Re: Help with engine running very rich [Re: 73cuda340] #1818502
05/04/15 02:26 PM
05/04/15 02:26 PM
AndyF Online content
AndyF  Online Content
If you have gas coming out of the boosters then you probably have a problem with the needle and seat.
It isn't uncommon for these carbs to develop issues if you let them sit for very long with ethanol pump gas in them. I had an old truck that I didn't drive very much with an Edelbrock carb on it and I constantly had to pull the top off the carb and clean it out. The pump gas swill just eats at those carbs if it sits in there for very long.
Re: Help with engine running very rich [Re: AndyF] #1818936
05/04/15 11:19 PM
05/04/15 11:19 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I pulled the tops of both carbs off and it was clean inside. No white slime or residue from the ethanol. Pulled out the needle and seats and they were clean too. I cleaned everything up with carb cleaner, rechecked the float adjustment and put everything back together and it still wont idle by itself and it is still leaking gas out of the boosters. If I give it just a little gas it will stay running, but it still has very strong fumes from the exhaust that will burn your eyes even after a few seconds of it running. I'm ordering the fuel pressure regulator tonight and I'm really hoping that this will be the end to the problem. I appreciate all the help so far.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Help with engine running very rich [Re: 73cuda340] #1818988
05/04/15 11:55 PM
05/04/15 11:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you verify the floats were not leaky? If so, how?
Don't be the exception.
Re: Help with engine running very rich [Re: Supercuda] #1819030
05/05/15 12:23 AM
05/05/15 12:23 AM
clarks summit pa
clarks summit pa
They were floating on the gas that was in the bowls and when I pulled them out they were not full of gas.
Re: Help with engine running very rich [Re: 73cuda340] #1819053
05/05/15 12:48 AM
05/05/15 12:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you shake them and listen for slosh? Doesn't take much to keep the needles from seating. Had it happen twice to me over the years. First time I resoldered the seam, couple years later I just replaced them.
Re: Help with engine running very rich [Re: Supercuda] #1819086
05/05/15 01:19 AM
05/05/15 01:19 AM
clarks summit pa
clarks summit pa
I didn't shake them, but I did take them off to clean the needle and seats and I couldn't hear anything moving around and they were very light so I'm almost positive that they are still good.
Re: Help with engine running very rich [Re: 73cuda340] #1825300
05/12/15 11:27 PM
05/12/15 11:27 PM
clarks summit pa
clarks summit pa
I got the fuel pressure regulator installed and it does seem to run a little better and nowhere near as rich, however the problem is still there and I cant get the car to idle. I have the regulator set to 6 psi. I pulled out all the idle mixture screws and sprayed some carb cleaner in there and into the air bleeds as well. Does this sound like an idle circuit problem? I still cant get the car to idle by itself to see if everything else is okay.
Re: Help with engine running very rich [Re: 73cuda340] #1826843
05/14/15 08:36 PM
05/14/15 08:36 PM
clarks summit pa
clarks summit pa
The only way that I can get the car to idle is if I turn the idle up to around 1500-2000 rpm; I'm not sure as My car doesn't have a tach.
The vacuum was at 5 in/hg and when I looked at the metering rods, they appeared to be bouncing up and down a little bit. Im not sure if the vacuum is that low or the metering rods are bouncing slightly because of the idle being so high.
Re: Help with engine running very rich [Re: 73cuda340] #1826919
05/14/15 10:21 PM
05/14/15 10:21 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I run a pair of 750's atop a blower. As others have suggested, Edelbrocks are sensitive to pressure and float height.
I'd get your pressure down to 5-5.5 psi. (Up to 7 with a Holley)
If it's still flooding internally and the float isn't leaking, try lowering the offending float(s) slightly.
The stock step-up springs (orange) are rated at 5 in/hg. So if your engine is hovering at 5" vacuum at idle, the rods could be lifting (richening). Get your vacuum up or switch to stiffer springs. I'm leaning towards pressure/float height.
Re: Help with engine running very rich [Re: 70Duster440] #1829696
05/18/15 11:39 PM
05/18/15 11:39 PM
clarks summit pa
clarks summit pa
I took the whole carburetor apart again, cleaned everything again, lowered the floats a little more, and dropped the fuel pressure down to 5 psi and the car still will not idle. It is still running rich too. It only wants to idle at roughly 1500 rpm. I can sill see gas coming out of the boosters, but I believe the only reason now is because of how high the idle is. I am pretty much at a loss of what to do at this point.
Re: Help with engine running very rich [Re: 73cuda340] #1829824
05/19/15 02:47 AM
05/19/15 02:47 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You raised the float? That would make the problem worse. If you lower the float it will shut the fuel off at lower level in the bowl.
Re: Help with engine running very rich [Re: 70Duster440] #1830272
05/19/15 07:59 PM
05/19/15 07:59 PM
clarks summit pa
clarks summit pa
My bad, just a typing mistake. I lowered the float.
Re: Help with engine running very rich [Re: 73cuda340] #1831053
05/20/15 08:27 PM
05/20/15 08:27 PM
clarks summit pa
clarks summit pa
Does anybody here have a hemi, preferably 528, and know an average vacuum reading at idle?
Re: Help with engine running very rich [Re: 73cuda340] #1836812
05/29/15 06:00 PM
05/29/15 06:00 PM
clarks summit pa
clarks summit pa
Is there a set adjustment as to how far the primary throttle blades should be open at idle?
