proportioning valve delete? #1610829
04/23/14 04:01 AM
04/23/14 04:01 AM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
I'm running 13" disks on the front, 11.7" on the rear. I'm making my own brake lines as I will be installing a hydraulic ebrake on the rear lines and a line loc on the fronts. Just to be sure - can I delete the stock proportioning valve and just use Tee's instead? I'll be adding an adjustable brake proportioning valve on the rear line to dial in the brakes.
Re: proportioning valve delete? [Re: dangina] #1610830
04/23/14 08:37 AM
04/23/14 08:37 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Yes, you can. I ran a T up front, and a adj prop valve for the rear sticking through by the drivers seat.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: proportioning valve delete? [Re: dangina] #1610831
04/23/14 09:29 AM
04/23/14 09:29 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I'm using the Wilwood adjuster. Removed the stock valve and put the new one in it's place.
Re: proportioning valve delete? [Re: brads70] #1610832
04/23/14 09:47 AM
04/23/14 09:47 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I am having a problem where my brakes work too good and I can't heel toe like before. I just touch the brakes trying to heel toe and the brakes just bite down hard. I have Dr. Diff's 13" kit in front Cobra discs in back and hydroboost, will an adjustable proportioning valve dial this out?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: proportioning valve delete? [Re: RylisPro] #1610833
04/23/14 10:58 AM
04/23/14 10:58 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I'm considering hydoboost as well at some point. I have read from others that it's better to use the bell crank from the stock power brakes set up when using the hydroboost set up? Makes then less "touchy" they say? No first hand experience just thought I'd pass that along?
Re: proportioning valve delete? [Re: brads70] #1610834
04/23/14 10:54 PM
04/23/14 10:54 PM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
Yes, but I wouldn't go there or ever suggest it for anything approaching normal use. Try a less aggressive set of pads, see if that is enough.
I used to swerve around my hallucinations, now I drive right thru them.
Re: proportioning valve delete? [Re: ntsqd] #1610835
04/23/14 11:06 PM
04/23/14 11:06 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I was actually going to step up to Carbotechs once these pads are worn down,
I will just have to change my driving style
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: proportioning valve delete? [Re: RylisPro] #1610836
04/23/14 11:08 PM
04/23/14 11:08 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
what size master cylinder? I'm assuming it's pretty large, so your pedal throw will be quite short.
If you want to heel toe again (and you want to keep your hydroboost), you should adjust your pedal heights to where the brake is closer to the gas pedal height at threshold braking.
I have manual brakes - 15/16" master - has a decent pedal throw (correct for heel toe when threshold braking, though well shy of heel toe reach when normal braking). That's obviously the other option.
Re: proportioning valve delete? [Re: brads70] #1610837
04/23/14 11:38 PM
04/23/14 11:38 PM
dangina Offline OP
dangina  Offline OP
very cool - I didn't even know about this, I bought their inline one.
this. But I assume he probably knows this already if he does heel toe braking.
Thanks for the info guys! I can now finish my brake lines on my days off next week
Re: proportioning valve delete? [Re: Uhcoog1] #1610838
04/24/14 12:55 AM
04/24/14 12:55 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I am using a 13-1860 aluminum Dodge truck master cylinder 1.13" bore
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: proportioning valve delete? [Re: RylisPro] #1610839
04/24/14 04:10 AM
04/24/14 04:10 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I'm going to say no since the proportioning valve only holds off pressure to the rear brakes. Is there a way to regulate the pressure from the PS pump to the hydraboost unit? I think that is the only way to dial back the assist.
Re: proportioning valve delete? [Re: ntstlgl1970] #1610840
04/24/14 09:34 AM
04/24/14 09:34 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I believe using the stock bell crank instead of direct from the pedal to the HB changes the ratio.
Re: proportioning valve delete? [Re: brads70] #1610841
04/24/14 02:10 PM
04/24/14 02:10 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would toss the HB, way overkill IMO.
Mopar to the bone!!!
Re: proportioning valve delete? [Re: 72Swinger] #1610842
04/25/14 03:06 AM
04/25/14 03:06 AM
dangina Offline OP
dangina  Offline OP
not for overkill, for overdrift! lol I'll post pics of it when I'm done, something no one has thought of yet
Re: proportioning valve delete? [Re: ntstlgl1970] #1610843
04/29/14 12:05 AM
04/29/14 12:05 AM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
There are pressure regulators made for street rods running PS R&P's, which don't need the pressure that pumps made for steering boxes can provide. Don't know why they don't just adjust the regulator in the pump, but whatever.
In this case I read it as a bias problem, not an excess boost or pressure problem. Did I get it wrong?
Re: proportioning valve delete? [Re: brads70] #1810376
04/23/15 07:51 PM
04/23/15 07:51 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
I know this is super old, but thanks for the picture and the idea.
I was just about to order an in-line proportioning valve for my 4 piston brake conversion, but this is a heck of a lot slicker looking.
Just ordered myself one and will mount it in place of the stock splitter.
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: proportioning valve delete? [Re: dangina] #1810388
04/23/15 08:01 PM
04/23/15 08:01 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im still into the simple inline next to the driver seat method personally.
Re: proportioning valve delete? [Re: 72Swinger] #1810394
04/23/15 08:06 PM
04/23/15 08:06 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Maybe when I build my 69 Coronet AutoX'er... the 69 Satellite wagon is just a cruiser that may see the AutoX course once or twice.
Re: proportioning valve delete? [Re: Sneke_Eyez] #1810397
04/23/15 08:09 PM
04/23/15 08:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Not knocking you or the Wilwood, that thing is on about everything I see guys building these days. It has its place and takes the guesswork out of "which proportioning valve do I need..."
Re: proportioning valve delete? [Re: Sneke_Eyez] #1810635
04/24/15 12:29 AM
04/24/15 12:29 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
quote]
Just ordered myself one and will mount it in place of the stock splitter. [/quote]
To be honest I've never had to adjust it, It has always been wide open, you might get by with out it?
