Re: pics of my bearings for the 408 [Re: mopar dave] #1814665
04/29/15 05:15 PM
04/29/15 05:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Well, I'm curious what you're talking about, too.
As far as I know, every fluid pumping system is going to have flow limitations set by the size (restriction) of the passage(s), the viscosity of the fluid being pumped, the max free-flow volume of the pump, the max volume of the pump working against some set pressure (a product of the fluid's viscosity and that restriction), and any pressure-based blow-off limitation built into the system.
If the existing pump is already pushing the max capacity of fluid given the system's internal restrictions, and in the processs also hitting the peak pressure estabilished by the blow-off mechanism, then the only thing another pump could do differently is create more pressure from using a higher blow-off setting. However, the volume of fluid wouldn't increase signficantly past a certain point due to the limitation mentioned above.
Volume improvements under that scenario would need to come from enlarging the internal passage, not from trying to force-feed more oil through the same size passage.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814767
04/29/15 08:03 PM
04/29/15 08:03 PM
P
Porter67 Offline
Porter67  Offline
P
This mystery pump sounds ok, but id be asking why so many have no issues with the std melling pump or the hv melling pump.
Just say if 1000 racers builds use a melling pump and 999 use it without issues and 1 does id be looking cross eyed at the 1 because something is amiss with the 1. Im meaning something with the build/sum of parts itself.
Lets backtrack a bit.
Who built this motor?
Were the parts inspected with the proper tools and people prior to assembly?
What brought on the need to freshen things up?
How long has the current build been in service?
Im asking these things because I have dumped a lot into a couple oem blocks (should of went the race block from jump) however I have one id not give up for anything, a 4 bolted 1/2 filled 71 360 block that ive beat to death, had apart many times and kept the same coated bearings.
This is mainly do imo to good solid machine work.
All ive ever had to replace out of the norm was the small end bushings from on the gas off the gas at high rpm.
Instead of beating a dead horse id consider finding a good crank grinder/shop and in short order they can tell you what state your crank is currently and what it needs. Its what they do, day in, day out.
Re: pics of my bearings for the 408 [Re: Porter67] #1814783
04/29/15 08:22 PM
04/29/15 08:22 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
MRL Performance. I agree and know nothing more than I already mentioned. I think melling is a great pump but there is better. Titan but do I want to spend $800 for it. No. The pump mike has is said to be easier on bronze gears and is worth a few hp and feeds oil depending on rpm. I built this engine and best machine did most of the machine work. It went 8 years with 40 to 50 passes and some street miles.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814786
04/29/15 08:31 PM
04/29/15 08:31 PM
Mt Morris Michigan
Mt Morris Michigan
Not claiming to be a pro engine builder. Just a hobbies with 6 engines built and no major failures. My tools are not the most expensive but get the job done. Craftsmen. My knowledge comes form this site as well as mopar performance books and other professional engine builders. The engine block and all components are getting checked and machined properly. Nothing gets throw together in my garage without getting checked and machined.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814792
04/29/15 08:42 PM
04/29/15 08:42 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Maybe I missed it. How much bearing clearance did it have? How much oil pressure at what RPM level? Are the main bearing bore dimensions correct and in line? How was the assembly balanced? Studs or bolts? What crank? What rods? What oil pan? What oil? Many questions to answer here before someone decides it needs a "trick oil pump". To me it appears the crank is flexing with too little clearance causing irregular wear and metal transfer on mains #2 & #4. Rods appear to have been borderline on losing oil film causing the shiny spots but no metal transfer. Way more information needed to make a good repair. I will say that the bearings look very poor.
Doug
Re: pics of my bearings for the 408 [Re: dvw] #1814820
04/29/15 09:30 PM
04/29/15 09:30 PM
dogdays Offline
dogdays  Offline
Yes, Dave, the reason I asked the question was because I think there's a good possibility that you're being sold something that won't have any effect except to lower your bank balance.
Whether the shop is ignorant or dishonest I don't know, but IMHO it has to be one of the two. Hate to sound harsh, but I do pumps for a living and my BS meter is off the charts.
Any time I hear about a $180 oil pump that resides in the oil pan like a stocker I have to wonder why. The Mopar design gearotor pump is a good one.
The other thing that sticks in my mind is that you are not going to get much difference in efficiency between any well-designed positive displacement pump. They have about the same efficiency across the board, and the gerotor pump is more efficient than the two gear type pump. Your existing pump is the gerotor type.
Good Luck,
R.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814878
04/29/15 10:03 PM
04/29/15 10:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Don't out-trick yourself with trickery. I just took my engine apart after four years (2 years pump gas, 2 year alcohol) and my bearings looked GREAT. 35 dollar melling standard volume, standard pressure pump.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: pics of my bearings for the 408 [Re: pittsburghracer] #1814885
04/29/15 10:12 PM
04/29/15 10:12 PM
PA.
"Little"John
"Little"John
PA.
To add to this I will never use a Canton oil pan on my small block again without modifying it. I bought one after seeing how nice the small block Chevy one was when I built an engine for a Friend. The Mopar one was a piece of JUNK compared to it and my oil pressure was dropping like a turd when I left the line. I put it on hoping it would give me more room than my Milidon did with the 1 7/8 Hedmen headers so I could use a diaper. NEVER again and thank God for my Racpak or I may have not caught it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: pics of my bearings for the 408 [Re: dvw] #1814897
04/29/15 10:24 PM
04/29/15 10:24 PM
Mt Morris Michigan
Mt Morris Michigan
.002 on both rods and mains. Used main studs. Had a local shop hone the mains. Eagle forged crank and rods. Moroso pan. Don't know how it was balanced but the guy that did it has a great rep. Brad Penn oil and now amsoil dominator 15/50.
Re: pics of my bearings for the 408 [Re: dogdays] #1814901
04/29/15 10:31 PM
04/29/15 10:31 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the heads up. My bs meter is also on but I'm going to take a look at it next week. Says he will have one to open up. Should be interesting. Been using melling 72hv precision pump. I'm familiar with the melling pump as iv had them apart.
Re: pics of my bearings for the 408 [Re: BradH] #1814912
04/29/15 10:40 PM
04/29/15 10:40 PM
Mt Morris Michigan
Mt Morris Michigan
Makes perfect sense to me. I will find out more next week.
Re: pics of my bearings for the 408 [Re: mopar dave] #1814930
04/29/15 11:05 PM
04/29/15 11:05 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
How much pressure? To me .002 with 15/50 is tighter than I would run. Personally most of my stuff is about .0027-.0029 and I run 5w30.
Doug
Re: pics of my bearings for the 408 [Re: mopar dave] #1814938
04/29/15 11:15 PM
04/29/15 11:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Dave.... Did you say you used the Melling pump that a company called Precision blueprints?
Ran one of them in my old W5 motor and thought it was up to snuff.
I would be extremely suspect of a 180 dollar miracle oil pump, as I am sure you are as well.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: pics of my bearings for the 408 [Re: B3422W5] #1814959
04/29/15 11:35 PM
04/29/15 11:35 PM
Mt Morris Michigan
Mt Morris Michigan
Yes. That the same one. I want to see what he has but I do like what a have.
Re: pics of my bearings for the 408 [Re: dvw] #1814963
04/29/15 11:39 PM
04/29/15 11:39 PM
Mt Morris Michigan
Mt Morris Michigan
15 to 20 at idle hot. 55 at anything over 3000. 80 cold
Re: pics of my bearings for the 408 [Re: mopar dave] #1815012
04/30/15 12:18 AM
04/30/15 12:18 AM
P
Porter67 Offline
Porter67  Offline
P
Ive not had an Eagle crank that was good enough out of the box to run .002 on rods and mains, so the first go around it was 003.
But at the same time im having trouble with a "Quality" K1 kit and could of saved 8 bills with a eagle kit and been just as good.
One of the decent mopar shops told me if all was machined right and the crank was 10/10 .002 was doable and I had that one on the dyno just about a month ago.
Nice vid of your car as well. Since you have some micro scratches your going to take it in anyways and im sure you will get your answers.
Btw that's a good long run on your motor prior to this. The long runner I mentioned also had a Eagle forged kit in it as well.
Re: pics of my bearings for the 408 [Re: Porter67] #1815072
04/30/15 01:07 AM
04/30/15 01:07 AM
Mt Morris Michigan
Mt Morris Michigan
when I bought the eagle crank I thought it was good right out of the box. over the yrs i'v learned better. the crank will be corrected and I would like to do some oil mods, but i'm still not sure which ones are most effective. I will check out MRL's pump and see what he thinks is so special about it. if I like I just might buy one, but it will have to be something very different. thanks for all your thoughts guys. its been helpful
