Re: Switched to synthetic oil and have a question. [Re: shart70rt] #1812777
04/27/15 12:45 AM
04/27/15 12:45 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
Unless I missed it somewhere....I did not read where you used an engine flush before switching over to synthetic....?? When I switched my diesel engines over from conventional to Amsoil, I was told to use the engine flush that Amsoil sells to help clean up the cylinder walls and all from the contaminants.
They said to pour the flush in with the conventional oil and run the engine for either 20 or 30 minutes (cannot remember) and (do not drive with the flush in the engine) but after the run time, drain the engine and then put the new synthetic oil in and my engines always looked clean when checking the oil.
One main thing I remember when I switched was that the engine temp. always seemed to run about 5° cooler with the synthetic over the conventional oil......
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Switched to synthetic oil and have a question. [Re: gch] #1812813
04/27/15 01:22 AM
04/27/15 01:22 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Originally Posted By gch
Originally Posted By 65Fury440
Originally Posted By old chief
I would be real careful using Synthetic in old muscle cars with flat tappet cams. Flat tappet cams REQUIRE an oil with Zinc in it. You really need a racing oil with Zinc, for instance, VR1 Valvoline, or Amsoil Dominator racing oil, Joe Gibbs racing oil. They have taken all the Zinc out of oils because it plugs up Catalytic Converters. I learned the hard way. At least put an additive with Zinc in it.
This might be an interesting read.
https://540ratblog.wordpress.com/
Big thread on this guy on the corvette forum.Film strength test being taken as gospel without wear and other factors taken into consideration.One guy chellenges him pretty strongly.I will provide a link if anyone is interested.
I would like to read that. The logic this guy is presenting, to a layman like myself, seems to make perfect sense.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812818
04/27/15 01:35 AM
04/27/15 01:35 AM
Good Ole USA
djw383 Offline
djw383  Offline
Good Ole USA
I was told you could not run Zinc in full synthetic, that's why Spector makes semi synthetic with the zinc added in...
Re: Switched to synthetic oil and have a question. [Re: djw383] #1813007
04/27/15 01:31 PM
04/27/15 01:31 PM
dogdays Offline
dogdays  Offline
Bullpoop. The three most dangerous words are, "I was told".
Synthetic lubricants probably require different additive packages than petroleum based oils, that's true. But there are several brands of engine oil with high levels of zinc in a pure synthetic base stock.
R.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1813056
04/27/15 02:37 PM
04/27/15 02:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If anyone is concerned about zinc and phos in a synthetic, here is a Blackstone Labs used oil analysis for Shell T6 (synthetic Rotella) off of a BMW forum.
12,500 miles on the oil.
Kevin
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1813074
04/27/15 03:00 PM
04/27/15 03:00 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Wow. Since I've had the motor in my car, I've used only Mobil 1 15w-50 along with one bottle of Comp Cams break in lube. In 5 years, I've changed my oil once. Just checked it yesterday, and it's still pretty clear. On average, I'll drive about 600 miles/year. To be fair though, the first several years it wasn't really driven at all. 2012 was the first year I started driving it more than just back and forth from a shop/garage. And that was late 2012, so I'll say 2013 for all intents and purposes.
1968 Plymouth Road Runner 383 4 speed
Re: Switched to synthetic oil and have a question. [Re: 65Fury440] #1813082
04/27/15 03:09 PM
04/27/15 03:09 PM
hooziewhatsit Offline
I too would be interested in reading the other discussion.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1814570
04/29/15 02:21 PM
04/29/15 02:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I agree, if you're changing oil every year at 1500 miles, synthetic is a waste. That said, I wouldn't go running to change it now, I would just run it for the year as-is.
Also, out of curiosity, why are you running 20w50? Were you getting low oil pressure with 10w30 or just jumping on the "old cars need thick oil" bandwagon?
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1816993
05/02/15 12:01 PM
05/02/15 12:01 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
http://www.corvetteactioncenter.com/tech/oil/oil_camwear2.html
Here's a good article on zddp, even though not what the OP was was about, it came up in the discussion.
dstryr, since 1986.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1817339
05/02/15 10:10 PM
05/02/15 10:10 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
You all could have a bit of a look at service intervals on every car ever produced in the last 50 years, I have yet to see one based purely on mileage - there is a time factor in there too, this is because various parts of the oil start losing their effectiveness when exposed to heat/air/contaminates, I think 6 months OR 3000 miles is more appropriate than a year - its not like its a huge $$ thing to protect your $howevermuch to replace motor
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1819056
05/05/15 12:49 AM
05/05/15 12:49 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
A few thoughts,
I wouldn't stress over the appearance of the oil in such a short time. Motor oils have heat activated additives that change appearance with normal use. Nothing to be concerned about. Here's a video from GM which I find helpful in showing folks it's very difficult to judge motor oil useful life based on color alone. I'll start the video at 1:05min to avoid the marketing on GM's OLM system. -> https://youtu.be/oi_J4SZUlSo?t=1m5s
I also agree with others that 20W-50 may be overkill. Don't know the specifics of your build, but as I recall, the general rule is 9-to-10psi per 1,000rpms. You may be able to accomplish that with a decent 10W-30 and free up a pony or two in the process.
Also, plenty of full synthetics with lots of Zinc in them. I'd also agree that in a seasonal driven muscle car application, synthetic may not provide a meaningful advantage. There's lots of good options commonly available. With an old school cam grind, I'd consider a 10W-30 Rotella or even a Quaker State DEFY 10W-30. With a newer fast-rate flat tappet I'd go with the specialty muscle/race oil.
Also, there is one area I can think of where a top tier PAO synthetic may be advantageous in a muscle car application. That is PAO synthetics have shown an increased ability to stay within their viscosity grade when fuel dilution is a potential occurrence like for example in carbureted engines. But you won't really be able to tell you'r degree of fuel dilution without used oil analysis testing.
Good Luck beer
Re: Switched to synthetic oil and have a question. [Re: Alchemi] #1819374
05/05/15 03:01 PM
05/05/15 03:01 PM
Manitoba, Canada
Manitoba, Canada
Who do you think came up with those oil change intervals? Scientists working in a lab for the good of mankind? Or was it oil companies/car manufacturers who make money every time you come in for an oil change?
