I've secured a 71 duster parts car, just need to go get it. Parts cars are a must IMO in doing a restoration.
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1833519
05/24/15 11:02 PM
05/24/15 11:02 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
drool popcorn
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1879688
07/28/15 12:48 AM
07/28/15 12:48 AM
smokes Offline
smokes  Offline
Hey, what are the updates on the car??
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1879745
07/28/15 01:49 AM
07/28/15 01:49 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I've been putsing away at it! nothing major to post yet. I got the steering column pretty well done, just waiting on the ignition lock set to get in. the heater box is sitting on the bench ready to work on also. I'm thinking the dash cluster should be back within a month or so.
Being summer time, seems as though all my free time is spent getting other peoples projects done. Nice to have the extra cash flow to put towards the Duster though!
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1885329
08/05/15 12:22 AM
08/05/15 12:22 AM
smokes Offline
smokes  Offline
Well when you have some time smile Maybe post up some pictures of your current work??
Re: 1971 Haloween V24 340 Duster [Re: mopars_1] #1888202
08/09/15 07:14 PM
08/09/15 07:14 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Well, heres the column so far.
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1946505
11/06/15 07:17 PM
11/06/15 07:17 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Nothing major, but figured id post a small update. I ended up buying some pretty decent, original quarter panels. Some small creases, and the drivers side has a rust hole smaller than a baseball. Both of them for a lot less than what 1 reproduction costs. Also got a decent hood given to me!
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1946510
11/06/15 07:20 PM
11/06/15 07:20 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Also steering column is ready to go.
1937 Plymouth PT50
Re: 1971 Halloween V24 340 Duster [Re: mopars_1] #1965243
12/07/15 11:56 PM
12/07/15 11:56 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Nothing major, but wheels are painted up. Been busy with a new job and buying a house among other things. Dash should be done soonish i would think..
1937 Plymouth PT50
Page 2 of 4 1 2 3 4
