318 Bottom End Strength #181376
01/02/09 11:57 AM
01/02/09 11:57 AM
Bothell, Washington
71Swinger318 Offline OP
Bothell, Washington
What kind of compression can a stock (rebuilt) 318 bottom end take before you start bending rods/hurting the crank? Sadly, the crank and rods are already balanced and installed, but the engine is still out. I ran across a set of pistons that would put my motor at ~11.2:1 compression, and im concerned about breaking stock castings.
Any Help is Appriciated,
Thanks,
Bill
MoPar Or NoCar 1971 Dodge Dart Swinger 1978 Dodge Power Wagon Ex-Forest Service 1995 Jeep Grand Cherokee Limited 5.2/AWD
Re: 318 Bottom End Strength [Re: 71Swinger318] #181377
01/02/09 01:24 PM
01/02/09 01:24 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Compression ratio does not matter in regards to parts breakage. What does matter is running too much compression and having detonation that will break parts. Unless this is a race gas/aluminum head motor, you need to rethink your piston choice for no more than 9.5-1 with iron heads. Look at Keith Black pistons site for a good choice and Summit sells them for under $275 a set for Hyperutectic cast pistons.
Re: 318 Bottom End Strength [Re: 71Swinger318] #181378
01/02/09 01:30 PM
01/02/09 01:30 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
You say the crank and rods are balanced and installed, I assume you have pistons already on those rods? If thats the case, changing your pistons will likely throw the balance out, and youll need to do it again.
Re: 318 Bottom End Strength [Re: 71Swinger318] #181379
01/02/09 02:17 PM
01/02/09 02:17 PM
NC
alpha727 Offline
alpha727  Offline
NC
Hot Rod has an article where they got over 400 HP and over 400ft.lbs. torque out of a stock 318 shortblock. link:
http://www.hotrod.com/howto/113_004_318_small_block_build/index.html
Re: 318 Bottom End Strength [Re: 71Swinger318] #181380
01/02/09 05:31 PM
01/02/09 05:31 PM
CA
David Lee Offline
David Lee  Offline
CA
I run my stocker motor with the stock 340 rods and cast 318 crank. I go thru the traps around 6800 rpm and never hurt the rods or crank
Ah...so many pedestrians, so little time...
